Question about Sharp AL 1631 Copier
Paper jamed right side of the machine , paper has jammed,how it can take
  • 26 Answers
Ciao,
aspetta che si raffreddi la copiatrice, apri lo sportellino di dx, e verifica dove si è inceppata, nel caso sia nel gruppo fusore fai attenzione alle unghiette di separazione a non danneggirle. se queste sono sporche di toner secco, rimuovilo perchè è questo che causerà ulteriori inceppamenti. spero d'esserti stato d'aiuto ciao Valerio
Posted on Jul 14, 2010
I need need a picture on how to remove a paper jam in xerox 4118 machine right now please
Well open the printer where you can(the closest point to the jammed paper) attempt to remove the jam by attempting to pull the Jamed paper in the direction it would normally exit the machine.thats about as far as I can get you with the information I have--Good Luck.
Feb 01, 2013 | Xerox WorkCentre 4118 Network Kit - 1 x...
IF PAPER HAS NOT JAMED BUT MACHINE ARE SHOW PAPER JAMED
Try cleaning the rubber paper feed rollers. If it fails to pick up the paper in a pre determined time it will show paper jam. The pick up tires must pick up paper when turning, if not the paper will not feed into the machine and it will show paper jam with no jammed paper.
Mar 16, 2011 | Canon imageRUNNER 400S Copier
Paper jams every sheet. Checked the paper weight, made sure it was faned edges and not rolled. Catches on the left side as it rools in from the drawer. What can I do to fix it. I have used it many...
Marie, there is something stuck between the paper tray and the transport section of the copier. Probably a small piece of paper. try to push a piece of paper up from the tray to the rest of the machine to push this obstructing paper out of the paper path. Also try using the handfeed section on the right hand side of the machine by folding down the tray and putting paper in it. You may have to choose this "manual" feed tray on the operation panel. Good luck !
Feb 20, 2011 | Canon imageCLASS D860 All-In-One Laser...
It says clear paper jam
what brand of fax machine do you use?
try to open the fax machine ande see if there is any paper jamed or piece of paper jamed at the sensor.
Nov 11, 2010 | Office Equipment & Supplies
My fax machine keeps jaming on the right side in the paper tray, what causese this
When it jams, does the paper get bent or crinkled? If so, there is probably something lodged in there causing the paper to stop. Could be a paperclip or staple, or maybe another piece of paper.
If there is nothing blocking the paper and it just stops feeding on one side, you may have a tension problem -- springs might be getting old and not pushing rollers together tight enough to feed the paper. If you can take the machine apart, try switching the springs around to see if that makes a difference.
May 26, 2010 | Brother IntelliFax-4100e Fax
Paper jam
Remove the paper following the procedure below.
(1) Load a single sheet of the same paper in the Auto Sheet Feeder in portrait orientation.
Do not load it in the landscape orientation.
(2) Turn off the machine.
(3) Turn on the machine.
The paper is fed and then pushes out the jammed paper as it ejects.
If you cannot remove the jammed paper or the paper jam error continues after removing the paper, contact your Canon Service representative.
James Mac
Sep 09, 2008 | Canon PIXMA MP600 all-In-One InkJet...
My epson cs7800
I had the same problem and found a small spring was loose and interfering with the paper. The Spring was on the right side as you look at the printer, near the bottom of the paper feeder. I took it out and it works fine, for now.
Jun 15, 2008 | Epson Stylus CX7800 All-In-One InkJet...
Paper Jamming
Could be a faulty roller, or jam you have not found yet. Check again with a torch right up insied unit. If no go, try uninstalling and reinstalling printer.
Jun 29, 2007 | Canon PIXMA MP150 All-In-One InkJet...
Paper jam lite-still on
If your machine is showing a jam it could be that you have a piece of paper stuck in the machine. There are many areas to check. There is a help function on the machine and it will show you all of the areas to check. Use a flashlight because there may be a small piece of paper ripped off by a sensor. I would also take out the paper trays and shine my light inside. Make sure you check the duplexor cover also. This is on the right hand side. It open up and there are blue labeled areas to check. Just take your time and systamatically check all paper jam areas and you should find it. It could be a bad sensor in which case you may have to call a repair person. Good luck http://www.tonerovernight.com
Mar 25, 2007 | Toshiba e-Studio 350 Copier
Sharp AL 1631 Copier Logo
98 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
