Question about Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan P2316 chain saw. The chain got stuck in a tree. After freeing it, the clutch appears to be locked up. The chain moves freely on the bar when I remove it from the saw. Thanks Alan
Chain wont move while motor running
Posted on Aug 17, 2011
    Brigadier General:
  • 4,088 Answers
Make sure the chain brake isn't set. When you turn the clutch outer drum, does it try to turn the engine as well? If so, try oiling the bearing that allows the outer drum to turn over the inner section, and work the oil into the bearing. If no help, you will need to replace the clutch. It is held to the shaft with left-hand-threads and usually requires a special tool to remove it, plus the upper cylinder needs to be stuffed with starter cord so that the piston cannot rise much above the upper part of the exhaust port while trying to remove the clutch. Don't try to remove it with an impact wrench as that will shear the flywheel key. Hope this helps!
Posted on Jul 14, 2010
My remington electric chainsaw 3.0 is not cutting and making a high pitch screech when i go to cut with it
Hello. Please make sure the saw brake is not set. This locks the blade so it cannot spin. If it is locked then if you try to rev the saw, the blade cannot turn and the clutch will scream. The other thing it could be is it sounds like the chain is out of the groove and the clutch is slipping BAD. UNPLUG the chainsaw. Check to make sure the chain turns freely around the cutter bar. If it does not move at all, you will need to closely examine the cutter bar to see if it has 'popped' out of the guide path. You must also make sure the chain is on the drive gear correctly.
These are 2 things to look at that can help you. Hope this helps..
Nov 04, 2012 | Remington Garden
Chain doesn't move
Sounds like the clutch is slipping due to oil collected on the inside of the clutch drum. Wash out the entire clutch assembly with spray carburetor cleaner and let dry. Make sure the chain can be turned freely by hand, but the chain doesn't droop from the lower bar edge. Hope this helps!
May 26, 2010 | Poulan Pro Chain Saw 46cc 20"
Chain and sprocket won't move. Poulan P4018WT
Poulan P4018WT Gas Saw Type 2 link below (may not be your saw - 5 to choose from):
http://www.ordertree.com/modelinfo/PWE/P4018WT-Gas-Saw-Type-1/75.P4018WT-Gas-Saw-Type-1.1.59.1.html
It has an inboard clutch. If this is your saw remove the clutch cover, bar,
chain and inspect the chain brake linkage within. Is the brake band tight against the clutch drum? If yes grasp the forward most upper handle and pull it aft (may require some force at rear extreme) until it clicks (a keeper nests in a detent). Is there a little clearance between the brake band and clutch drum? Can you spin the clutch drum now? If yes reassemble your saw.
http://www.fixya.com/support/r4146814-chainsaw_chain_installation
If not post back please.
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Mar 19, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
The chain wont grab on the clutch bell
What are the symptoms? stuck & not moveing? Engine runs freely but chain dont turn? Tell me more. Just for the heck of it make sure the chains going in the right direction around the bar.
Mar 04, 2010 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Chain will not move freely. When hitting gas will
Did anyone explain how a chain brake works?
Pull the forward most handle as far aft as possible. It should click if it was tripped. Wearing gloves can you easily rotate the chain?
Remove the clutch cover. If it seems stuck the chain brake is tripped do not force it off, reset the brake. Inspect all interior parts for small twigs or pieces of tree that have jammed the brake or clutch. Anything beyond this please see the dealer that sold it to you. HTH
Lou
Oct 24, 2009 | Husqvarna Garden
It seems like the chain is not getting any oil earlier in the day the saw was fine. I had to replace the chain and started sawing on a tree and the chain just smoking and burning the wood. It does not look...
Are you using any oil in the oil resivour? The oil lubricates the chain on the bar. I would guess that you installed the chain backwards. If the chain moves freely on the bar it is getting lubrication. I have made that mistake before. check rotation and your new chain. Don't know what brand of chain saw you have, automatic oiler, manual oiler, ect. but would guess that the problem is with the chain itself. Hope it as simple as that.
Aug 23, 2009 | Poulan Garden
Saw starts but blade wont turn
The chain must be free to move by hand--adjust as necessary. It could be that it is not being oiled properly. The chain sprocket (gear) is part of the clutch assembly and probably needs to be replaced if the chain is moving freely. The internal component of the clutch must be firmly attached to the engine crankshaft.
Jul 02, 2009 | Garden
Poulan Pro 42CC 2 Cycle Chainsaw, 18" Logo
345 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
roeb
Are you a Poulan Garden Expert? Answer questions, earn points and help others
