Question about Polaroid FLM-3734B 37 in. LCD HDTV
Takes a long time to turn on. and sound humms for
Takes a long time to turn on. and sound humms for 15 min before comming in normal
  • 11,361 Answers
Look at the power supply for bad caps with leaking/bulging top, and check the CAPS' ESR with meter since cap can look OK but can have high ESR (Equivalent Series Resistance).
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 14, 2010
Tv no turning on straight away
The clicking is the relay the set uses--likely bad filter caps in power supply and here is what to look for:
Dec 03, 2012 | Televison & Video
Front loader machine stuck before spin cycle
This is an issue with the pressure switch, it is having issues detecting the water level.
Mar 11, 2012 | LG Washing Machines
When i switch my garmin 200w on it takes 15-20 mins to find satellites any ideas on how to fix this problem
first time, when you turn on your GPS in new position, it's normal. but if second time turn on, it still be same thing, that's problem. please make every setting back default to test
Mar 18, 2011 | Garmin nuvi 255W GPS Receiver
I have 17 inc lcd viewsonic and the monitor gets start in 15 mins. that means it takes 15 min. time to display. pls pls pls send me the solution ankiiunique@gmail.com
It sounds as if you have a blown capacitor somewhere withing the monitor's power supply. A general electronics repair shop should be able to identify and replace the broken component.colinu.jpg
Mar 03, 2011 | Computers & Internet
My 37" LCD takes ~ 15 min to sync and display an
Tv power supply board is this tv problems and causes 90-95% of the times.5% maybe it is the tv Tuner signal board,but very low possibility.The power supply board,that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
Feb 17, 2011 | Audiovox fpe 3207 32 in. LCD Television
On start sometime it takes much time almost 8 15 min. after start it takes almost 2 min to explore any programe and this it work normal
Remove all the garbage from your startup menu. Delete any unnecessary fonts from the font library. Change any wallpaper to a plain colour and reduce the number of icons on your desktop.
Jun 12, 2010 | Computers & Internet
Acoustimass Subwoofer has a low "hummm" sound when turned on.
Sounds like an inadequate ground wire in the signal cable. You may have to replace the cable between the reciever and bass module. It also, however, may be IN the bass or reciever module.
Aug 04, 2008 | Bose Acoustimass 15 System
Scrambling for first 15 mins
That is the exact problem I am currently having with my toshiba 50 in. I did some reading and it sounds like there is a temperature drift across one of the capacitors on the board and it takes longer and longer to warm up. Havent fixed it yet...
Mar 18, 2007 | Toshiba TP50H50 50" Rear Projection...
Humming and popping but only at first
Try going through this troubleshooting procedure site first: http://logitech-en-amr.custhelp.com/cgi-bin/logitech_en_amr.cfg/php/enduser/std_adp.php?p_faqid=10&p_created=1083625594&p_sid=5*uWZ8vi&p_accessibility=0&p_lva=&p_sp=cF9zcmNoPTEmcF9zb3J0X2J5PSZwX2dyaWRzb3J0PSZwX3Jvd19jbnQ9NzgmcF9wcm9kcz04NDQsMTcmcF9jYXRzPSZwX3B2PTIuMTcmcF9jdj0mcF9zZWFyY2hfdHlwZT1hbnN3ZXJzLnNlYXJjaF9ubCZwX3BhZ2U9Mg**&p_li=&p_topview=1 If you get no solution from this, there are other similar logitech speaker systems that have had similar problems on initial models. Although none appear to be from the z-2300 it appears that logitech have been very helpful with replacing speakers in the past if design is faulty. Give them a try.
Feb 25, 2007 | Logitech Z-2300 Computer Speakers
Polaroid FLM-3734B 37 in. LCD HDTV Logo
104 people viewed this question
Top Polaroid Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Polaroid Televison and Video Expert? Answer questions, earn points and help others
