Question about Nikon Coolpix 5700 Digital Camera
The camera makes a rumbling noise when it is turned on and once had a lens error displayed but started the next time I turned it on. Can it be opened and clean some gears to make it start smoother.
    Sergeant:
    Champion:
  • 230 Answers
Hello!
If you are not that really familiar with the internal components of the camera, I suggest not to open it. There is a good chance that you might not be able to put it back or worst case scenario, you might accidentally damage other components within. Let the Pro's do the job for you. Visit your nearest camera shop and have it diagnosed. After all it might not be just the gears or mechanical parts of the camera.
Take care!
Posted on Jul 14, 2010
My camera lens won't go back in and is making weird noises.
Since you said it makes noise when you turn it on, the gear system controlling the lens might be faulty. have it checked.
Sep 16, 2009 | Panasonic Lumix DMC-FS3 Digital Camera
E18 error w/sound effects!
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ...
Here are some things that you can do to try to correct it. They only seem to work for less than 50% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jul 18, 2009 | Canon PowerShot A95 Digital Camera
Lens error, restart camera
Lens error is usually caused by mechanical faults concerning lens assembly. The lens cannot extend or retract fully, the error is detected and lens error is returned.
Sometimes this can be fixed playing with the lens during extraction or retraction to help the lens asset getting back to normal.
More often the camera lens must be disassembled and re-assembled by a technician to fix the problem.
Apr 28, 2009 | Canon PowerShot SD850 IS Digital Camera
It has a lens error. Everytime the camera is turned on it beeps and clicks constantly. It eventually shuts off after displaying "Lens error, restart camera." on the screen.
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Apr 23, 2009 | Canon PowerShot SD1100 IS Digital Camera
Canon powershot A590 displayes lens error, restart camera.
I had this problem. Nothing was lodged between the body and lens, restarting multiple times did nothing, cleaning, torquing, twisting over several days - nothing.
So, figuring "what could it hurt?" I just smacked it on the heel of my hand a couple times. Now it works.
firm percussive maintenance saves the day once again.
Dec 27, 2008 | Canon PowerShot A590 IS Digital Camera
Error C:13:10, displays ''access'', ''turn the power off and on agai
Lens jams can happen without dropping the camera. The lens motor is bad, or a grain of sand has got stuck in one of the lens cogs. Either way will need lens repair/replacement.
Nov 12, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Canon G9 dropped
I was told it happens when the battery is low
Aug 20, 2008 | Canon PowerShot G9 Digital Camera
Taking photos
Hi, I researched the Canon site and the E18 message relates to a lens issue. Your lens sounds like it's "jammed" and so the camera is displaying the error message. According to the Canon online support, the error is temporary and should go away the next time you properly turn on the camera. Howevcer, since you say it happens every time, it may be a bigger issue with the lens. There suggestion is to have it inspected by a certified repair person. This is what I got off the Canon site: Issue: Lens will not move and camera may display an E18 or "Lens" error. Solution: Possible solutions for an E18 or Lens Error message PowerShot A410 The "E18" or "Lens" error message indicates an error that involves the lens unit or lens cover. This error may appear where the lens is prevented from properly extending or retracting such as, for example, when pressure is applied to the lens or the area surrounding the lens while handling the camera. The error may also be displayed if the lens unit/camera has been subjected to an external shock, or if a foreign substance (i.e. liquid, sand, dirt) enters the camera. Solution Check the following when you operate the camera to avoid applying pressure to the lens and surrounding area: * Hold the camera so that your fingers do not touch the lens unit when you are shooting. * Make sure the camera is off before the camera is placed back in the case. Exercise caution to ensure that the camera does not accidentally power on while the camera is stored inside the case. If you cannot clear the error code by turning the camera off and then on again, or if the error code is displayed frequently, a camera malfunction may have occurred. Good luck. NewMediaMan
Jul 03, 2007 | Canon PowerShot A410 Digital Camera
EX-S500 Casio Exilim - Lens does not full extend on camera so the picture is blurr
get the new ex-600s.. my 500s's lens wont come back in either.. i got the 2 year ultra warantee this time cause they're junk cameras but it's the best compact for about a year till it breaks
Nov 12, 2006 | Casio Exilim EX-S500 Digital Camera
Nikon Coolpix 5700 Digital Camera Logo
Top Nikon Cameras Experts
Steve
Jeff Marcus
Are you a Nikon Camera Expert? Answer questions, earn points and help others
