Question about Nikon N70 35mm SLR Camera
Photos are coming out foggy.
My nikon n70 works fine, but the pictures are coming out looking cloudy or foggy. Is there a chance of a light leak, or is it something that I could be doing wrong?
  • dam1owh Jun 03, 2008
    I have a similar problem with a Nikon Pronea 6i which is very like your N70 except that it takes APS film (What's that?)
    Assuming you have eliminated the possibility of light leaking in
    through the film back then chances are your problem is the same as mine.
    I have traced my problem to light leaking in through the viewfinder and spilling onto the film "around the mirror".
    I find that if I fire off 2 or 3 shots in quick succession, only the first shot is noticeably affected by the leak.
    I think this shows that the effect of the leak builds up while the part
    of the film at the is in position at the focal plane waiting to be
    exposed.
    The longer I wait between shots the worse the leak appears to be and
    again I think this shows that the fogging takes time to build up.
    I traced the source of the problem as follows:
    1. Remove lens.
    2. Set camera to Manual and BULB
    press and HOLD the shutter so that the mirror locks up
    3. Shine a high intensity LED torch in at the view finder
    4. Look into the camera body.
    5. Turn the torch ON and OFF a few times.
    If your problem is the same as mine you will see small pin-***** size
    rays of light appearing around the mirror as it sits in the locked up
    position. Sitting in a darkened room will help here but will also raise
    some comments from your partner or strange looks from your cat.
    My reasoning is, if the light leaks around the mirror when locked up
    then the chances are it will also leak while the mirror is covering the
    film in the normal position.
    Sorry I don't have a fix for this. I only finished 'diagnosing' the problem last night.
    I think paying to have the N70 repaired would be worthwhile as it is a
    very good camera. I'm not sure yet if I will pay good money to have the
    pronea repaired.
    If you want to do it yourself then Jon Goodman has some very good
    information and products for repairing light seals on older cameras at:
    http://www.kyphoto.com/classics/sealrepl...
    Maybe there will be enough information there to get you going.
    Good luck.
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Nikon Master
  • 102,366 Answers
It could be. One way to attempt to find out would be to take a picture with the lens cap on. You'll have to go to Manual mode and take a guess as to the exposure. I would also investigate the possibility of a dirty lens. If you have another lens, try that and see what the pictures look like.
I assume you're not using expired film, nor subjecting the film to extreme heat or humidity.
Posted on Jan 16, 2010
Good evening. I have a camera CoolPix S10 which takes beautiful photos. But when I photograph an orignal oil painting, the photos are kind of foggy and the colors are dull. What kind of settings do I...
If you are taking the photo inside with artificial lighting then this will affect the colors.
Try taking the photo of the painting with outside lighting.
Apr 10, 2012 | Nikon COOLPIX S10 Digital Camera
I am using Nikon Transfer on my Macbook Air with my Nikon D3100. The software on teh PC says, 151 photos selected and transfer successful however i cannot see any of the photos in the provided default...
Pictures are normally stored in:
~\Pictures
Option 1:
Nikon Transfer stores the pictures in a user selected folder. To fine it, look: http://support.nikonusa.com/app/answers/detail/a_id/266/kw/Nikon%20Transfer
Option 2:
1. Remove Nikon Transfer 2. Have iPhoto import the images into the iPhoto library (~\Pictures)
Jun 27, 2011 | Nikon D3100 Digital Camera
I'm using my Nikon coolpix 8700 to take photos of museum objects so the photos need to be of a fairly high standard, but the photos are coming out just slightly out of focus. Where am I going wrong? Thanks
If these are close up photos, the depth of field will be shallow. You need to raise the ISO to force the camera to close down the aperture and increase the depth of field. Also, the use of a tripod or monopod will greatly increase your chances of taking a sharp picture.
May 17, 2010 | Nikon Coolpix 8700 Digital Camera
WS-55809 cloudy foggy picture
Check the EHT splitter assembly, this feeds the focus grids on the output tubes.
BE CAREFUL as there is more than 25kVolts there!
Apr 23, 2017 | Mitsubishi WS-55809 55" Rear Projection...
We have a Magnavox Model 55P8288A Projection tv and it is showing a cloudy and light picture.. Try to adjust color and it won't adjust...It shows a foggy picture...
Replace the CRT coolant. You can get the phillips CRT coolant replacement kit at the following link. The kit contains the coolant and the CD with instructions.
http://servicemanuals.vstore.ca/
Sep 22, 2009 | Televison & Video
Better photos in florescent lighting
You need to adjust the white balance setting.
This is on the shooting menu.
The options on the white balance presets are.
Flash, Cloudy, Daylight, Fluorescent, Incandescent
Fluorescent is what you are looking for.
Remember to change it back to auto for outdoor shoting.
Jul 20, 2009 | Nikon Coolpix S560 Digital Camera
Cloudy Glasses
The problem is hard water and jet dry will not solve that. There is a new product out called The Dishwasher Filtration System. It filters the water going into your dishwasher leaving your dishes spot free with every load. It is very affordable and fits right under the sink. You will be amazed how sparkling your dishes look just after one load. You will love this product. Get it at www.dishwasherfilter.com.
Jun 01, 2009 | Dishwashers
Pictures overexposed in daylight, visible lines in photos
1. Adjust ISO or ASA 100
2. Adjust AWB Indoor florescent or Bulb while outdoor select sunny or foggy it depends of the place
Dec 25, 2007 | Panasonic Lumix DMC-TZ1 Digital Camera
High Flash Resolution
You are shooting with the exposure bias set too far on the plus side, not familiar with the 550, do You have the user manual? If You look at exif data of posted photos, You will see that many are taken at settings below the midpoint. If You don't have a manual, go to the Olympus website, many manuals are available for download. You may also find the function in the menu based on sunny, cloudy, etc, this is important to set right
Sep 12, 2005 | Olympus Camedia D-550 Zoom Digital Camera
Nikon N70 35mm SLR Camera Logo
138 people viewed this question
Top Nikon Photography Experts
pontelemon
pontelemon
michael galang
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Nikon Photography Expert? Answer questions, earn points and help others
