Question about ASUS Eee PC 1000H Laptop
Cam - ASUS Eee PC 1000H Laptop
    Problem Solver:
  • 6 Answers
Your question please.
Posted on Jul 25, 2010
Right head cam seized up
overhead cam heads do not usually have cam bearings. If your cam has seized, it properly damaged the cam journals. Your heads might have removable cam journals, but not likely.
If you need further help, reach me via phone at https://www.6ya.com/expert/david_f2436a37cbb50365
Jan 06, 2014 | 1994 Nissan Pathfinder
We removed the cam and did not pay attention to timing marks. the engine was rotated without cam in it. How do we set the timing?
Take the cam out and put the piston at TDC
Look at the cam with the cam gear facing you.
Turn the cam until both lobes are down(on the bottom of the cam)
Look at the cam gear, there should be 2 marks across from each other at 3 o'clock and 9 o'clock
Those marks need to be parellel to the head when you set the cam in the head, carefully place the timing chain around the cam gear, trying not to move the cam.
Once you have the chain on, push the cam down in its slots in the head and look ate the timing marks on the cam gear.
They should be parellel with the head, and straight across from each other.
Recheck that the piston hasn't moved and your still on TDC.
If all is good put the rockers/valve cover on and timing chain tensioner in. Tighten the cover to specs then adjust your valve clearances to specs and your done with the timing.
Nov 29, 2010 | kawasaki KLX 125 Motorcycles
Machine Elna Supermatic 722010 When I sew with a single cam all works properly the problem comes with any twin cam, the upper cam follower has a spring holding it away from the cam, how do I get the upper...
tally_girl_2.jpg I don't suppose it would be so simple as setting the wheel inside the elnagraph to "A" to engage the automatic stitches? I've done it myself once or twice LOL.
Mar 29, 2010 | Elna Heirloom Edition 6005
2006 rmz250 When I torgue the cam bearing
Are you CERTAIN the two cams have not been switched? Chances are there will be the letter "E" on the side of the exhaust cam gear and/or an "I" on the intake cam. The diagram below is for a WR250. I don't have a manual for an rmz250. Your cams are probably the same. Note that the caps should tighten to only 7.2 Ft lbs. (10nm / 1.0 m-kg ). Many other things could be wrong. Was the cam assembly removed incorrectly? Doing it incorrectly can damage the cam, cam caps and cylinder head. Is the cam runout out of specifications ( .0012 )? Are you using a standard torque pattern? ( Cris-cross from inside to outside ) for installing. The reverse when dis-assembling. It may be best to let the shop figure out the problem and do the repair on this one.
Feb 19, 2010 | 2005 Suzuki RM-Z 250
Black cam no number M/N Cam IV
go to cam company's website.. there u enter sr no. of ur cam... and istall drivers. ok
Sep 04, 2009 | Ezonics EZCam III Webcam
I have web cam model vf0040 it's green light is on but i can't invite icant see the picture
down load split usb cam from the site i give below
http://www.giveawayoftheday.com/freeware/usb/webcam-driver
run it, then restart your computer, connect your cam open usb cam, to pc . open split usb cam in programme , open the icon , in all cam list choose usb cam and start ,you shall see your cam working.
thank you,
domnickr
Aug 18, 2009 | Computers & Internet
Free download creative web cam software model no VF0330
plz help me to install my web cam as i lost my installation cd . creative web cam model no vf0330 as this is very good canera. Please tell me who has got it and will send the software to me
Aug 13, 2009 | Creative Labs Live! Cam Notebook Pro...
Back cam will not rotate
oops sounds like you had the cam in the wrong place and bent a valve or two unless u mixed the cam caps and have them in the wrong spot that will bind the cam and lock it down by the way that is a dodge engine same as a neon
May 06, 2009 | 1996 Mitsubishi Eclipse
PC Cam 300 and PC Cam 600
Probably the driver isn't installed properly. Try updating the driver for PC-CAM 300 and PC-CAM 600.
Sep 12, 2005 | Creative Labs PC-Cam 300 Digital Camera
ASUS Eee PC 1000H Laptop Logo
Top ASUS Computers & Internet Experts
Alun Cox
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
