Question about Dremel & Stylus Lithium Ion Cordless Rotary Tool
Dremel Stylus 1100 7.2 volt wont charge when the
Dremel Stylus 1100 7.2 volt wont charge when the drill is placed in the charging cradle the green light comes on but only for about 30/40 seconds then goes out i have tried to charge it by watching as the light goes out taking it out of the cradle and replacing it until the light goes out again i have repeated this for about 20 mins this seems to work and it does put a charge in the battery so is it the charger or the batterys that are faulty. thanks mark.
  • 28 Answers
SOURCE: Replace the docking station-charger of dremel stylus
ebay.com or www.craigslist.com
Try to find a used one maybe?
Posted on Sep 01, 2010
  • 132 Answers
SOURCE: Model 800 Dremel cordless won't work
try putting the battery in the charger with the power turned off (unplugged from wall socket ) leave over night then start recharging fresh and dont disturb for 10hours after 10 hours see if any better hope this helps glenn.........
Posted on Nov 16, 2008
SOURCE: Battery on my cordless dremel will not charge.
Dremel Stylus AC/DC Adapter 230/240V Transformer primary is open circuit any idea what the AC output of the transformer is. I should be the same for 110V input transformer. If I can find the output voltage from the transformer I can probably get a replacement
Posted on Dec 14, 2009
rowdy45176
  • 2176 Answers
SOURCE: Dremel Stylus model 1100
I would contact Dremel.com and talk to their tech department about a warranty repair for this tool.
Posted on May 08, 2010
blueextc3221
  • 15935 Answers
SOURCE: My dremel 10.8 lithium ion
The battery has been overcharged.
You will need a new one.
Thanks!!!!
Posted on Aug 18, 2010
Why will my cordless dremel not take a charge
Make sure it is seated properly in it's cradle. Check that the dremel and cradle contacts are clean. If it is brand new, it may need a longer initial charge. Check the manual under 'troubleshooting'. Good luck!
Feb 15, 2016 | Dremel Tools & Hardware - Others
How can I locate capcisator for Dremel Stylus Lithium-ion model 1100 ? It has got charging problem.The Stylus is a cordless tool.
Do you mean a capacitor? Is it the charger or is it the battery? The capacitor are plain types can be found at any electronic parts store. I think the main one is 220uf. Be sure an check each for problems.
Jan 18, 2015 | Dremel Tools & Hardware - Others
Dremel stylus 1100 (No Charger)
First you need to get an equivalent charger and some type of male/female or contact harness. This will have to have at least three pins as that is what is already on the Dremel. Now the difficult decision, do you want to open up the Dremel if it's still under warranty? If you don't mind opening it then my solution will work. Open up the Dremel and look at the inside of the contacts. As this is a DC charger it can only have positive and negative terminals. You say there are three contacts, so there will either be two positive and one negative or two negative and one positive. Most likely there will be a bridge wire between the two terminals with the same polarity. Strip a little of the insulation from the terminal wires and solder new leads to your contact harness. Noting the polarity of each pin/contact on the new harness wire the other part of the contact harness to the charger. You will most likely have to make a small hole in the Dremel's outer cover to allow the wires to pass through. As you own a Dremel I'm sure you are capable of attempting this easy bit of DIY. There is only one problem, If the third contact plate is a return signal to the charging base it might be to inform the charger when the battery is full. In this case the terminals inside the Dremel will not be bridged and I suggest you buy a new or secondhand charger. Hope this helps
Nov 15, 2013 | Dremel Cordless Stylus, 7.2V, 5, 000-25,...
I want to use my USA Dremel Stylus in Europe. I already ruined a docking station, using my 110-220 transformer. I now have a new dock but what type of transformer should I get? Dremel says it should put...
I presume you want to use a transformer to convert the Europe voltage to USA voltage ( 220 or 240 to 110 )
Why not purchase a 240 volt docking station ?
Send me the 10 digit number on your Dremel (usually starts with F ) and I can help you.
Oct 09, 2013 | Dremel Drills
Dremel 1100 for in a few seconds
Change the capacitor 220uF 25V and it will charge properly again (at least that is the result I got and several others here at FixYa).
Easy to do and cheap (component around 0,2 Euros) work about 2 min,.
Feb 17, 2012 | Dremel & Stylus Lithium Ion Cordless...
Dremel Stylus only charges for 2-3 minutes then stops
This is the charger, its getting a reading from the battery that its charged when it isn't. I don't know exactly how that charger is wired but, to be suroe it is the charger, as I have had similar problems beforehand.
