I have a Panasonic portable CD player model RX-DS102 (16 years old) that cannot play certain discs without skipping repeatedly throughout certain tracks. I have thoroughly cleaned the discs and they play without any problems in my car's audio system.
  • mdblanton Apr 20, 2008
    If the lens is dusty or damaged why is it that the problem occurs only with certain discs and not with others? If the problem persists after the lens is cleaned can the lens be repaired or will the entire unit have to be replaced?
  • 13,433 Answers
The cd players lens inside the player id probably dusty and needs to be cleaned.
Or then the lens is damaged.
you will need something similiar to this
http://www.maplin.co.uk/Module.aspx?ModuleNo=27775&doy=search
Posted on Apr 20, 2008
  • Ekse Apr 20, 2008
    Are you sure its not a disc spesific problem?
    A repair tech can replace the lens in most cases.
    I dont know about cost, maybe it might be cheaper to buy a new one? Not sure check your local stores.
Repairing coby cx-cd118 cd player
hi there.
Use a lens cleaner to clean your CD player's lens properly. Unscrew the top cover of the player and locate the laser lens, which is located just adjacent to the central disc drive. ... If theCD player is still skipping after the lens has been cleaned, there is likely a hardware problem that needs to be solved.31 Mar 2015
How to Fix a CD Player That Skips ' Techwalla.com
https://www.techwalla.com/articles/how-to-fix-a-cd-player-that-skips
Why does a CD player skip?They don't scratch as easily as vinyl LPs, but I've damaged half a dozen CDs over the years. If a CD is skipping, first give it good clean using a CD wipe or mild soap and water. Dry carefully with a lint-free cloth in a straight line from the centre to the edge. Rubbing in circles can cause more damage.12 Aug 2005Buyer beware: to fix a CD that skips, first try good old soap and water ...www.telegraph.co.uk/.../Buyer-beware-to-fix-a-CD-that-skips-first-try-good-old-soap-an...Search for: Why does a CD player skip?
How do you fix a CD player that skips?Clean the CD if it skips or the player can't read it. Use a clean lint-free cotton cloth and make sure the CD is not scratched. Use a lens-cleaning CD in the player. If you can access the lens without opening the case, clean it with a cotton swab and lenscleaner.12 Jul 2010How to Troubleshoot a CD Player - YouTubehttps://www.youtube.com/watch?v=xAlPb7NBvz4Search for: How do you fix a CD player that skips?
or try this link for more help if you need it.
cd player skips Google Search
Nov 27, 2017 | Coby Lands Phones
When playing cd's the player skips and then stops when the second part of the disc is reached?
If the CD plays correctly in some other player (or in the CD-player in your vehicle), then your Panasonic CD-player is the cause of the problem. If under warranty, get it replaced. If not under warranty, purchase a replacement.
Jan 04, 2015 | Panasonic Home Theater System System
My Sony mini hifi component system is going berserk!! 2 problems: 1- CD system skips tracks and on playing on repeat song, the song skips certain times and jumps ahead of the track. 2- Tape system plays...
Your cd player is fubar and in definite need of replacement.
Tape unit seems to have a mind of its won. Try to reset the electronics to factory defaults. If that has no remedy, since it is a sony< best advise is to trash it. Repair cost is prohibitively expensive.
Sep 19, 2017 | Sony MHC-RG222 CD Shelf System
3 disc Phillips cd player sometimes skips. It is
At some time in its life, the laser that reads the CD starts to get too weak to operate reliably. That's probably what's happening here. Unlike mechanical parts that can be inspected for wear, electronic parts tend to work fine one day, then the next, poof. The laser assembly is replaceable if you can locate the part and find someone to install it. An electronic service shop could give an estimate for repair. If you can provide the full model number, I'll see if I can find the part number.
Mar 08, 2010 | Teac AD-600 3-Disc CD Changer
CD player will not play burned Cd's anymore after 5 years of work
If it has been playing CD's for over 5 years (really reliable CD player.) then I'd think it's had it's life, it needs to rest now. Meaning it's dead so you either get a replacement or a get a new CD player.
This is what happened to my mum by the way. ;)
Sep 03, 2009 | JVC XLFZ2585 Disc CD Changer CD Players
IT PLAYS TAPES SLOW
can i buy your panasonic rx-dt75. i have that model almost 15 yrs to me made in japan. but this past few months cd and tape do not work... contact me here +639392859269
Jan 06, 2009 | Panasonic Portable Radio/Cassette Player
Gpx tvp75
To repeat one track, press the REPEAT Button once while the track is playing. The REPEAT Indicator will flash
To repeat another track, press the SKIP/SEARCH DOWN or SKIP/SEARCH UP Button
To cancel Repeat One Track, press the REPEAT Button twice. The Repeat Indicator will no longer flash
To repeat the entire disc, press the REPEAT Button twice while the disc is playing. The Repeat Indicator will illuminate
To cancel Repeat All, press the REPEAT Button once. The REPEAT Indicator will no longer illuminate
Sep 16, 2008 | GPX TVP75 5 in. Portable Television
CD Player not working
i have an older machien here its a mini hifi system fw 540c it wont play any cd's i put into it it skips tru all 3 trays and than says no disc or disc not finilised. i had it in storage for about 4 months over a winter worked fime b4 can some one tell me what could help before i trow it away (>-_-)> ty<(-_-<)
Mar 04, 2008 | Teac GF-350 CD Shelf System
 Grubhead
Grubhead
