Question about Roper RAS8445KQ Top Load Washer
It will wash but not spin out the water
It will wash but not spin in any cycle
  • 166 Answers
You could have several problems, but the most common would be the lid switch. Check the lid switch by opening the lid and using a screw driver press the switch in and out. you should hear a clicking sound. if you don't hear this clicking sound your switch is bad. replace it.
(you can also check the switch with an ohm meter but you have to remove the back splash and disconnect the switch from its connector.)
If you must replace the switch there are 2 clips underneath the backsplash that hold the cabinet in place to the back of the machine. You will have to remove these clips and pull the cabinet off to get to the switch.
Posted on Jul 14, 2010
  • 1294 Answers
SOURCE: Does not Spin out the water at the end of a load
If it spins the balance is okay. Check out your filter now. And then the pump (after the spigot prob below) Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
Rate me pl.....if helped.
Posted on Jan 06, 2008
SFroese
  • 141 Answers
SOURCE: wwsr3090t8ww
It's possible that the high speed windings on the motor no longer work, or it could be the clutch.
If the motor is spinning very fast, but the tub is not spinning, then the clutch is broken. If the motor is not spinning fast, then it probably needs a new motor.
Posted on Sep 06, 2008
  • 30 Answers
SOURCE: washing cycle is ok but wont spin
check carbon brushes on motor
Posted on Jun 09, 2009
SOURCE: no wash cycle or spin cycle. it will drain the
After taking apart my machine I discovered a broken part called the Motor Coupling. This part is what makes the basket turn from the motor. I had to completey take apart the machine. The part is located between the motor and the transmission. This machine is not belt driven. It is called a direct drive. good luck
Posted on Jan 04, 2010
hh0405
  • 77 Answers
SOURCE: I have a Roper top load washing machine and the
the washer needs to have the lid closed to go into spin cycle the lid switch is broken just replace it and that will fix it
Posted on Apr 03, 2010
Why is my whirlpool auto load sensing washing machine spraying water while in final spinning cycle?
you could have a bad temperture sensor bad are water valve but first check an make sure the washer drain alway check your drain hose for clog are lint are trash in pump an last you could have a bad timer if you dont know how to check these call a applince service for repair ok
Dec 13, 2017 | Washing Machines
Water sprays into machine on spin cycle
the machine is programmed to spray water during the initial period of the spin cycle as an added method of removing any remaining suds
that stops then the spin cycle goes into high speed spin for that last few minutes
If the problem is that it continues to spray water until the spin cycle is finished it will be the program board or program controller switch
Oct 15, 2017 | Washing Machines
Please describe a typical washing cycle to me on the RTW4440XQ Roper 3.1 Cu. Ft. Top-Load Washer, please.
The typical cycle is;
fills to selected water level
agitates wash cycle
drains wash water
spins wash cycle
fills to selected water level on rinse cycle
agitates on rinse cycle
drains rinse water
spins final time
end of cycle
Aug 08, 2011 | Roper Washing Machines
Wt you mean by spin in washing machine
its a separate cycle all by itself.
Say U hand wash something in a sink and instead of wringing it out by hand U can put it in the washer and press this SPIN cycle.
So U can also use it to spin more water out of your garments after the regular wash and spin cycle.
Slower spin speeds mean -
  • Cheaper washing machines
  • Quieter washing machines
  • More stable washing machines
  • Longer lasting washing machines because there's less wear and tear on the bearings, motor, carbon brushes, suspension etc.*
  • Gentler on laundry
  • The drum spins for approx 4 or 5 mins. No water is added and you dont add detergent or fabric softener for the spin only option. The object of the exercise is to centrifugally remove excess water from the garments in the drum. They will still be damp but not sopping wet after the spin cycle
  • Spin takes the water out, extract is even better
May 17, 2011 | Frigidaire ATF6000ES Front Load Washer
Maytag Neptune TL clothes still dripping wet after full cycle
Pump out time of 40 seconds sounds good.
No ND error code and you spin up to 850RPM which is max for the machine.
You have no standing water in the wash basket.... I'm scratching my head.
Could you do a Spin Only cycle with that same wet wash load and set the SPIN for Max Extract. After you start the Spin Only cycle put the machine in Service Mode and watch the RPM range. This cycle sets the display to 12 minutes. Let’s see if the wash load remains wet and what max RPM is reached.
""Maybe the pump is not turning on during the spin cycle?"" You have no standing water in the wash basket correct? I feel the pump is turning on or you would have standing water in the wash basket and the pressure switch would have never indicated an empty condition (Low Level pressure switch contacts) to the Control Board. The Control Board would have stopped the wash cycle with a ND for no drain error code.
The pump in the spin cycle will turn on a number of times see if you hear turn on in a Spin Only cycle
I just ran a Spin Only light wash load with about 5 gallons of water in the wash basket. Timer went to 12 min. I toggled into Service Mode to watch wash basket RPM. At about the 5 Min mark (toggle in and out of Service Mode) the wash basket reached 850RPM then a few minutes later it stepped down to 830RPM to end of Spin Only Cycle. You don’t have a water valve stuck open or you would flood/over flow of the machine. Did you here the drain pump turn on several times during the Spin Only cycle?
Rich
Apr 08, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Washer will fill fill with water but doesn't start wash cycle
it will fill but won,t spin, will throw out water as if it washed, then it take water to rinse but won,t spin ,then will throw out water as if it did , but clothes are soaked
Feb 21, 2009 | Roper RAS8445KQ Top Load Washer
Bosch classixx 1000 washing machine - stops on spin
Washing machine stops at the spin cycle - light flashes. Have to drain water out manually. Happened last week and was then able to run an empty rinse cycle. Machine worked normally for another week. Same problem today but have had to drain water manually from the drum after trying an empty 90 wash and rinse cycle (both stopped on the Spin and flashed). Any ideas? Thanks. x
Apr 29, 2008 | Bosch Classixx WVF 240S Front Load Washer...
Jan 06, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Roper RAS8445KQ Top Load Washer Logo
534 people viewed this question
Top Roper Washing Machines Experts
Dan Webster
Dan Webster
Mike
Are you a Roper Washing Machine Expert? Answer questions, earn points and help others
