Question about Electrolux Epic 6500 Vacuum
Epic 6500 vac stopping for no reason
Clean bag, clean filter - Vac worked fine until this afternoon. Vac the dining room and then it started then stopped and continued to do so.
Nothing in hose, no reason that I know of for problem. Help if you can.
  • Nokaoi May 08, 2008
    Both the cord plug light is on and the ? light is on. The bag is new and the filter is clean. Neither switch (on the handle or the cannister) will turn the vacuum on...
  • BH247 Jun 10, 2008
    I have the same problem. Only this one seems to cut out when even the slightest blockage occurs. If i remove the bag and press the little button that the bag would press on, it runs fine. The second i cover the opening just a little it cuts out.
    seems like a system protection of some kind that is too sensitive at the moment.
    I've had the 6500 about 10yrs without even the slightest problem.
    - Brian
    President:
  • 1,673 Answers
Could have a problem with the cord or the motor.
Posted on Apr 20, 2008
Epic 6500 Sr. Why does it keep turning on and off?
Electrolux Epic 6500 - Bag Full Indicator Bypass - YouTube
? 0:55
https://www.youtube.com/watch?v=YrMgoUAHcI4
Jun 23, 2013 - Uploaded by easilen
The rear pops off. There's a vac. ... Yeah, keep it. Undo Close ...Electrolux Epic 6500 - Bag Full Indicator ...
Questions and Answers for Electrolux Vacuum Unit
builtinvacuum.com/help/electrolux/qanda/main-central-unit.html
For Electrolux; Central Vacuum Attachment Kits and Hose and Tool Kits for Electrolux Attachment ... With a clean bag in, the unit starts up and immediately shuts off. If you hold ... From what I have read hear, it sounds like the motor is going. ... How can I fixmy electrolux epic 6500 SR vacuum? ..... It keeps cutting off and on.
Electrolux Epic 6500 SR Shuts off when power hose ...
Dec 28, 2015 | Electrolux Vacuums
Have a 6500 epic electrolux canister vac shuts off if you restrict the hose new bag not completly
Shake the bag if you've been cleaning up "fine" carpet freshener powder, drywall dust or anything extra fine as it clogs the pours of the bag and the machine stops thinking the bag is full. If this doesn't work, you'll have to have the control valve on top cleaned or replaced to correct the issue. Hope that helps!
May 16, 2014 | Electrolux Vacuums
No vacumm pressure. the passages are clear and the motor runs but there is very little suction.
if you are certain no blockages ? and the dust collector is clear/clean ? have you checked that the outlet filter which is located inside dust compartment is clean/clear this is usually a gauze filter its purpose is - as vac works and draws dust into collector the air that is sucked up thro vac builds up in collector chamber or bag on most vacs? and so for vac to maintain suction the air has to be able to escape to atmosphere/room without dust which is left insude chamber/bag if fitted and so air escapes via the gauze vent as prev mentioned ? however if gauze filter is not clear to vent then vacuuum is restricted due to air drawn being unable to expel sometimes on vacs they will eventually cut off due to o/heat but will operate when cooled so may i suggest checking the above possibility ?
Dec 13, 2009 | Electrolux Pronto 2-In-1 Stick/Hand Vacuum...
What does the warning light with question mark mean on the Electrolux Epic 6500 SR canister?
It means to check the bag. Your bag is either missing or misaligned and has slipped past the little clear sensor or bag lockout plunger in the corner of the bag chamber at the door.
Remove the bag turn on the vac and push this switch, the vac should start when the switch is depressed. If not the internal switch inside the vac is misaligned or damaged. Please post back to confirm how you make out
Oct 13, 2009 | Electrolux Epic 6500 Vacuum
My canister machine kicks off immediately after starting and bag full light goes on but it has a new bag
hi from uk your problem with vac may be the gauze filter on the inside of the compartment that has bag this filter there to allow air from the micro pores of the bag to expel to the exterior of vac (room) whilst preventing dust from expelling too ? normally another symptom of this is the vac cover sometimes flips up ? however if air cannot expel from compartment it will cause overheat of motor resulting in auto cut off but will reset when cooled SO check the filter gauze and renew or wash clean? hope you understand above and hope this helps ?
Oct 09, 2009 | Electrolux Guardian Bagged Canister Vacuum
Kenmore upright vac model 33922 - good suction but developed loud whining noise after accidentally vacuuming room without bag. Added bag and changed both filters. Still makes noise. How can I stop noise?
The bag is the first stage in your filtration. Most times what you did will draw fine dust right through the filters and into the motor itself, affecting the bearings and clogging the motor fans, throwing them off balance.
The fact that there is a new noise would seem to indicate bearing problems which will only worsen unless the vac motor is dismantled, fans cleaned and bearings either replaced or cleaned and repacked.
Sep 14, 2009 | Kenmore 33922 Direct Drive Bagged Upright...
What size/model bags do I need for my Electrolux Epic 6500 SR vacuum?
You need an Electrolux Cannister bag to fit pre 2001 Series cannisters. You can fin them at a VAC Service center or thru AERUS Electrolux. Buy only a 4 ply bag, nothing thinner.
Sep 08, 2009 | Electrolux Epic 6500 Vacuum
Vacuum won't stay on
When you open the canister you eill see a little rubber hole that senses when your bag is full. This must be clogged. If you have another vac try to vacume all the dusr from this hole and any other opening inside the vacume that you can reach. I hope this helps. Don't forget to rate this answer.
Feb 07, 2009 | Electrolux Epic 6500 Vacuum
Vacuums Logo
135 people viewed this question
Top Electrolux Vacuums Experts
Chris Nomland
Chris Nomland
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
