Question about GE WBSR3140DW Top Load Washer
It sounds like your water system might need some filter housings installed?-- are there any filter housings in any of your water systems?-- If so, what are they accumulating-- what do you find, when you change filters.
Write back what you are finding.. If you have no filters, then let's install either ONE on your common cold water supply to the house-- or start with two at your washing machine. Which would be easier?- Write back-- Mack Baxter
Posted on Nov 04, 2017
SOURCE: GE Washing Machine
Sounds like you have a bad fill valve on the cold water side. If your hoses are not clogged, then remove the hose and check the cold water inlet going into the machine for clogs. There is a screen that can trap mineral deposits and/or rust. If you have well water or hard water, they can become clogged easily. Sometimes you can clean them out and they will work just fine. Most of the time, however, you will need to replace the fill valve. Make sure you unplug the machine and turn the water off. The valves are electronically controlled. I hope this helps.
Posted on Apr 29, 2007
I dont kow what you mean about a spinner? If your talking about the part in the middle thats caled a agitator. If your washer is the model with the plastic tub the agitator pulls up from the bottom. And I have to tell you it is not a easy thing to pull out. The hard gritty substance could be from your water. You might want to have your water checked. Hope this helps you.
Posted on Jul 13, 2007
SOURCE: Hot water continues to run after rinse, filling tub overflowing
sounds like you are right the water inlet solenoid on the hot side is sticking remove the hoses and clean th escreen out and the valve try agin with a fill on hot to see if it stops on a small load if not replace the water inlet valve
Posted on Mar 15, 2008
SOURCE: Cold water is slow when filling for rinse cycle
Turn off the cold water.
Remove the cold water hose from the machine.
Look inside the cold water inlet on the machine and clean the debris from the screen.
Problem solved.
Posted on Feb 22, 2009
SOURCE: Wahing machine overflowing
Water does not enter the pressure hose, air does.
Remove the plastic tube from the air dome on the side of the washer. Use a small piece of wire and clean the soap scum out of the air dome hole. Blow through the plastic tube to hear the water level switch click.
Inspect the plastic tube for a hole or pinched.
If these steps do not work replace the water level switch.
Posted on Mar 24, 2009
May 30, 2013 | Washing Machines
Sep 14, 2011 | GE Washing Machines
Jun 19, 2010 | Kenmore 24032\24036 Top Load Washer
Mar 13, 2010 | Crosley Washing Machines
Mar 04, 2010 | Bosch Washing Machines
Sep 26, 2009 | Washing Machines
Jun 19, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Sep 10, 2008 | Frigidaire CWS3600AS Top Load Washer
Aug 12, 2008 | Frigidaire Washing Machines
Mar 01, 2007 | GE WHRE5260E Top Load Washer
42 people viewed this question
