Question about LG WM-1832C Front Load Washer
I'm getting the error message LE which says motor overload. I've read some comments on line that people have drained the water unplugged the machine for a couple of hours and the error message went away and washer worked fine. I'm wanting to know how to drain the water?
  • 327 Answers
LE code stands for locked motor error. When this error code appears in your front load washer it indicates a fault in the motor unit.
1 . Check the connections to the Coil/Stator at the rear of the unit possibly it should be something like a broken wire.
2 . Coil/Stator Assembly will be defective preventing the drive to operate.You should go for a replacement of that assembly.
Thanks
Posted on Jul 14, 2010
How do I fix my washing machine
If your washer was working previously please read below.
Thermal Overload Protection
Your washer may display the LE code if the thermal overload protection circuit in the motor has been tripped. The feature is designed to prevent the motor from overheating and causing permanent damage to the washer. To clear the error code, the motor must cool down. Allow the washer to sit for approximately half an hour before restarting the cycle. If the code reappears, the motor may have an issue that requires a service call. Unplug your washer and contact LG.
Jan 06, 2015 | Washing Machines
Lg wd-3245rhd LE error message
This seems to be a fault in the motor wiring harness, check all the connectors to and from the motor, check the male and female connectors. Also check the sensors to the motor which can cause this motor to show up as overload.
Jan 14, 2013 | LG WD-3243RHD Front Load Washer / Dryer
LE error message - how to finish the wash cycle?
error LE Overload in motor.unplug for 1 hour plug back in. motors going bad or over loaded with stuff.
If not, you need to call tech.
Thanks.
Jun 17, 2009 | Washing Machines
Le error code on my LG washer.
On LG Washers the code LE is for motor overload protection.
Ensure that you are not overloading washer, make sure to clean pump by draining at little door at lower left corner(check manual for instructions), unplug for 30 minutes to reset, now try running cycle again. if it fails again something else is causing the motor to work to hard and will require a professional.
Apr 25, 2009 | LG WM-1832C Front Load Washer
Error code LE and OE
The LG error code OE simply means “the pump is blocked”. Presumably the water isn’t being emptied properly. Check the exit hose, it may be clogged.
LE Code refers to a motor overload.Since the pump is blocked,the motor becomes inefficient in working.Once you get the pump cleared from blockages,I assure that you can get rid of these errors.Good luck with the machine.Please do post the results and comments.
Apr 12, 2009 | LG 24 in. LDF 7811 Stainless Steel...
LG WASHER WM1832CW HAS LE ERROR MESSAGE
Jan 15, 2009 | LG WM-2277HW Front Load Washer
LE error after machine fills with water
LE error means level error (the d/w fills up but the water drain out at the same time somehow). I had a case once where the drain hose at the back of the d/w was resting on the floor to drain underneath the cust house. problem is like any drain hose it has to GO UP FIRST and then down to the ground otherwise the gravity will push the water out as the d/w fills up hence the LE error.
take care.
Jul 19, 2008 | LG 24 in. LD-12BS6 Stainless Steel...
LE Error message
"LE" means overload in motor. When we first got our LD washer we had similar problems. I evenually concluded it was related to adding too much detergent. My suggestion is remove everything and run the machine thru the cycle empty a couple of times with just water. If you cannot get it to run, try draining the water though the drain at the front lower corner. Then using a jug add some hot water in the soap dispenser to flush some of the detergent, and drain that. See if the machine will now run thru a cycle with just water. In our case we were able to get it to run after it sat for a day, perhaps the motor need to cool, I am not sure why. It was tough to get the machine going but once we flushed it and used a LITTLE high efficiency soap with loads we have had no more problems except once when my son did a load with lots of detergent. Then we followed the steps above and were back in business. Hope this help you.
Nov 29, 2007 | LG WM-1832C Front Load Washer
LE error code
The LE error code can be an indication of several different issues. The most common cause is over-sudsing in the machine. Overloading the wash with too much laundry may also cause the LE error code. Lastly, a breakdown in the signal between the microprocessor and the motor may cause that error code. This can occur if there is a loose wire or a dislodged ball sensor. Good luck!
Aug 19, 2007 | LG WM1812C Front Load Washer
LG WM-1832C Front Load Washer Logo
262 people viewed this question
Top LG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
