Question about Kenmore Oasis HE 27082 Top Load Washer
Kenmore Elite Oasis HE Model #110.27087604. My washer had an error code "ld". I removed the hoses from the pump and discovered loose change in the pump that was probably jamming the impeller. I removed the coins and after fishing more coins out 3 more times the washer started giving me a "sd" code. I checked the impeller and there is definite damage to one of the wings but the others are intact. I ran it through another wash and it again stopped this time with no change in the pump. I ran it through a diagnostic test and received and error code of F32. I pressed the same button for 3 more seconds and C0 displayed and the washer started by its self for a short time the display read C1 - C7 then it stopped. I have run it through another wash cycle and everything seems fine, but at the end of the cycle an inch of water remains in the bottom of the plastic tub. Is this normal? And is it normal that a coin should get under the agitator and into the pump?What is error code F32 and what does the C0-C7 codes mean?
  • 15,935 Answers
Pressure Switch failure - remove the hose at the top of the machine, and blow in it to clear moisture/buildup.
If not - replace the Pressure switch.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 18, 2010
Ld code. It won't drain. Not the drain pump (I changed) and not clogged pipe.
Slow drain code. How high is the outlet pipe ABOVE the machine?
Jan 05, 2016 | Washing Machines
I have an kenmore elite oasis he and the washer has a code - LD. If i try to stop and start it, it just hums.
The LD means Long drain time...that error code coupled with the hum i believe something is stuck in the drain pump preventing it from turning and that is why its humming
GENE
Aug 28, 2011 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis Washer won't drain. "Ld" code during
Hi
Error code LD means long drain. This error appears when the washer takes more than 5 minutes to pump out the water till point where pressure switch resets. To resolve the issue you'll need to clean the drain hose, inspect if the drain hose is plugged. If the hose is fine, then remove the front kick panel and access the drain pump and filter, if you are unable to find the pump and filter remove the back panel as well and trace the drain hose to the bottom of the tub. There is a drain filter connected with the drain pump. It usually gets clogged, and needs to be cleaned every 6-8 months or so. The drain filter is a small white filter connected to drain pump with a hose. If it still doesn't work then you'll need to check the connections of the drain pump, check the electrical connections with a multimeter. Hope this helps... Please post back for more information.
Daniel
Nov 26, 2010 | Kenmore 4.5 cu. ft. Oasis Canyon Top Load...
I have an error code that says "LD", what does
The LD stands for Long Drain and it flashes when the water level does not change after the drain pump is on. Check to see if the drain hose or drain pump is clogged or is the drain hose situated too high.
Nov 08, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Code
Hi
Thanks for using FixYa. Error Ld means long drain and it flashes when the water level will not change even after the drain pump is on. To resolve this issue you’ll need to check the drain hose and the drain pump for any blockages. Also check if the pump is running fine. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Washing machine stops half way thru and flashes code LD?
Long Drain
Ld flashes when the water level does not change after the drain
pump is on.
Is the drain hose clogged?
Is the drain hose height greater than 96′?
Is the pump running? If not, see TEST #7, page 13.
May 06, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
What does the code Ld mean???
Ld flashes when the water level does not change after the drain pump is on. ? Is the drain hose or the drain pump clogged? ? Is the drain hose height greater than 96′?
Apr 26, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis is beeping with an error code of Ld
LD code is long drain,one of two things the drain pump is frozen and need to be replaced or there is somthing in the pump.Pull the washer away from the wall a bit and get a bunch of towels.Lean the washer back against the wall towards the middle in the back you will see the pump take it apart and find the clog.
Apr 10, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
My washer has an error code ld and it wont start or turn off i have to unplug it to turn it off now its stuck on on how do i fix it
"ld" stands for long drain. check the water pump for any obstructed items like coins, hair pins or clothing. the water pump is located in the bottom of machine in right back of stator. remove hoses and clean. also check the air dome located in bottom of basket.
May 05, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
Apr 24, 2009 | Kenmore Elite Oasis 27052 Top Load Washer
Kenmore Oasis HE 27082 Top Load Washer Logo
1,145 people viewed this question
Sal DeAngelo
fordexpert
Ed Mac
