Question about Sharp LC26SB24U 26 in. LCD TV/DVD Combo
I've only had my LCD TV for 16 months and of course now that the 1 year warranty isn't in effect the darn TV decides to break down. The TV screen is bright white with sound. What is wrong with it? :(
  • Sharp Master
  • 8,457 Answers
This problems i fix it before,it the Tuner board the main board that take the coalax signal in to get the broscast programs it dead.Tries websites like Shojimmy.com,Ebay.com to buy a refurbish Tuner board for the replacement.Will solved this problems,i experience before.
Posted on Jul 14, 2010
  • 11,361 Answers
This is very common problem with this model, failed transistor for switched 12vdc (located on the POWER SUPPLY board) for the T-CON board, you can easily check it out without spending big money for new board. Please verify that before buying the main board.
http://s807.photobucket.com/albums/yy352/budm/Sharp%20LC-26SB24U/
Here is the service manual for in depth troubleshooting.
http://elektrotanya.com/?q=showresult&megnev=sharp&megnev2=lc-26sb24u&kategoria=tv&kat2=all
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Posted on Jul 15, 2010
  • 2 more comments
  • hitide99 Sep 22, 2010
    As suggested, I replaced the failed transistor (Q413) with NTE153 and that did fix it ....for a few days, then it broke again...same problem. So I replaced the transistor again and sure enough...that fixed it. Then sure enough, it broke again.
    Oddly, I replacd the tarnsistor again, but this time with the original KTA1281 and that does not fix it. It only will work with the NTE153, but breaks afrter a few days.
    Weird problem.
  • Bud Martin
    Bud Martin Sep 22, 2010
    Did you put in with the correct pin out when you use the NTE153?
    This is the spec sheet for the KTA1281: http://www.datasheetcatalog.org/datashee... KTA1281.pdf
    Please note the E, C, and B of the KTA1281 compare to the ECG153.
    If you look at my pictures of the transistor mounting, it should be as shown in my pictures. http://s807.photobucket.com/albums/yy352... LC-26SB24U/
  • hitide99 Sep 23, 2010
    Yes, I did mount the NTE153 exactly as shown in your photo. This did fix it and it worked fine for about 5 days, then it failed with the same problem. I replaced it again with the exact fix/failure results.
    The third time, I used the KTA1281 and did consult the datasheet for proper placement, noting E,B,C, but that did not fix it at all...just a white dcreen. Then, I was wondering if I had inserted it wrong, so I put it in the other way and of course it did not work and I had a black screen.
    I don't know what is going on here. I bought my parts brand new from MCM. Thanks!
  • Bud Martin
    Bud Martin Sep 23, 2010
    You need to test the KTA1281 with the DMM to see if all the junctions are still good, also check the failed NTE153 to see which junction has gone bad. The original KT1281 in my set had Emitter to Base shorted out so it never turns on. The 12 v out put is at the Collector of the transistor, the input voltage from the power supply is fed into the Emitter of the transistor. My is still working.
My ns-lcd42hd09 insignia tv only displays the right side of the screen clearly until the tv is on for about an hour then it will display both sides correctly. Today it never cleared up, stays really dark...
Having same problem. Smacking it or applying pressure often works. Extremely annoying (inconvenient) that a nearly $1000 machine breaks down very soon after one year ( how long the warranty is, of course)
Feb 15, 2011 | Insignia 42" LCD Flat-Panel HDTV
Westinghouse tv goes to a black screen and no sound after about 1 hr. Power is still on
I had a similar problem with my Phillips 42 in. LCD HD TV.
Here's the problem. The Power Supply Board. I opened my TV up(warranty was up of course) and found several bad capacitors. Phillips and several other companies were sold capacitors that although were highly rated failed within 5 years because of a lack of preservatives. All sorts of electronic equipment is now being effected due to these defective capacitors.
Solutions?
1. Take it in and have it fixed
2. Open it up, check the board for faulty capacitors(bulged or leaking) Buy a new Power supply board and install it.
3. Remove PSB, remove faulty capacitors and replace with compatible new ones.
Hope this helps
Dec 09, 2010 | Westinghouse Electric SK-26H540S 26 in....
I have a vertical red line on 46 inch lcd it is 2 weeks out of warranty model no TOSHIBA 46 XF355DB what is best course of action thanks
I also have this problem on a set that is a year and a half old. The repair man was here yesterday with some parts that didn't fix the problem...he said the screen needs to be replaced! Luckily I bought from Costco, who extends the warranty by a year, so we won't be out any money. They will be getting back to me with what they are going to do...repair or replace...depending upon what is most cost effective for them. I will be trying to purchase extended warranty for this TV, if repaired, or new TV, if replaced. Too many horror stories out there on all brands not to.
May 16, 2010 | Toshiba 46XF550U 46 in. HDTV LCD TV
Vizio L32 stopped working.
I have seen this many times. The tv most likely has run its course. It could be the power supply or a lamp. Sounds more like a lamp, as you still have lights on your set. check around and get some prices on a lamp. you can have a local shop install it for you. or just replace the set.
May 03, 2010 | Vizio L32 32 in. LCD HDTV
Vizio 42" LCD screen is red where is should be black. It's only 3 months old!
It maybe a video board or LCD screen control problem. Best to use the warranty at this point. You shouldn't have to pay a dime for the TV breaking down this early.
Here's a link to help you get started on your warranty:
http://www.vizio.com/support/
Sep 09, 2009 | Vizio GV42L 42 in. LCD Television
16 in symphonic lcd tv wont stay on. Itcomes on for about 30 seconds then shuts off. But it will come back on by itself and do the same thing.
Solutions?
Hope this helps
Jun 27, 2009 | RCA F27450 27" TV
Vertical line on my 46" toshiba lcd tv
The only logical solution for the problems people are having for the toshiba regza's tv's is to get into a class action law suite..., they contiue to sell tv's with defective parts and refuse to help the customer that spent large cash to find out they last if your lucky 2.5 years, they are junk and anyone with one will soon find out./.......
Apr 03, 2009 | Toshiba Regza 46RV525U 46 in. LCD HDTV
Vertical line on LCD TV Panel
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
TV shuts off within 5 seconds of turning on
Solutions?
Hope this helps
Feb 15, 2008 | Sony KDF-E42A10 42 in. LCD Television
EMERSON SCREEN SPLIT
Rosey074, looks like the number for Emerson is: 1-800-256-2487.
Good luck.
Aug 25, 2007 | Emerson EWL20S5 20 in. EDTV-Ready LCD...
Sharp LC26SB24U 26 in. LCD TV/DVD Combo Logo
810 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
