Question about Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
Not getting the cold it needed - Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator
  • 327 Answers
Hi, both compartment of the refrigerator (freezer & fridge) not freezing and getting cold means you have low or empty freon (gas) in the compressor of the refrigerator and you need to refill it as soon as possible.
Take care
Posted on Jul 14, 2010
Why does cold water mix with the hot when the switch is set on hot
Depending on the age of the unit you may be looking at a faulty switch. Sometimes the contacts for the cold water solonoid on the switch may be fused shut and therefore you will always get cold water no mater what you select. If hot water is what you need the easy way to do this is select hot water and close the tap for the cold water until needed again. Hope this helps
Sep 06, 2012 | Admiral AW22 Top Load Washer
My air condition is not getting cold it turns on but it doesn't get cold
you need to charge the a/c unit. you can purchase a charge kit from your local auto parts store for around 30$ just follow the instructions on the can and you should be up and running withing a few minutes
Mar 21, 2012 | Kia Sorento Cars & Trucks
Can you exchange a 450cca battery for a 500a cca battery
Yes! If the question is can I replace my 450 with a 500cca battery. The more the better. CCA means cold cranking amps so it will perform better in the cold than a 450CCA. The higher the number means you will have more cold cranking capabilities in colder weather. The voltages are the same.
Sep 23, 2011 | 2004 Chevrolet Silverado 3500
Does the Indesit model No W113 have to have hot and cold water intake or can I blank off the hot water intake?
In two words- NO and NO! No, you need it to be cold fill only (presumably) and No, you do not need to blank off the hot water intake.
You will need to purchase, from a hardware (?) store, a 'Y' adapter. Upside down the single end screws onto the cold water supply and the hot and cold was pipes from the washer screw onto the double end. The washer is fooled into thinking it has hot and cold! When it expects hot, it opens its hot valve but instead gets the cold water and has to heat it up. It will therefore take longer for the machine to do the washing. When it wants cold for rinses, it opens its cold valve and gets the same water! Simple ;-0)
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck,
John C
May 12, 2011 | Indesit Washing Machines
Could you catch a cold while sleeping on a matress on the tiles
Hi.
If you sleep with dust on the tiles, then yes.
It is recomended to sweep it first or vacuum clean it. A cold may be an alergy from any dust sticking on your matress or body freezing and warming at the same time..
Before you get a cold, you will feel a certain irritation while swallowing your saliva, that is a sign of a cold infection in your system.
- you need to make a hot tea, squeeze half a lemon, pour in the tea. break half paracetamol and drink it.
For sure the cold will vanish in no time.
Take care.
-avoid dust
-avoid swift changes of temperature environment.
Feb 07, 2011 | Health & Beauty
Not getting cold water
As long as the water valve is turned on.....most likely you need a new water control valve. This valve turns on the cold water for cold, the hot water for hot or both hot and cold for warm water cycles. About $100 or less parts and labor to fix. Or if your inclined you can get the part yourself and replace it....not to much trouble. You can get a generic valve for $15 to $20
Oct 17, 2009 | Maytag LAT3600A Top Load Washer
Fridge won't get cold
Check to make sure that the fan in the freezer is running whenever the compressor turns on to cool the unit down. If the fan's not going, warmer moist air from the fridge will make the air duct frost up. The fan needs to be running to blow the cold air into the fridge section.
Apr 28, 2009 | Refrigerators
Won't start when cold
Check the Cold Cranking Amps on the Battery that you have. Normally the Cheaper the Battery the Lower the Cold Cranking Amps. I Recommend getting an "Interstate Battery" . It costs a Little more But has a Warranty and the Cold Cranking Amps that you need. They have never let me Down!
Jan 21, 2009 | 2003 Volkswagen Passat
Washer is using hot water on the cold/cold was
Unless your hoses are reversed the machine control is bad and needs to be replaced. Please contact me if you need further help or leave feedback if appropriate as that is how I get paid. Thanks for letting me help you!
Nov 30, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore 55612 / 55614 / 5561 / 655619 Side by Side Refrigerator Logo
126 people viewed this question
Top Kenmore Refrigerators Experts
Sal DeAngelo
dweatherby
paulcarew
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