Jun 17, 2011 | Dremel & Stylus Lithium Ion Cordless...
Change the capacitor 220uF and it will most certainly work again. I got the idea from FixYa and it solved my problem!
Easy to change just 2 soldering points and a component costing around 0,2 Euros. If you do not know how to operate a soldering tool ask someone for a quick assistance. The switch takes around 2 min (1,5 min to open the charger and 0,5 min to change the component!).
/Johan
May 05, 2010 | Dremel & Stylus Lithium Ion Cordless...
Ipaq 1940 losing programmes during main battery changeover
  1. Plug the charger adapter into the charging port on the bottom of the HP iPAQ Pocket PC.
    Figure : Charging the battery
  2. When the power indicator on the top of the HP iPAQ Pocket PC turns solid amber, the unit is fully charged and can be disconnected from the AC adapter (approximate time to fully charge a unit is four hours).
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.In the event of a low backup battery warning, charge the unit immediately before removing the main battery to avoid data loss. To view the amount of charge left in the backup battery, tap Start, Settings, the System tab, and Power.
Charging with the universal desktop cradle and AC adapter Use the universal desktop cradle to charge the HP iPAQ Pocket PC, or synchronize the HP iPAQ Pocket PC with a computer.
Follow these steps to charge the HP iPAQ Pocket PC using the universal desktop cradle:
  1. Plug the AC adapter into an electrical outlet and connect the other end of the AC adapter to the AC connector on the universal desktop cradle.
  2. Connect the serial or USB cradle cable into the appropriate port on the desktop PC.Figure : Connecting with the cradle
  3. Slide the bottom of the HP iPAQ Pocket PC into the cradle and push firmly to seat it.
CAUTION: To avoid damaging the HP iPAQ Pocket PC or the cradle, make sure the pins are aligned before pushing the HP Pocket PC into the cradle.
    Figure : Charging with the universal desktop cradle
  1. AC adapter into electrical outlet
  2. AC adapter into universal desktop cradle
  3. HP iPAQ Pocket PC into cradle
NOTE: The amber charge light blinks while the battery is recharging and turns solid (nonblinking) when the battery is fully charged.There are stabilizers located in the universal desktop cradle that assist in aligning the unit when there is no expansion pack attached. When placing the HP iPAQ Pocket PC with an expansion pack attached into the universal desktop cradle, the stabilizers will be pushed down by the expansion pack. To release the stabilizers for use without an expansion pack, press the button on the back of the cradle.
Charging with the optional USB Autosync cable Charge the HP iPAQ Pocket PC using the optional USB Autosync cable by connecting the Autosync cable to the HP Pocket PC and the personal computer. The HP Pocket PC will be charged using power from the personal computer.
For more information on charging the HP Pocket PC using the optional USB autosync cable, from the Today screen, tap Start, Settings, the Systemtab, Power, the USB Charging tab, Settings, and Help.
Charging a low battery The HP iPAQ Pocket PC will not turn on if the battery has a low charge (less than 3.2 Volts). Fully charge the battery prior to using the HP Pocket PC.
If the charge on the battery goes below the 3.2 Volts as a result of not being connected to the universal desktop cradle or the AC adapter, no damage will occur to the battery. However, the HP iPAQ Pocket PC charge indicator light will not flash until the battery reaches the minimum charge of 3.2 Volts and a normal reset is performed.
Follow these steps to charge and reset the HP iPAQ Pocket PC:
  1. Connect the HP iPAQ Pocket PC to an A/C power supply.
  2. Charge the battery to the minimum level of 3.2 Volts (this will take 5 to 30 minutes depending on the current charge level).
  3. Perform a normal reset by using the stylus to lightly press the Reset button on the bottom of the HP iPAQ Pocket PC.
  4. Turn on the HP iPAQ Pocket PC.
Keep the HP iPAQ Pocket PC connected to the universal desktop cradle or AC adapter when it is not in use.
Aug 25, 2017 | HP iPAQ H1945 Pocket PC
Apr 01, 2009 | Dremel 8000 01 Cordless Rotary Tool Kit...
Dremel & Stylus Lithium Ion Cordless Rotary Tool  Logo
460 people viewed this question
Top Dremel Tools & Hardware - Others Experts
Mike
rodhep
Level 1 Expert
Daniel Dollive
Daniel Dollive
Are you a Dremel Tool and Hardware - Other Expert? Answer questions, earn points and help others
