Question about Frigidaire GLEQ2152ES Electric Dryer
I bought a condo that has a stackable Fridgidare model# gleq2152es0 dryer. Upon doing a load of wash the dryer works properly for several minuetes than stops,showing an error code of 68 with the four top status lights blinking and the machine beeping.I made sure the lint trap and vent path were clear and tried to reset the control card by shutting off the breaker and trying different cycles with no luck.The e68 in the operation manual tells me a button on the front panel is stuck but I have taken apart the panel and mechanically all switches appear to be working properly.I do not have a maintenance manual so I would appreciate any insight you can give me concerning this problem. Thanks ! **** Kocher.
  • rgkocher Jul 14, 2010
    thanks! the solution was helpfiul.I thought the board was the problem but wanted assurance before spending that much money to fix it.To delve a little further ,is there a component (relay) on the board that is a common cause of this problem that can be metered for faulty operation.
  • 6,784 Answers
HI, The word stuck can be confusing. This is not exactly referring to "stuck button". This is in reference to a permanently closed circuit on that particular sector of the control board. The necessary actions are to replace the entire main control board, due to circuit damage. The part number will be 134523200
Posted on Jul 14, 2010
  • Michael Masters
    Michael Masters Jul 14, 2010
    There are relays mounted on this PCB, but due to the sealed stated of the part, It is very hard to expose such relay for testing. The relay would not necessarily be the cause of this particular error code. This is, essentially, related to the actual circuit at that particular key sector.
I have lse7806ace (stackable) and problem with water leak. I live in condo and this washer/dryer stackable in small closet. I can't reach locking tabs. This stackable is also on the pan (bottom). 'BTW,...
Remove the 2 screws which hold the lower front washer panel , lift out from the bottom and remove the panel.You can now run the machine and use a flashlight to see where the leak maybe. Usually the top tub seal under the plastic tub cover will leak. The other possibility is the main tub bearing and seal on the main tub where the transmission goes up through tub. Hope this helps.
Feb 11, 2011 | Maytag LSE7806A Top Load Stacked...
Kenmore Stackable washer/dryer Model #11088752793, won't heat
Either the elements have blown, or it could be a device called a thermal overload which has popped. (There may also be a loose wire which connects to the heating elements). Have your drier checked out by a good handyman or technician.
Best wishes,
Graemevm
Apr 18, 2010 | Kenmore 98702 Stacked Washer/Dryer
My kenmore stackable model number has been
there should be a number on the belt take it to the spares place and they should be able to match one up for you
Jul 15, 2009 | Kenmore 98702 Stacked Washer/Dryer
Turn off buzzers
I had the same problem and the buzzer was one of the worst sounds ive heard. But, I found the buzzer and turned it off for good. Open the front panel and look for a small part in between the 2 main curcuit boxes.I have a Fridgidare stackable combo FLEB8200FSO. On mine this small part is number 144547100. Look for two black wires, one goes to H and the other to C. Disconnect both wires and no more buzzer!! Good Luck
Mar 29, 2009 | Frigidaire GLEH1642DS Front Load Stacked...
Owners Manual for Sears Kenmore Stackable Washer/Dryer
how do you seperate the stackables for moving
Oct 13, 2008 | Washing Machines
Fridgidare Affinity washer door won't open after wash cycle
Try the following site for full information on unlocking Dryer -------
http://www.freepatentsonline.com/4908957.html
Sep 14, 2008 | Frigidaire Affinity ATF7000ES Front Load...
Frigidaire stackable washer-dryer
I would check the manual.
Mar 22, 2008 | Washing Machines
Fridgidare stackable washer and dryer
Why did it go in the shop anyways?Was it being painted?Ive never removed a dryer to repair it un less it was to be painted.What are you saying about red hot coil?If this is a 220Volt dryer than yes the coils get red hot,thats normal.The repairman is most likely responsible if it caught fire in any way!Sounds un believable to me.
Jan 08, 2008 | Frigidaire GLEH1642DS Front Load Stacked...
Used kenmore stackable washer and dryer P/N 145781-000A
was the machine working when you bought it? if there's 240 available, then a problem is in the machine NOT your wiring. both motors, the dryer and wash motor may be 240 volts OR 120 volts - a hot leg to ground. the feeder should be a four wire because the white is the neutral and the ground an equipment ground. at the panelbox both the equip gnd and white terminate at the neutral bus.
Sep 10, 2007 | Washing Machines
Frigidaire GLEQ2152ES Electric Dryer Logo
Top Frigidaire Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Frigidaire Dryer Expert? Answer questions, earn points and help others
