Question about Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl
My saniplus is not working correctly, it doesn't drain the water from the bath and it makes a funny noise. Its any way of checking inside it?.
    Scholar:
  • Saniflo Expert
  • 115 Answers
Could be something stuck on the blade or the impeller. You can unplug the unit from the GFI, remove all the piping attached, remove the unit completely out the back of the toilet, pry open the lid with a flat head screwdriver, remove 2 screws in front and 1 at the back of the pump casing, then you will be able to remove the motor and pressure chamber out of the pump casing. Therefore you can put it on a work bench and inspect the blade and impeller for obstructions.
Posted on Jul 27, 2010
The bath water won't pump out. Seems like there's too much water left in the Saniplus itself to allow the bath inlet valve to open. Can this be adjusted? The toilet and wash basin are working OK.
This is a bit of a puzzle, if theres water in the Suniplus then the float valve will operate and the water will pumped out as it does for the toilet and wash basin.
I can only think that the bath discharge none return valve is stuck and needs removing and cleaning.
Hope that solves the problem.
Alllan
Mar 26, 2015 | Saniflo SaniPlus-Round SaniPlus Macerator...
We have a basement bathroom. The bath drains away very slowly, but everything else seems fine - toilet and sink draining/flushing fine. Can we use a usual unblocker (eg sodium hydorchloride) to unblock?
I worked on a lot of Saniflo products, they do not recommend using any products that have bleach or chlorine. Make sure the flapper inside the side inlet where the bath drains, is not obstructed.
Dec 03, 2012 | Saniflo & Saniplus& Macerator Pump
Saniplus has bath water going into it as well as toilet water.Why does it take at least two flushes before the bath water all goes?
The Saniplus works on a float switch which is a rubber membrane in the pressure chamber (where electrical components are) water pressure pushes up in the membrane and the unit kicks on and pumps the waste out. Once the pressure releases, the membrane goes back down and shuts off. If the membrane is warped or solids are build up at the bottom, it will not allow it to kick on and off as it should. You might want to inspect that membrane and have it cleaned or replaced.
Jan 17, 2012 | Saniflo 002/005/007 Saniplus Toilet with...
Sanivite 3 makes humming noise and no longer pumps water out
Jonathan: You need to remove the pump from the shell and make sure the grinding impeller is not cloged up with hair or other junk. Also, is you drain line out of the unit completly clear?
Dec 12, 2011 | Saniflo & Saniplus& Macerator Pump
My neighbours saniflow toilet is drivng me mad. The motor keeps whirring every 5 mins. Whats the problem, please!
Water pressure is what makes the unit kick on and off. If its kicking on by itself most likely water is somehow draining back into the pump. Start by checking the flapper in the flush valve inside the toilet tank, it may be leaking water into the bowl and from the bowl into the pump. Also inspect the check valve inside the 90 degree elbow where the waste is pump out from. The check valve may not be closing properly and is allowing waste water to drain back into the pump creating water pressure making the unit kick on and off by itself.
Oct 07, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Water has filled the toiled bowl,wash basin and bath. And it's not emptying
Your drain line is clogged. need to find the clean out on your drain lines and snake it out. If tou don't have a clean out , you have to go through the vent stack on the roof.
Jun 12, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
Sanipro xr is less than 6 months old been working fine but has recently become rather noisy. Sometimes goes off in the middle of the night for no reason.
Water pressure makes the unit kick on and off. Somehow water is draining back into the pump casing, check the flapper on the check valve inside the discharge elbow, it may not be closing properly or may be obstructed allowing waste water to drain back into the pump. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may be leaking water into the bowl and from the bowl into the pump casing sitting behind. As far as making a loud noise, there could be a blockage on the drain pipe, blade or impeller. The discharge pipe may be loose, not clamped against the wall and is rattling against the wall when in use.
Jan 08, 2011 | Saniflo SaniPlus-Round SaniPlus Macerator...
System works perfect however the pump now has started turning on every 10 or 12 min and runs for about 2 seconds then shuts off
This means that water is draining back into the pump, creating enough water pressure that is making the pump kick on and off at all times. You need to inspect the check valve inside the discharge elbow where the waste is being pumped out, the check valve may be obstructed or may need to be replaced. Also check the flapper on the flush valve inside the toilet tank (water closet) the flapper may not be sitting properly allowing water to drain into the bowl and from the bowl into the pump.
Dec 08, 2010 | Saniflo SaniPlus-Round SaniPlus Macerator...
My macerator turns off and stops working for 10 - 15 minutes
the macerator is over heating.check the maintenance opening and clean it ,but you may need a more powerful macerator,some are made only for flushing systems (as in toilets) a pro-longed use may be making it overheat.. good luck
Jul 02, 2009 | Saniflo & Saniplus& Macerator Pump
Our Saniflo - Saniplus works fine and efficiently when we flush the toilet, if we use the shower or bath,when emptying the water the flow is not as strong/as much pressure like a toilet flush & the...
Sounds like a restriction in the outlet pipe, the 2 galls from a flush are OK but the bath or shower is more, especiallly if you have flushed before you shower, try drain unblocking chemicals or flushing the outlet pipe with mains water from a hose
Mar 09, 2009 | Saniflo & Saniplus& Macerator Pump
Saniflo SaniPlus-Round SaniPlus Macerator Toilet with Round Bowl Logo
260 people viewed this question
Top Saniflo Home Experts
Paul Carew
Tim Whalen
Are you a Saniflo Home Expert? Answer questions, earn points and help others
