Question about Canon PowerShot A520 Digital Camera
Time and date popup
When I turn the camera on it pops up the "set time and date window" and no matter what I push it doesn't change or go off the screen.
  • 477 Answers
Goto http://www.digitalcamrepair.com/self_diagnosis_page.htm
for self diagnosis.please let me help you before leaving a bad feed back.
Your control buttons are not working.
Posted on Apr 26, 2008
How to change dates on my personel computor
Click on the Date at your taskbar. When the analog clock shows up, click change date and time settings. A popup windows will appear.
Then, click change date and time, and seti it as your preferred. Click ok and it's all done.
But if you restart the laptop or pc and you date reverse back to previous one, then you need to change the CMOS Battery inside.
Generally, the battery is the flat one used in the watch but the size might be different for some model.
Aug 27, 2014 | HP Pavilion Computers & Internet
When I print photos, it doesn't show the date on the photo. Also , when I scroll down to Date/Stamp on the menu, it is always "off". And I can't change the setting. Help
You haven't said what make/model your camera is, so it is hard to advise.
Without knowing the camera, I am guessing that you may be in the wrong mode when trying to change this setting. You won't be able to change it while reviewing pictures already taken. You can only change it for pictures to be taken subsequently. Once pictures are taken, you won't be able to add the date stamp, nor remove it if it has been stamped.
It may be that it won't allow you to set this if you haven't already set the date and time in your camera. I can't see why this setting would be shown at all if it was not possible to turn it on (i.e. if your camera did not have this feature).
Nov 03, 2010 | Cameras
How do i set date and time
NOTE: NEVER EVER set the date between 7pm and 2am or you will damage the watch!! The crown is screwed down to make it waterproof. Start by unscrewing the crown by turning it counter-clockwise until it pops out slightly. That is position '1' which is used for winding. Pull it out two more clicks to position '3' and set the time by turning the crown clockwise. Turn it past midnight at which point you will see the date change and continue turning till you get to the right time. If you're setting the time to a point after noon, be sure to go all the way past 12 noon before setting the time or the date will change at noon instead of midnight. If the time is before 7pm push the crown in to position '2' and turn it to set the date. When you are finished push the crown all the way in and turn it clockwise to screw it down.
Apr 28, 2010 | Rolex Daytona 116520 Wrist Watch
How do I keep the date correct?? It alway pops up
Next time you finish setting it, press the set/ok button twice.
Apr 01, 2010 | Polaroid A500 Digital Camera
Locks onto Favorites screen at start
Please also try to upload new firmware:
Connect the camera with the computer.
Turn the camera on.
Click onto the link and follow the instructions.
http://www.kodak.com/global/mul/service/downloads/DownloadLookup.jhtml?pq-path=7546/7548&product=EKN030485
Feb 07, 2010 | Kodak EasyShare One Digital Camera
Canon A470 The date and time menu keeps popping up every time I switch on the camera despite setting the date and time.
There is another battery next the the AA battery under a little cover marked CR1220. That is the battery size. If that battery is dead, or has never been installed then every time you change the AA batteries the camera will forget the time and date. Try to get one from a specialty store that turns over its inventory quickly and you may find that you will only change this battery every 2 or 3 years.
Oct 31, 2009 | Canon PowerShot A470 Digital Camera
Set time/date on Argus APS 400
I continued to push other buttons on the camera while the date or time was flashing untill I found that the mode button made it change.
May 21, 2008 | Photography
Adjust the date on the i70
Hey Mat,
You can find your product manual here:
http://www.samsungcamera.com/popup/download.asp?prol_uid=4148&prj_uid=733
You'll find once you download the manual's pdf, it'll be on page 20 of the pdf manual. The sample is below, but it's much clearer on the pdf manual. Best of Luck!
When Using the Camera for the First Time : Setting up the Date / Time and Language
When the camera is turned on for the first time, a menu will be displayed
in the LCD monitor to set date, time and language. This menu will not be
displayed again after setting up the date, time and language. Set up the
date, time and language before using this camera.
■ Setting up the language
1. Press the [Language] menu button.
2. Select a desired language by pressing the
vertical smart button.
■ Setting up the date, time and date type
1. Press the [Date & Time] menu button.
2. Select a desired date type by pressing the
3. To change the date, select the [2008/01/01]
menu and press the vertical smart button.
4. To select Year / Month / Day and Hour :
Minute, press the horizontal smart button.
To change the numbers, press the vertical
smart button.London
● You can select any one of 22 languages. These are listed below :
- English, Korean, French, German, Spanish, Italian, S.Chinese,
T.Chinese, Japanese, Russian, Portuguese, Dutch, Danish,
Swedish, Finnish, Thai, Bahasa (Malay / Indonesian), Arabic,
Polish, Hungarian, Czech and Turkish.
● Even if the camera is restarted, the language setting will be
maintained.
Jan 07, 2008 | Samsung i70 Digital Camera
Camera will not keep date settings
I suggest u to contact the service people and they will change the internal battery to keep update with time and date. Every camera has internal small battery so has to change regularly
Dec 18, 2007 | Fuji FinePix E550 Digital Camera
Button don't work
One of the buttons is constant presset in.
Under the button is a metal membrame, sometimes it happens by to mutch force the membrame is defect, it doesn't popup again.
Try to find out witch button doesn feal good anymore, can you work without it ?(for example left macro), open camera and remove membrame.
LKet it repait by fuiji ? a least € 100,-.more than new....
Nov 12, 2007 | Fuji FinePix A310 Digital Camera
Canon PowerShot A520 Digital Camera Logo
93 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
