Question about Maytag CWG3100A Gas Single Oven
The oven took an hour to heat up to 200.
Had mice and moved it to clean behind, etc. and now isn't heating up????
    President:
  • 1,891 Answers
Ck the wiring as some may have been chewed through. make sure the gas is turned on. then reset your oven clock and try again .. mm
Posted on Jul 15, 2010
Gas Pizza Oven - Heat issues
Many of the Pizza ovens require ceramic plates that line the bottom surface of each oven. These ceramic plates absorb the heat and retain the temperature. I never used our ovens with a bare lower surface, always applied the plates for even heat and distribution.
Mar 05, 2014 | Ovens
Does not work after self cleaning.
Behind the door latch assembly there is a thermostat with a reset button on top.
When its tripped everything will appear to work, but just no heat in the oven.
Use a wooden spoon handle to reach behind the oven door latch and push down on the button.
Your oven should work after this point.
Oct 27, 2008 | Dacor MCS130 Millennia Electric Single...
After self-cleaning, oven will not heat. I waited at least an hour before I tried to pre-heat the oven and it will not heat.
There is a thermal fuse on the back of the oven that has blown, it is in series with the broil and bake elements so when it goes out neither element will work. You will have to pull the oven and take the back off. the fuse will be behind the rear panel. It usually has to red wires going to it. Once the fuse is replaced the oven should work fine. It is fairly common for this fuse to blow during the clean cycle due to a lack of air flow around the oven.
Aug 28, 2011 | Whirlpool RBS245PDS Electric Single Oven
Delonghi CT200 cleaning
hello,
Here are step of cleaning oven
Self Cleaning
  • 1 Remove oven racks and soak them in soapy water.
  • 2 Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • 3 Let the oven do its work; it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • 1 Remove oven racks and place them in soapy water to soak.
  • 2 Preheat oven to 200 degrees.
  • 3 Turn the oven off and spray the inside with oven cleaner.
  • 4 Allow to sit for 10 minutes.
  • 5 Wipe the cleaner and dirt away with a damp sponge, rinsing frequently.
  • 6 Dry with a soft cloth.
  • thanks.
    Oct 10, 2010 | Ovens
    I cleaned my self-cleaning oven yesterday and today it won't heat up. Can you help me out?
    hello,
    Here are solution on how to clean up your oven below.
    Self Cleaning
  • 3 Let the oven do its work;it will heat for several hours, charring off baked-on foods.
  • Fast Cleaning
  • Thank for visiting.
    Oct 09, 2010 | Whirlpool Ovens
    MY OVEN wont heat up. its takes at least an hour
    If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
    Check out this tip that I wrote about the Oven not heating problem..
    Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
    http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
    heatman101
    May 28, 2010 | Ovens
    Gas oven doesn't work.
    your ignitor might be bad. check if it glows. if it glows and takes a while to flame up change ur ignitor
    Feb 12, 2010 | Ovens
    My jenn-air self-cleaning electronic wall oven model w131 is heating up very slowly. It took 1.5 hours to get to 175 degrees.
    One of the 2 hot wires is out. Flip (hard) the oven circuit breaker to the off position, and then back on. If it did not help - verify 220-240v between the two hot wires on the terminal block behind the electronic control. If there is less - call electrician.
    Oct 13, 2009 | Ovens
    Our Dacor Millennia wall oven will not heat
    There is a manual reset button behind the vent under the touch pad. Turn off the power. Open the door. Remove the vent. Behind the latch is a two wire switch. press the red button on it until it clicks. reassemble and turn on power. It over heated when the power went off by stopping the cooling fan.
    Mar 04, 2009 | Dacor MCS130SS Millennia Electric Single...
    Magic Chef oven won't heat up past 200 degrees
    You obviously have one or more elements not working, you need to test same, and replace as req'd.
    Dec 12, 2008 | Magic Chef Ovens
    Maytag CWG3100A Gas Single Oven Logo
    101 people viewed this question
    Top Maytag Ovens Experts
    Carmen Mikulic
    Oloyede Monsuru
    Mack Baxter
    Are you a Maytag Oven Expert? Answer questions, earn points and help others
