Question about Casio Waveceptor WVA104HA-1AV Wrist Watch
My Casio 3053 has reset to 01/01/2005 no radio signal. Have set it on rc! a couple of times and although the icon builds correctly nothing happens in the end. Otherwise appears to be the usual amount of battery power.
I can't find a solution to this problem and have the same problem despite trying a number of reset options, do Casio have a solution?
Posted on Jan 12, 2011
You need to also set home country since that defaults back to Japan so won't synch. Then manual synch. Use manual. What causes it I don't know but my partners watch and mine both do this.
Posted on Oct 12, 2015
Can you send me instructions on how to set the time and date on my boss's E. Howard & Co. accurate radio controlled watch? Thanks!
the maker claims setting to be automatic!
The signals for Casio watches are sent out during the night, so I would assume that your watch will be the same.
Do nothing and wait till tommorow!
If nothing happens, then go to http://www.lacrossetechnology.com/support/manuals.php and select the manual from the list.
Mar 22, 2011 | La Crosse Technology E. Howard Ambassador...
I have a wave ceptor casio 4774 watch - looks great etc. Only problem is that I work in middle east and it does not correct itself so I am having problems constantly resetting the time. The casio watch...
Nothing you can do. Where you work (middle east) there is no time signal radio station for your (radio controlled) wave ceptor watch.
You can read more here:
http://en.wikipedia.org/wiki/Casio_Wave_Ceptor
Feb 19, 2011 | Casio G-Shock GW500A-1V Wrist Watch
I attempted to adjust the time of my WaveCeptor while out of the country and as a result it is now permanently 1:23 minutes behind PMT. The little LCD windopw shows the correct time, though. I've tried the...
This watch will set itself at specific time set times, this is likely to be at 0200 0400 and 0600.
You will however be required to set the time zone, the switch is likely to be on the back.
INFO:
Atomic Time Synchronisation:
How does it work.
SHORT VERSION:
Radio set clocks and watches receive a 60-kilohertz, radio signal from the NIST the official timekeeper for the US and is located in Boulder, Colorado. Ft. Collins. they use atomic clocks and transmits this official time via high frequency short-wave and low frequency AM radio signals, satellite transmission, Internet, and via telephone.
RECOMENDATION:
You are likely out of range.
Adjust your time manually using the official time link below.
COPY OF YOUR MANUAL:
http://world.casio.com/wat/download/en/manual/
REFERANCE LINKS:
OFFICAL TIME:
http://www.time.gov/timezone.cgi?Eastern/d/-5/java
PHOTO OF ANTANA TRANSMITTERS:
http://tf.nist.gov/stations/wwvb.htm
R/
David
http://antiqueclock.clockstop.com/
Mar 11, 2010 | Watches
My Casio waveceptor tough solar watch will not pick up its signal
You may have wrong manual. Follow this link and find correct one:
Rate me, please.
Jul 28, 2009 | Casio Watches
Reset itslelf. WIll not display correct time, day, or year
My Casio wave ceptor keep resetting itself like this when the bottom right (D button) is pressed. I need to make sure I reset the city code or before trying to receive as it defaults to Tokyo. Press & hold the top left (A button) and date changes to city code. Scrole through codes using right bottons.
Hope this helps.
Nick
May 29, 2009 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Reset the time on my Casio GW300
When out of broadcast range for a time signal, the online manual procedure works for me: http://www2.casio.co.jp/manual_pdf/wat/en/pdf_search.php?MODULE=2608&submit.x=39&submit.y=11
Jan 03, 2009 | Casio G-Shock GW300CA-1V Wrist Watch
Resetting
Visit:
world.casio.com/wat/download/en/manual/ - 23k - Cached - Similar pages
Download your manual.
Dec 21, 2008 | Casio Atomic Timekeeping Waveceptor Watch...
Casio Wave Ceptor #3054
I have the same watch and thought I had the same problem. Casio's website actually DOES have the downloadable manual for this watch in their Support section, though it's kind of burried in their "Watch Manual Archives" section. Try to copy this address into your browser: http://world.casio.com/wat/download/en/manual/ FYI, the manual number you'll need to search for is shown in a rectangle on the back of the watch. In my case it was # 3054. When I downloaded the manual and read it, I learned how to confirm auto-updating is activated, and how to do manual updating. In my case, I was trying it from too far inside my house with a weak signal. When I set all of the settings as described and placed the watch in the window with 12:00 pointing outside as shown in their diagrams, the manual update feature worked like a champ. I also learned about a couple of other neat features hidden in the watch. Too bad the manual didn't come with the watch when I bought it; it would have saved me lots of frustration. Hope this helps you!
Jun 12, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Wave ceptor
Check to see if the watch is set up to get its time from another country. You may find that the fault started with a battery change or an all reset of the watch. The default location for many of these models is for North America or Asia. In some models the location is not active until it is set. In different parts of the world, they are using different time set protocols. There are some technical reasons for this.
Check the instructions about setting the time zone for the watch. Pay particular attention to the time zone setting, location setting, and that the feature is turned on in the first place.
Jerry G.
Apr 08, 2008 | Casio Wave Ceptor WV57HA-1AV Wrist Watch
Casio Waveceptor WVA104HA-1AV Wrist Watch Logo
1,717 people viewed this question
Top Casio Watches Experts
Kazim ERGUNEY
Kazim ERGUNEY
Jimmy Accardi
Are you a Casio Watch Expert? Answer questions, earn points and help others
