Question about Dryers
Kenmore stackable dryer. heater coil is broken. how do i replace. looks like the drum must be taken out. do i do this repair from the back.
  • Dryers Master
  • 2,605 Answers
Welcome to Fixya.
There are several versions of those Kenmore stacker machines, ( built by Whirlpool, Frigidaire, etc ) if you could provide the model number it will eliminate any possible mis-understanding on how to repair your machine.
The one thing they all have in common however is they are serviced from the front, not the back.
I`ll watch for your reply and we can move forward from there.
macmarkus :)
Posted on Jul 14, 2010
  • mickthom Jul 15, 2010
    thanks, it is made by frigidaire model #c94812-00
  • Mark MacDonald
    Mark MacDonald Jul 15, 2010
    Thanks for the reply.
    **unplug the dryer from the wall before attempting any repairs...safety first.**
    I also recommend you video this as you do it or take photos for reference to re-assemble the unit.
    To acces the heater for that machine you`ll need to remove the top panel, screws are all around. Then remove the front of the dryer, if you get up top of that thing and look down to the front you`ll see a screw on each side which must also be removed.
    The biggest challenge may be getting the front off by yourself.
    Remove the square panel just above the washer lid, and the galvanized metal panel behind it.
    Just below the control panel will be a couple of screws which must also be removed. Unplug the wiring harness which connect`s the washer & dryer to the controls and there will also be wires going to the door switch and light ( if yours has the light ) and then the entire front should come off.
    Once the front is off and out of the way, you must undo the belt & lift out the drum assembly. For the rest of the procedure, check out the link, the freestanding dryers are exactly the same apart from the front & top we covered here...
    http://www.youtube.com/watch?v=zc1sTUiYz...
    Let me know how it goes or if you need any further assistance.
    Good luck.
    macmarkus :)
Dbsr463eg7ww no heat
First check to see that the exhaust venting line is clear (not full of lint) as well as the path in the dryer to the line. This is the most common cause of no heat.
Second set the knob to heat turn on dryer with the lights off and the door open but the "open door" switch so that it still rotates with the door open. Look at the back of the rotating drum for a orange/red glow behind the drum (the heater coils). If there is no glow the heater coils are probably broken.
As the dryers age, the amount of thermal cycles the heater elements go through until the point when the coil wire breaks. There usually two heater coils behind the rotating drum (one hotter than the other and when combined the hottest heat temperature setting. You will need to pop open the top where you see the belt that turns the drum. The belt is removed from the spring loaded tensioner pulley at the base of the dryer. Then you can lift the drum out to get to the heater coils. Since no heat, both should be broken and will require replacement.
Nov 05, 2013 | GE DWSR463EG Electric Dryer
Dcvh660ghbb dryer wont heat
Sep 05, 2013 | GE Dryers
Dryer does not heat
Might be a limit or a the heater element.MY REPAIR PAGE
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Aug 15, 2012 | GE Dryers
My dryer won't heat up. where is fuse box for kenmore stackable 41794813301
Behind this drum on the upper left hand corner is the fuse
If it was tripped however the dryer would not operate as it is tied into the door switch.
You can get a restring kit for less than 20 bucks for these
Get top off then the controls off there then remove the front like this:
The heater is on the back side of the drum so it has to come on out
I did a repair on a similar dryer last year and took some photos
Nov 02, 2011 | Kenmore 98702 Stacked Washer/Dryer
It doesn't heat up and it's not the breaker.
may be heater coil, located inside machine on back right side. unplug dryer, open dryer door and remove screws, with a flat tip screw drive gently pry on each top corner till it pops off, gently move panel forward and disconnect door switch. sit panel aside, lift top all the way up it is clipped on the back so it will not fall off. look to the back and right and the coil looks like a spring, it is easy to change, all you need to do is will the make and model call a appliance store and they can tell the price for a new one. good luck tim
Sep 18, 2010 | GE DBXR463EBWW Electric Dryer
How to replace ge dryer heating element
you will need to remove the drum for this one.  once it is out, the element is mounted on the back of the unit.  not a hard repair, just lay out the parts as you take it apart to give you some order as you re-assemble it.
Aug 03, 2010 | GE Profile Wizard DPSE592EAWW Electric...
I have a Kenmore stackable washer and dryer and when ever you turn the dryer off you can hear the drum grinding I can hear pennies in it would that make a difference?
You have front felt glide kit that the drum rides on and also rear bearing in back also that drum rides in. One of these is the problem and they both have to be repaired by going thru the front not the back of the dryer.
Jan 31, 2010 | Kenmore 98702 Stacked Washer/Dryer
Dryer is tumbling but not heating
if you remove the back you will see the heater box to your right,at the top of the box is the heater fuse,also the bottom half of the box is the heater coil,it come off just remove the 2 screws,if you have a meter you can test it if not take it off and look to see if you see a broken wire anywhere,your model number is inside the door-mike
Jan 28, 2010 | Kenmore 63942 Dryer
Need to replace the heating element in stackable Kenmore model 417.98702891
Go to www.repairclinic.com and enter 417.98702891. You will be presented with a list of common replacement parts and may be able to view a generic Sears video showing disassembly with identification of various parts.
Mar 11, 2017 | Kenmore Dryers
How to install heater strip in kenmore dryer 62622
normally if its the heater is in the right side duck looking from behide there is a screw to remove slide the heater coil assy out if you have the heater on the back of the drum then the drum assy needs to come out to replace the coil to identiy if its the back of the drum heater when you open the door you shoud be able to se tru the back of the drum where all the smalls holes look with a flash light you should see the ellement ok thanks from gilles
Mar 15, 2009 | Dryers
Dryers Logo
Top Dryers Experts
Marvin
Marvin
