Question about Bosch HBL 455 Stainless Steel Electric Double Oven
The door to the lower oven on my Bosch model # HBL455A UV/01 does not close properly. Is there a way to tighten the closers to allow a more snug fit? ken_balestreri@comcast.net
  • ken_balestre Jul 14, 2010
    The door and hinge assy on my model are different than the solution you sent. Please address this particular oven.
    that helped. thanks
    Sergeant:
    Champion:
  • 230 Answers
Hello!
You try first is take the door off. Then get a big flat headed screwdriver and put it in were the hinge normally goes. Then push it towards the oven and try and bend the bottom of the hinge keeper outwards.
As sometimes if the hinge keepers worn in doing that pulls it out a bit and then you get a better fit on the hinges. Hope it helps
Take care!
Posted on Jul 14, 2010
  • 677 Answers
Hi, you can use this link a guide.
(farmfreshmeat.com/2009/10/fix-for-bosch-range-door-closing.html)
Take care.
After changing the right door hinge on my bosch hbl455auc the door closes but the upper oven door is 1/8 lower at right top than left. How can I realign the door to level?
There are adjustment screws or bolts on the hinge attachments to the oven. Loosen them and adjust the door using wedges to hold the door in place.
Jan 12, 2013 | Bosch HBL 455 Stainless Steel Electric...
Both oven doors do not close properly. lights stay on & can't heat properly with doors not closing tight. is there an adjustment for these doors?
We have similar Jen Air double oven and with the same problem but only on the lower oven. The doors are interchangeable and the top door fits fine but the lower door will not close completely at the top. It does turn out the light but has never cooked properly. I checked with several appliance repair shops and the hinges are not adjustable, but since one door closes and our other doesn't it is not a hinge problem, just a defective design.
We let this go too long and are out of warranty so I doubt Jennair is going to do anything. I hope someone post a solution but it is clearly not problem with the henges but with the receptacle they go into.
Jan 04, 2011 | Jenn-Air WW27430P Stainless Steel Electric...
Hello, I have a Bosch cooker HSF135 FEU/01 and the door do not close firmly. How can I extract and replase the hinges?
It is quite involved to ex[plain in full detail, if you go to the following site, it should help.
WWW.YOUTUBE.CO.UK
In the search box enter---
Fitting oven door hinges
there are several videos to pick from.
Hope this helps.
Feb 09, 2010 | Bosch Ovens
Bosch range outter glass shattered
You just need the glass, get part number from Bosch website (UK) and source locally.
To fit just dismantle the door.
Aug 29, 2009 | Ovens
Bosch Oven Door Problem - doesn't close at top
On our oven (Bosch Evolution 700 Series HGS7152UC), the problem was getting worse and worse. I found it is was worsening simply because the hinges had started to come loose. I removed the door as suggested above, and although there are no adjustment screws on this model I tightened the now-loose hinge mounting screws. For each hinge there are three screws altogether: two (phillips heads) on the bottom of the door and one (torx head) on the inside wall of the door. After tightening those screws it is a lot better, only leaks as much heat as it did when it was new which is tolerable. Still a bad design.
Mar 02, 2009 | Bosch HBL 742 / HBL 746 Electric Single...
Oven door isn't closed tightly on both sides.
If it is a door that lifts up and down, then the only solution is to replace both door hinges, as they are not normally adjustable, it is the springs that are weak.
Plz rate my solution.
Thanks.
Jan 05, 2009 | Dacor ECS130 Epicure Electric Single Oven
Bosch hbn41 ..43
BOSCH COOKER HBN41/43 GLASS ON INSIDE OF OVEN DOOR SLIPPED AND SMASHED
Nov 21, 2008 | Bosch HBN 9163 GB / 9163 GB hot-air Double...
Oven Door will not close properly
Don't buy Bosh. This is a common problem with them and they are not interested in a fix (ie a thinner door seal would help or adjustment to springs...
Feb 11, 2008 | Ovens
Faulty oven door
This IS SO EASY !! I have the DACOR 48...no tools, 5 minutes and you are done! It took me 8 years of frustration and I fixed it TODAY !!
Just open the door, latch the small hook that binds the two hinges together. Next try to slowly close the door until resistance. Just when you think you might break something push up another 2 inches. Now lower the door , unhook the latch to seperate the hinges (latches) nad PRESTO a snug fit !!
Dec 19, 2007 | Dacor ECS127 Epicure Stainless Steel...
Bosch HBL745A Oven door
My husband just figured this out.
- Follow Door removal instruction from the manual.
- There is a screw at the end of the hinge that can be adjusted.
- Adjust the screw to desired height.
- Secure lock nut.
Nov 14, 2007 | Bosch HBL 742 / HBL 746 Electric Single...
Bosch HBL 455 Stainless Steel Electric Double Oven Logo
122 people viewed this question
Top Bosch Ovens Experts
Oloyede Monsuru
michael_t919
Are you a Bosch Oven Expert? Answer questions, earn points and help others
