Question about Yamaha RX-V663 Receiver
MY YAHAHA RX-V663 RECEIVER WILL NOT PLAY SOUND FROM MY TV. THE VHS AND DVD HDMI SLOTS WORK FINE. I HAVE REPLACED THE CABLE BUT STILL NO SOUND.
I have a yahaha rx-v 1065 reviver it will not play my tv. What do I do?
Posted on Feb 22, 2011
I am have my DVD player connected to the receiver via component cables (blue, green, red). Sound is playing perfectly via its own set of cables. I have an HDMI leaving the receiver as an input to the...
Sounds like your receiver only supports HDMI "pass-through"
HDMI passthrough will only forward the video signals from the source HDMI port, it will not actively convert the Component Signal to HDMI.
May 30, 2011 | Yamaha RX-V663 Receiver
Yamaha rx v663 video signal skipping
I'd leave it that way if it was me.
Jan 28, 2010 | Yamaha RX-V663 Receiver
Verizon Fios connection issue with RX-V663 Receiver
I had the same problem with RXV3900, was told by verizon and yamaha it's a software issue with the box. Verizon is suppose to be working on a new update, but no time frame for now. I'm using component to receiver, and hdmi to tv with no issues.
Mar 15, 2009 | Yamaha RX-V663 Receiver
No sound out of right main when watching DVR/TV or VHS
When watching TV or VHS the sound should be stereo and therefor come out of the the 2 front speakers. I suspect you now have sound out of the left front and the center speaker which indicates you connected the center speaker to the right front speakerterminal and the right front to the center terminal.
Just check if all speakers are connected to the correspondent speakerterminal.
If this is correct and the problem persists, try to connect another speaker to the right front terminal to see of the terminal or speaker is not working properly. If another speaker does work on the same connection, your right speaker might be damaged which might not be heard when listening to 5.1 because of the surround sound.
Tv speaker noise from yamaha rx-v663 hdmi connection
try running your A/C from TV to your reciver swichd outlet sound like it could be a grounding problem.This will put all ac from same outlet to the same componets.And will elimanate any difference in potencial
Jan 19, 2009 | Yamaha RX-V663 Receiver
Xbox 360 dashboard will not show using Yamaha RX-V663
I had this issue once before, recheck all the conenctions on the tv, and make sure that the HDMI plug in for the TV * if its the older model * make sure it is placed to HDMI not TV.
Please let me know how it goes,
Thanks
Justin
Please rate me
Jan 07, 2009 | Yamaha RX-V663 Receiver
Yamaha RX-V663 - HDMI doesn't work.
Hi and welcome to FixYa,
Initially, a workaround:
  • as you posted, audio out of the DVD goes to the receiver;
  • HDMI out of the DVD goes to the Schaub Lorenz LCD.
Even if it were a compatibility issue or HDMI processor issue on the receiver, the above should get you going.
Good luck and Thank you for using FixYa. Happy Holidays.
Dec 19, 2008 | Yamaha RX-V663 Receiver
Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Dec 01, 2008 | Yamaha RX-V663 Receiver
No sound when using Panny plasma with RX-V3800
Let me see if I understand. You have one HDMI cable linking your TV and AVR? This is only to send video and sound out to your TV from the AVR you will not be able to send sound back over this same cable. You'll have to use the TVs audio out and connect it to an input of the AVR. The "HDMI out" on the AVR is just that Out and not In. For more questions I'd recommend checking out the RX-V3800 RX-V1800 thread over on AVSforum.com
Aug 10, 2008 | Yamaha RX-V3800 Receiver
Green screen via analog connections
check if your input settings in the RXV663 for the S-video and composite are correct. Both connections are about the worst possibilities for video signal. What might help is powering of all other equipment not used when using XBOX or VCR, really powering off, not leave in standby.
Does your TV support analogue inputs? Than use them for the XBOX and VCR to connect directly to your TV for video, sound can still be connected to the yamaha.
let me know if it works.
Aug 08, 2008 | Yamaha RX-V663 Receiver
Yamaha RX-V663 Receiver Logo
118 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
