Question about Sharp AR-5316 Advanced Digital Imager Copier
A copier model sf 2220 shows F2 pls what can i do to that?
  • 26 Answers
you have not installed the developer (it's a steel-colored envelope that must be purchased separately if not included in installation). To do this you need to remove the toner cartridge that you entered, and remove the screw with a screwdriver blue. slip off the drive containing the hopper and fill the whole bag well distributed along the developer hopper. Reinsert done this, tighten the screw and install the toner and error F2-40 is resolved. if you need instructions let me know. Hello Valerio
Posted on Jul 14, 2010
Sharp 2540 code f2
F2 mean toner not supply .Change toner chip
Jul 12, 2014 | Sharp SF 2540 Copier
No fonctions
  • F2 with sub code 00 - Toner Sensor problem, ID pattern reading error;
  • F2 with sub code 02 - Toner Motor problem, check toner dispenser motor;
  • F2 with sub code 31 - Image Density error, Check the light level or the drum surface reflectivity;
  • F2 with sub code 32 - Drum Mark sensor, missing/dislocated mark or sensor faulty. Sensor cannot scan mark properly;
  • F2 with sub code 33 - grid voltage wrong, either too high or too low;
  • F2 with sub code 35 - grid voltage correction will not work during simulation;
  • F2 with sub code 37 - drum mark sensor adjustment required.
Feb 24, 2014 | Sharp SF-2025/2030 Copier Toner Black...
After powering on, it will show F2 on the Sharp SF 2540 Copier, So please, I need a programme code to clear it or any other solutions to solve it problem
You need to take it to a Sharp technician to check machine , usually a toner issue that toner is unable to replenish in developer unit and so blows the chip on toner cartridge ,
replacing toner cartridge rarely helps
seeing as it is a deeper issue
Sep 12, 2013 | Sharp SF 2540 Copier
I have sharp AR-163 it indicate f5 error. And Sf 2030 error code f2
Ar163 F5 = Copy lamp problem.
Possible causes are:
Blown Copy Lamp
Inverter trouble (copy lamp driver module)
MCU Board failure
This is most likely to be a blown copy lamp.
Ar2030 F2 is a process control error - depending on the sub-code it could be a number of different things. Please repost with the full code.
Hope this helps.
Feb 09, 2011 | Sharp SF 2540 Copier
Olivety
F2 means that an improper cartridge has been installed. Look for the exact type that you used before and it will work.
Mar 26, 2010 | Sharp AR-5320 Black and White Copier
F2 ERROR CODE
WHEN F2 FLASHES JUST PRESS START KEY U WILL RECEIVE A SUB CODE.IF SUB CODE IS 02 THIS IS TONER SUPPLY PROBLEM IF 04 THIS IS DATA PROBLEM LIKE AS IDENTIFICATION PROBLEM MODEL ERROR TYPE ERROR.BYMIAN AKHLAQ
Oct 22, 2008 | Sharp AR-C160 Color Copier
Sharp AR-5316 Advanced Digital Imager Copier Logo
113 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
jasbo
jasbo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
