Question about KitchenAid Refrigerators
Not cooling - 52 degrees vs.35 - KitchenAid Refrigerators
  • 11,800 Answers
This can be caused bu a lot of problems: the thermostat is faulty, the compressor is dead, the controlling valve is malfunctioning, the coolant/freon has leaked out, the fan doesn't work, the air channel between the freezer and the refrigerator is blocked, heck, there could be even a fault on an electric cable. Without more details and a serious testing it's impossible to provide a better answer. All i can say to you is to start checking for power: at the wall socket, at the thermostat, at the compressor, at the valve (if your unit has one). If all are active and functional then the fluid has been lost.
Posted on Jul 14, 2010
What is the best temperature for white wine to be in?
It is important to keep the wine cool and in stable temperature that doesn't fluctuate very often. Bright tart white wine: 48-52 degrees; sparkling wine: 50-55 degrees and rich white wines: 58-62 degrees.
May 29, 2012 | Furniture
Freezer works refridgerator only cools to 52 degrees
Check out these tips...they can help you figure out what is going wrong withyour refrigerator and why it is not cooling
Refrigeratornot Cooling or Fridge not Cooling
How to Defrost Refrigerator DefrostTimer Problem
WaterRunning in refrigerator from Freezer
Refrigeratoror Freezer not Cooling or Getting Cold
heatman101
Jul 02, 2011 | Magic Chef Refrigerators
I need to know what the following codes mean for a 1989 Dodge Ram. 12 24 35 52 17
12 Battery or computer recently disconnected (will occur on most cars most of the time, it indicates a low / missing battery happened in the last 50 key starts. Don't worry about it. — Tom Wand)
24* Throttle position sensor over 4.96V (SEE NOTE #3)
35 Cooling fan relay circuit open or shorted
52 Oxygen sensor stuck at rich position (SEE NOTE #5!)
OR
52 Internal logic module fault ('84 turbo only)
17 Engine stays cool too long (bad thermostat or coolant sensor?)
NOTE 3
Matt Rowe: “The throttle postion circuit tells the computer how far the accelerator is depressed. The Throttle Position Sensor (TPS) is on the throttle body on the opposite side of the throttle cable. The connector should have a round rubber cover over the connections. Clear the fault codes, start the car and try jiggling the wires/connectors to try to trip a fault code. Loss of this signal could cause other problems.”
Tom Wand: “Throttle Position Sensors (TPS) will on some early 1990s trucks start to drift high in voltage, there was a problem with these and the idle will not set low enough. Need to replace if it does this. As I recall, the output voltage at idle is 2.4 volts, much above is no good.”
NOTE 5
Wade Goldman wrote: In my case, the breather tube leading into the catalytic converter had rusted and become detached. This some how would cause the sensor to read an over rich condition and run crummy. I did not trust the reliability of the weld over a corroded surface and opted for the more expensive route of replacing the converter, breather tube and all.
More details can find in 80s-codes
Hope thats help (remember rated this FREE help) Good luck.
Jan 29, 2010 | 1989 Dodge Ram D-Series Pickups
Wendy has 52 coins consisting of niclels and pennies. If the value of the coins is $1.20 then how many of each coins type does she have
Let X=Number of pennies
Then (52-x) =Number of nickels.
You can then say that:
(x*1) + (52-x)(5) = 120
x + 260 - 5x = 120
260 - 4x = 120
260 - 4x + 4x = 120 + 4x
260 = 120 + 4x
260 - 120 = 120 + 4x - 120
140 = 4x
35 = x = Number of pennies
52 - 35 = 17 = Number of nickels
Verify: (35 * .01) + (17 * .05) = $1.20
.35 + .85 = $1.20
$1.20 = $1.20
Nov 15, 2009 | Microsoft Word 2003 for PC
2005 F 150 A/C just won't keep the cab cool.
sounds like a compessor problem, it would have to be about 120 degrees outside for 47 degrees at the vent- should be around 30-35 degrees at the vent. sounds like the compressor is only working when its under load-which usually indicates internal failure
May 18, 2009 | 2005 Ford F-150
Norcold fridge not cool enough
Yes very likely the cooling unit has stopped working. You need to do a bypass test by unplugging the thermistor on the inside of fridge. It will be attached to the fins. Give it 6 hours or so and check your temps. If they are the same the cooling unit is bad. If the temp goes down the thermistor or circuit board is bad. If you need more assistance feel free to call.
734 777 6432
Jan 25, 2009 | Refrigerators
Refrigerators Logo
62 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
mike cooper
Todd Arndt
Todd Arndt
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
