Question about Sharp R-1502 Microwave Oven
Display and Start button
Are you still repairing these and what is your current price and turn around time?
  • handyman1950 May 05, 2008
    2nd sharp r-1502 for me both lost control panel functions first one 16 months 2nd 5 months this is a piece of junk dont buy or repair because even if it was free it would not be worth the installion fee
  • jhoetzl Oct 03, 2008
    Moved into a new place and the LCD in ours looks shot. Will notify landlord about this site.
  • Sharp Master
  • 9,098 Answers
Yes, the repair cost is $39.95 (add $15 for the button assembly) and normal turnaround time is about a week.
Full details are at http://www.microwavedisplay.com
Thank you.
Posted on Apr 20, 2008
How do I set the clock on the kenmore brew wave
To set the clock:
Find the OPTION button, it is the second top button to the left of the green clock display
1 - Press OPTION
2- Press 1 (to set the time)
3- Press the numbers for the current time of day - then press START (ie: 130 for 1:30 )
4- Press 1 for AM / 2 for PM
5- Time is set !
Jul 10, 2014 | Kenmore Brew 'n Wave 63992/63999 Microwave...
Need to st clock on panasonic nne281mm
follow the steps and fix it. God bless you
1) Press the "Stop" button on the microwaveicon1.png to reset the digital display to the clock setting.
2) Push the "Clock" button once. Locate the "Hour" button and press it once for each hour of time. For example, if the current time is 5:15 p.m., press the Hour button five times.
3 )Press the "Minute" button to set the second half of the time. For the example above, you would press the Minute button 15 times to set a time of 5:15 p.m.
4)Push the Clock button to saveicon1.png the time setting. Check the time on the microwave's digital display.
Feb 07, 2013 | Panasonic Microwave Ovens
My microwave doesn't work, but display works
I would strongly consider replacing the microwave oven, prices have dropped considerably. The problem you are describing is in the keypad controller board.
Apr 01, 2012 | Samsung Microwave Ovens
Previous homeowner turned off GE Spacesaver 2.0 microwave display and now we can't turn it back on. Tried directions given to press option button 5 times then #1 to turn display back on. Doesn't...
I was not aware you could turn off the display, maybe it is just a bad display and you need to replace the board??!!
Ive been repairing Microwaves for 37 years. i do not remember seeing one where you could just turn off the display.
Oct 16, 2017 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave shows H98 problem. How can we solve it.
H97, H98 and H99 appears in display window a short time alter start key is pressed and no microwave oscillation.
NOTE:
DO NOT try to REPAIR this Inverter Power Supply (U) and also DO NOT RE-ADJUST PRESET VOLUME on the board. It is very dangerous to repair or adjust without sufficient test equipment because this circuit handles very high voltage and very large current. Off alignment or inverter board operation is dangerous. Operating a misaligned inverter circuit is dangerous due to the very high voltage and current that is produced by this board. Defective boards must be replaced with a new one.
Jan 01, 2011 | Panasonic NN-S541 Microwave Oven
Our 2006 Samsung Microwave has suddenly ceased to heat anything. The clock works and the turn table goes around, but that's it. We had a couple of power outages just before this happened. Could it be...
Press the "Off/Clear' button to cancel anything on the display, and reset the microwave. This is a soft reset and will simply get you out of any program you have started. Press it when the cooking complete reminder appears on the display.
Perform a hard reset. Pull the plug out of the wall power supply, and wait a moment. Plug the GE microwave back into the wall power supply to reset any anomalies with the microwave's memory. You will need to reset the time of day if you perform a hard reset.
Reset the time of day. Press the "Clock" button, and turn the dial to set the hours. Press the dial to enter. Follow the same procedure for the minutes and a.m. or p.m. Press the "Start" button to start the clock.
Nov 29, 2010 | Samsung Microwave Ovens
Turns off after 15 seconds..shows H98 on the window and wouldn't start.
NOTE:
- Check magnetron filament for open or short to casing before proceeding to determine a good magnetron.
Nov 04, 2010 | Panasonic NN-H765 Microwave Oven
Switching off the sound of my Samsung Microwave
1 Press the Sound button. The display shows "ON".
("START" will flash)
2 Press the Sound button to turn the volume off. The display shows:
"OFF".("START" will flash)
3 Press Start. The display returns to the time of day.
Lastly, you can find a copy of the manual here:
http://downloadcenter.samsung.com/content/UM/200507/20050727140356453_DE68-01945A[GB].pdf
Sep 01, 2009 | Samsung MW1030WA Microwave Oven
How do i set clock for time of day
You can download your owner's manual free here.
From the manual:
SETTING THE CLOCK - When the microwave oven is plugged into an outlet, the oven will display " 0:00 "
1. Press the CLOCK button; the hour digit will blink
and the clock indicator will light.
2. Press the number keys to set current hour.
3. Press the number keys to set current minute.
4. Press AM/PM to choose AM or PM.
5. Press the CLOCK button again; the display will
show the present time. After the clock has been
set, the time will appear with blinking colon,
unless the oven is cooking or defrosting.
NOTES:
- To reset the present time in the display window when the oven is off, press the CLOCK button and
reset.
- If you make a mistake when setting the time, press the STOP/CLEAR button.
- To recall the actual time while the oven is cooking or defrosting, simply press the CLOCK button
and the display will show the actual time for three seconds.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 03, 2008 | Emerson MW8107WA Microwave Oven
Sharp R-1502 Microwave Oven Logo
167 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
