Question about HP LaserJet 4700 Printer
When printer is turned on it reads 256MB and that is it. No menu buttons or anything else will work. Never get ready light.
  • HP Master
  • 6,826 Answers
First, try to unplug and wait 30 sec. then replug the printer into the wall to try to reset it. Then, read below to see if there is a solution if the '256mb' display problem persists. Control panel display is blank No display message Cause Solution The printer’s on/off button is in the standby position. Verify that the printer is on. Fans might run while the printer is in standby mode (off). The printer’s memory DIMMs are defective or installed incorrectly. Verify that the printer’s memory DIMMs are correctly installed and are not defective. The power cord is not firmly plugged into both the printer and the power receptacle. Turn off the printer and then disconnect and reconnect the power cord. Turn the printer back on. The line voltage is incorrect for the printer power configuration. Connect the printer to a proper voltage source, as specified on the Power Rating Label on the back of the printer. The power cord is damaged or excessively worn. Replace the power cord. The power source receptacle is not working correctly. Connect the printer to a different power receptacle. Printer is on, but nothing prints Cause Solution The printer’s Ready indicator light is not lit. Press STOP to return the printer to the Ready state.
Posted on Jul 14, 2010
Control panel not working
The panel menu attaches to the DC Control Board. I would remove the panel and reseat the connection.
Aug 13, 2017 | HP Laserjet M2727nf Multifunction Printer
I just replaced my ink on E238 laser printer and the yellow light is flashing. I have been on hold for 45 mins with you help line. Everything still prints but the light is flashing
  1. Enter the printer's Configuration Menu. To do this:
  2. Turn off the printer.
  3. Open the front cover
  4. Press and hold the Continue () button.
  5. With the front cover open and the Continue button pressed down, power on the printer.
  6. Hold the Continue button until all the lights cycle.
  7. When just the Error light (!) is displayed, close the front cover. The top four lights of the operator panel should come on, indicating that the printer is in configuration mode.
  8. Print the Configuration Settings page. To do this:
    • Press and hold the Continue () button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
      Save this page for possible later use.
  9. Reset the photoconductor page count as follows:
  10. Press and release the Cancel button () to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low () light is the only light left on.
  12. Press and hold the Continue button until all of the lights flash.
  13. Then release the button. When the Toner Low light is once again the only light left on, the photoconductor page count should be reset to zero.
  14. Return the printer to normal mode. To do this:
    • Power it off for five seconds and then turn it back on.
  15. Print a menu settings page. To do this:
    • When the Ready () light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
  16. Check the photoconductor reading on the menu settings page. To do this:
  17. Look for a section labeled Cartridge Information and locate the word Photoconductor under that heading.
  18. Confirm that the photoconductor level reading is OK or close to 100%.
  19. If the photoconductor reading is low, try printing 10 - 20 pages.
  20. Print the menu settings page(s) again. Confirm that the photoconductor level reading is OK or close to 100%.
  21. If the photoconductor reading is still low, refer to the Configuration Settings page you printed in Step 2.
  22. Confirm that Reset Photoconductor Counter is listed on the page.
    Also confirm that the light sequence for the photoconductor counter is the Toner Low light.
    • If the light sequence is correct, try repeating this entire procedure again from the beginning to reset the counter once more.
    • If a different light sequence is listed for the photoconductor counter, repeat the procedure but this time, instead of stopping at the Toner Low light (Step 3.2), press the Cancel button until the operator panel shows the light sequence that corresponds to the one listed on the Configuration Settings page. Continue with the remainder of the procedure as before to reset the counter again.
  23. If the photoconductor reading is still low after the page reset procedure has been performed twice, the printer may require service.
May 04, 2011 | Lexmark E238 Laser Printer
Replace fuser E error
Reset Fuser counter Oki B6200 Action: Power on and wait until the ready to print message appears on the operator panel. Press "Select and the Down arrow button at the same time" The following Menu is displayed"Reset Counter Fuser U4" Press the right arrow button Operator Panel will display "Fuser U4 Use the SEL to Reset" Press the SELECT Button Operator Panel will read "Clearing" Press the Menu key to return to "Ready to Print Mode"
Apr 05, 2010 | OKI B6200 Laser Printer
No printing, printer says ready, will test print from menu button
Go to my computer, click on control panel, click on printer/fax and see what is set for default. What ever printer icon that says ready, right click and set as default.
Mar 11, 2010 | HP LaserJet 4 plus Printer
79 error displayed power on power off and the
Hi
I can only say try it may work.
A solution:
  • Unplug
  • Hold down "*" & "enter/ menu buttons"
  • While holding down both buttons, turn power on
  • Wait until something like "initialize" shows up on the display
  • Let go of buttons
  • Wait until display reads "ready"
  • Unplug for 10 seconds, then plug back in
  • Please let me know if works for you.
