Question about Linksys WRT160N Wireless Router
I have a Linksys wrt160n router connected to a cable modem. I was trying to figure out why my Wii would not access the wireless internet so I went to the desktop that the router/modem are connected to and pulled up the Linksys EasyLink dashboard. I didn't change anything in there, just looked up MAC address, subnet, gateway, IP, etc. I did do a command run ipconfig/all to look at some of it, but i didn't change anything. Now my laptop (separate from desktop) and any other laptop will not connect to the wireless. what do i do?
  • 550 Answers
You will need to check the wireless settings of the router
is there any computer connected to the router ?
If yes then you can open the router set up page on that computer.
Router set up page is the page where you can check all the wireless settings of the router.
Click here for step by step instructions
Posted on Jul 14, 2010
My router is connected, but there is no internet connection.
Actually, Linksys WRT160N is meant to be used as a router not an access point. It can be but with at
Jul 26, 2011 | Linksys WRT160N Wireless Router
Hi Support team, I use Modem Motorola SB100 with Linksys WAP54G, and DLink Wireless G DWA USB Adapter to connect to Linksys WAP from my PCDesktop. Connection from the PC to Linksys is ok but can't...
peter_picasa:
You cannot use a Wireless Access Point (WAP) to connect directly to your IPS's modem. A WAP does not provide the ability to share a single IP address on the internet like a router does.
Either return the WAP for a refund and buy a wireless router or buy an Ethernet wired-only router and plug the WAP into the LAN side of that router. You would then plug the WAN side of the Ethernet wired router into your modem.
Thanks for using FixYa.
Feb 20, 2011 | Linksys Wireless-G WRT54G Router
I've got a Linksys WRT160N V2 router that stopped connecting to my modem last night. If I plug my computer directly into the modem, I can get Internet access, but if I plug the router into the computer and...
I had the same problem and found that the port was damaged and change to another port and work fine but after a few days working file it drops back again and no internet again. Tried all the other ports and no result. I found out that something is going wrong with a part in the router and when it heats up the problem repeat.
So my solution is Buy another router and my choice went to:
TP-Link TL-WR1043ND
Dec 16, 2010 | Linksys WRT160N Wireless Router
Cannot get wirelss connection through my WRT160N wireless router. Was working and now not. I can get internet connection through the LAN ports so I know that the router is working with a fixed cable
by default ip address of linksys is 192.168.1.1
to star config you need to be connected with ethernet cord rj-45
or conenct via wireless by conencting to linksys on wireless
admin user: blank
admin pws: admin
*choose a protocol on your linksys router on internect conenction type:
check isp protocol :
dhcp: needs serail number of mac address
it picks up automatic
pppoe: needs username and pws from isp
*the ip address has to be diferent from the isp modem:
isp modem 192.168.1.1 linksys 192.168.1.1 incorrect
isp modem 192.168.1.1 linksys 192.168.2.1 correct
change the ip on lan settings on your router
*wireless: ssid by default is linksys
ssid: linksys
wep : none
to setup wireless
access the wireless basic
change the ssid to any network name
enable the wireless password
choose wireless security
enable wep key 10 digit hex pws
make shure you saved settings on every setting
May 04, 2010 | Linksys WRT160N Wireless Router
Cannot connect Wii to Linksys WRT160N, Test connection is successful; however getting error code 220602 when it attempts to access the internet. Tried changing channels, manually inputting codes, disabling...
1.Unplug all off your devices starting with the wii then your linksys router.
2. On the router unplug the connections on the back ports then reconnect them "port connections first then power connections second"
3. Go to the wireless connection screen and do a network test on the Wii.
4.If that doesn't work then you have to go into the router itself through its ip address and redo the settings to make sure you have the connection to the router unblocked.
I hope that helps
Rad
Dec 06, 2009 | Linksys WRT160N Wireless Router
WAN connection problems with Linksys WRT160N
1.) Have you setup the router for use on cable modem?
2.) Run Your Setup utility that came on the CD for the router. And select Dynamic under the WAN settings unless you have a static IP address.
3.) If you do not have the CD to access the setup use IE Browser type 192.168.1.1. Select WAN settings and then Dynamic from the list.
4.) Make sure your computers are using the router and not the cable modem. Reboot your PC's and verify they work if they don't open the internet connections and view the gateway is 192.168.1.1?
Here is a link to the manual
Nov 26, 2009 | Linksys WRT160N Wireless Router
Changed my modem and now my wrt160n dosen't work
I recommend calling your ISP and have them synch your new cable modem with their connection. They may need to register the hardware address of your new modem for them to be able to recognize it and grant internet access.
Hope this helps.
Jun 25, 2009 | Linksys WRT160N Wireless Router
Vonage Phone Adapter and Motorola DSL Modem and Linksys NUltra
Your connection should be from DSL modem > internet port of Linksys router > Vonage phone adapter to port 1 of the router.
Nov 01, 2008 | Linksys WRT160N Wireless Router
Limited or no connectivity to the internet. my setup: the telephone port is approx 30m from where i need internet access. Originally I had a dlink wireless router set up but was connected via cable, now...
On which port of the D-link router did you plug the WRT160N router?
Do this setup.
Disconnect the WRT160N from D-link.
Connect a computer to port 1 of the WRT160N. Access the setup page by typing 192.168.1.1 on the address bar. you may need to type in the username and password for WRT160N. on the setup page Change the LAN IP address from 192.168.1.1 to 192.168.2.1. save the settings.
Connect a cable from port 1,2,3 or 4 of the D-link router to the Internet port of the WRT160N. turn off everything then turn them on starting from cable modem>D-link >WRT160N then computer.
You should be able to access the internet.
Oct 08, 2008 | Computers & Internet
Linksys WRT160N Wireless Router  Logo
155 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
