Question about Remington Electric Chain Saw
What kind of oil in the oil tank and how much for the remington electric pole saw ?
  • 518 Answers
Bar & chain oil is the best. You can use regular or synthetic. Some say you can use atf (auto transmission fluid) or sae30 oil. I use bar & chain oil.
Posted on Jul 14, 2010
What kind of oil or lubricant is required on a Remington Pole Saw, model # 108526-01?
Hi. Use any brand name bar and chain oil for your pole saw. Usually this oil is only sold by the gallon....so you may have quite a supply on hand. J.
Aug 01, 2010 | Remington Electric Pole Saw
Remington electric Pole Chain saw - what type of oil do I use?
Use regular bar/chain oil available from home centers, hardware stores, and saw shops. Good luck!
Jul 28, 2010 | Remington Electric Pole Saw
Oil leaks out of the remington electric pole saw. The saw is stored/seated upright and I can't see the problem
Remove the bar and chain, then clean the entire area. Look for leakage at either the small port where the bar fits, or from the motor case itself. Make sure the oil tank vent is open so that pressure doesn't build up from heat. If the leakage is from the case, then look for a crack in the oil tank, or a defective oil line from the tank to the oil pump. Clean the drive end of the bar oil-channels that go out from the large holes to the chain groove on each side. Clean the entire chain groove. It also may be easier to just dump the oil out of the tank after each use if the chain seems to oiling properly. Hope this helps!
Jun 15, 2010 | Remington Electric Pole Saw
Am I wise to purchase a Remington Pole Saw or should look for another manufacturer? Which Remington Pole Saw would you purchase: a. 18V Cordless b. 10" Electric
Remington Saws have ceased operations and, unless you like to make your own replacement parts, they are prone to failure. The gearbox is sealed and the motor brushes are not available anywhere. Look elsewhere!
May 11, 2010 | Remington Electric Pole Saw
SAE 30 motor oil if the temperature is between 30 & 75°F.
-Colder use SAE 10 oil.
-Warmer use SAE 40 oil.
take a look on amazon: Amazon com SAE 30 motor oil
Apr 24, 2010 | Remington Electric Pole Saw
What kind of oil solution do I use in my remington chain pole saw
I recommend bar and chain oil (SAE 30 with additives to make it adhere) available at hardware stores and home centers.
From a Remington OM, page 9 (edited).
FILLING OIL TANK
1. Remove oil cap.
2. Fill oil tank with SAE 30 motor oil if the temperature is between 30 & 75°F
  • Colder use SAE 10 oil.
  • Warmer use SAE 40 oil.
3. Replace oil cap at once. Tighten oil cap firmly for a good seal. This will avoid oil seepage from tank.
4. Wipe off excess oil.
  • It is normal for oil to seep when saw is not in use.
  • Empty oil tank after each use to prevent seepage.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 30, 2010 | Remington Polesaw Wizard
What kind of chain oil to use for a 10in remington electric
According to the manufacturer... "Use SAE 30 motor oil for best results. (For temperatures below 30° F, use SAE 10. For temperatures above 75° F, use SAE 40.) DO NOT use Bar & Chain oil." So, I suggest for any Remington electric chains saw not to use bar and chain oil. I hope this helps...
Jun 25, 2009 | Remington Electric Pole Saw
Remington Pole Saw Model # 106890-020 - Chain Oil Cap broke
Call Master Parts at 1-800-446-1446, or go online at www.masterparts.net. They have the part (107512-01) you need. I hope this helps...
Apr 26, 2009 | Remington Electric Pole Saw
What type of oil do I use for a Remington Electric Pole Saw?
While Bar Chain oil will probably work, the owners manual (sitting in front of me) on page 9 says to "use SAE #30 motor oil". This is the owners manual for Models: M12510US, M15012US, M15014US, M15014AS, M30016US, M30016AS, M30016AW, M35016UW, M35016AW. Remington Electric Chain Saw
Mar 13, 2009 | Remington 16" Electric Chain Saw
Remington Pole Saw
go to www.desatech.com that what i found my manual it the same one you have
Sep 07, 2008 | Remington Polesaw Wizard
Remington Electric Chain Saw  Logo
551 people viewed this question
Top Remington Garden Experts
Phil Walker
Phil Walker
roeb
Are you a Remington Garden Expert? Answer questions, earn points and help others