  • All The Best Pineworks
Jan 11, 2010 | HP LaserJet 3330 All-In-One Printer
How do I replace the photoconductor where is the menu button to reset PC CNT appears after it is replaced?
Power the printer on and get it to the Ready state. With the printer on and in the Ready state, open the front cover.
Press and hold the Cancel button until all of the lights begin flashing up and down.
Release the Cancel button and close the door. The photoconductor count should now be reset.
To confirm that the photoconductor page count has been reset, it is recommended that you print a menu settings page and check the photoconductor level. Do the following:
With the printer at the Ready status, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Look for a section labeled Cartridge Information and locate the word Photoconductor under this heading.
Confirm that the photoconductor level reading is either OK or close to 100%.
If the reading is low, try printing 10 - 20 pages. Print the menu settings page(s) again.
Good luck, Gerrit Jan
Oct 29, 2009 | Lexmark E232 Laser Printer
My Brother MFC-235C shows print unable 32 read user manual but I dont have a manual
The message "Print Unable 32" or "Machine Error 32" will appear on the LCD display if paper or labels are stuck inside the printer or drum unit.
This will also appear if there is either a mechanical issue or just a problem with a sensor possibly software.
1) The way to resolve this issue is to make sure there is no paper in between the rollers or on top of the print heads (if applicable).
2) If there is no paper the you will need to hard reset the printer which will restore to manufacuter settings and reset software.
Hold down the Menu botton while plugging in the power cable. The display should read "Maintenance." let go of the menu button and then punch in 91. The display should read "Param Init." The unit will beep once. Then type 99. The unit will exit maintenance mode.
This only works for maybe 30% of the time.
3) If this does not work then : Refer to Manufacturer or return the item.
IF PRINTER DOES NOT HAVE A MENU BUTTON:
1)Turn the printer power switch OFF. Check that the front cover is closed.
2)Turn the printer power switch ON while holding down the GO button until the Toner, Drum and Paper LEDS are lit.
3)Release the GO button. All LEDs will be off.
4)Press the GO button 8 times. The Ready LED will flash briefly while the printer is reset. After the printer is reset the READY LED will be lit.
Feb 19, 2009 | Office Equipment & Supplies
I have just bought a new photoconducter unit and put it in the printer. Instructions talk about select, return buttons, menu buttons and exit buttons. My printer does not seem to have this. It only has the...
  3. Open the front cover, as shown below.
  4. Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button.
    • Press and hold the Continue (pattlnk_1122005_1857-enus20682_continuebuttonicon_e230_en_us.gif) button until all of the lights flash. This page lists the functions within the Configuration Menu. The functions are the non·indented items listed along the left edge of the page (along the bottom as printed from printer). They are also unshaded.
  10. Press and release the Cancel button (pattlnk_1122005_1917-enus20682_cancelbuttonicon_e230_en_us.gif) to move sequentially from one menu item to another. NOTE: If you get lost, you can press and hold the Cancel button to jump to home state (top four lights on).
  11. Press and release the Cancel button until the Toner Low (pattlnk_1122005_215-enus20682_tonerlowbuttonicon_e230_en_us.gif) light is the only light left on.
    • When the Ready (pattlnk_1122005_218-enus20682_readylighticon_e230_en_us.gif) light is on, press the Continue button once. The Ready light will begin flashing and one or two pages will print out.
Jan 01, 2009 | Lexmark E238 Laser Printer
How do i reset a new photoconductor in lexmark e450dn.
According to Lexmark E450DN service manual;
1. Turn off the printer.
2. Press and hold Checkmark and Right Arrow buttons.
3. Turn on the printer.
4. Release the buttons when 'Performing Self Test' displays.
The message CONFIG MENU displays on top line of operator panel.
5. Scroll down and select 'Reset PC Cnt.'
Sep 25, 2008 | Lexmark Office Equipment & Supplies
Ibm infoprint reseter
Here is a procedure I would like you to do to reset the light:
1-Power the printer on and get it to the Ready state (i.e. the light on the operator panel is on)
2-With the printer on and in the Ready state, open the front cover
3-Press and hold the Cancel button until all of the lights begin flashing up and down.
4-Release the Cancel button and close the door. The photoconductor count should now be reset
1.With the printer at the Ready status, press the Continue button once. The Ready
2. Look for a section labeled Cartridge Information and locate the word Photoconductor
under this heading.
3. Confirm that the photoconductor level reading is either OK or close to 100%.
4. If the reading is low, try printing 10 - 20 pages.
5. Print the menu settings page(s) again.
6. Confirm that the photoconductor level reading is OK or close to 100%.
7. If the photoconductor reading is still low, there is a second, more detailed, procedure you
can perform to reset the count.
8. If the reading is still low after both procedures have been attempted, the printer may require service
Apr 06, 2008 | IBM Infoprint 1412 Laser Printer
HP LaserJet 4700 Printer Logo
191 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
