Question about Ovens
My bottom oven does not get hot. Mod. No. ZOU 575 N Ser. No. 81100001 would you please help me.
    President:
  • 1,561 Answers
Reset your “time cook” function if your oven has one. They are often set wrong and prevent the oven from coming on. Service professional see this problem often, much to the homeowner's embarrassment!
Make sure the stove is plugged in and you have power to the outlet. Electronic ignition systems and some standing pilots need electricity to operate.
Check the oven ignition fuse. You’ll need your owner’s manual to locate it. If blown replace it.
Check the pilot, if your oven has one. If it's out, clean and relight it according to the manufacturer's directions. If you're unsure how, call a service professional.
Take care.
Posted on Jul 14, 2010
Please help find oven mauel
open oven doors and check behind the bottom of the doors for mod number
Nov 21, 2013 | Ovens
How to clean the streaks between the inner and outer glass on the oven door
Ugh its not fun and takes two people as you have to split the door with several screws and easy hands... take the door off... there's two tabs at the two hinges either slide them forward backwards or some are spring loaded. however get the door off and begin dis assembly preferably on soft surface. pay attention to how things go back together and begin cleaning have fun....
Sep 02, 2012 | Whirlpool 30" Self-Cleaning Freestanding...
Where can I find bottom burner oven valve
Here is where you can find most parts copy and paste the link below into your web browser to look.
http://www.partselect.com/ModelFrames.aspx?ModelID=917028&ModelNum=fgf337awa&mfgModelNum=&ManufactureID=4&Selected=6HODOMXW&Position=2&mfg=Frigidaire&Type=Appliance&Mark=2
Apr 07, 2012 | Frigidaire Ovens
I am looking for self cleaning instructions for a GE oven. MOD. VJ33VWLW-3 SER.ZH273130 VOLTS 120/208 KW 8.6 120/240 11.4 LR 27 TYPE B45 CAMCO INC. Made in...
You should have a selector knob turn it to clean then lock door with lever in the front select hrs on the timer should start up
Sep 18, 2011 | GE Ovens
Bauknecht Mod. BSC 1000 nothing working. Checked fuses - is there a switch/fuse on the oven that could have blown?
THERE IS A THERMAL SWITCH ON THE OVEN INSIDE FOLLOW THE POWER CABLE TO THE CONTROL SWITCH. MOST OVENS HAVE A THERMAL SAFETY INSIDE THEM INCASE THEY GET TO HOT
Mar 08, 2010 | Baumatic B187 Stainless Steel Electric...
Magic chef mod.#b31fa-2kx ser.#22c817514515 gas range switched to propane top burners work perfect but oven is too hot. screwed in the orafice all the way and cant find any screw or lever on the thermostat...
Crank down and flip models require tweeking. have you adjusted the regulator accordingly?
You must remove and flip the regulator nut to get the gas pressure from 3.5 to 10.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Sep 13, 2009 | Ovens
Frigidaire self cleaning stove mod FEF369cgsb ser vf94422321 was originally wired direct and it shows 4 wires. Now I want to use a plug and outlet, 3 prong. How do you connect the 3 prong plug? thank you...
Vivian
the original wiring probably had a red, white, black, and green wire. It is 240 volts. The red is hot, carrying one leg of 120 volts. The black is also hot, carrying 120 volts. The white is neutral, and the green is the ground.
I am against altering this, but you can wire the red and black each to a hot leg, and wire the white and green to the bottom ground. This then introduces a ground wire to your neutral bar in the circuit panel, which is not the best way to do it, but will work.
Best to get an electrician to wire a 4 wire cable to a four prong outlet, and then use a four wire pigtail with a 4 pronged plug.
Lots of people modify it, they ground the green wire to the stove, where the wire originates,and to the box with the outlet in it where it hooks onto the plug if it is metal. Then you have a part ground. And that is assuming you have a cable with wires sticking out to wire to a plug.
Boils down to your decision. If the above isn't the case, get a four pronged outlet and wire the red and black to the top two prongs, the white to the neutral, and the green to the metal box it sits in.
Sirwriter
May 16, 2009 | Frigidaire 30" Self-Cleaning Freestanding...
I need to know if my oven has auto shut off and when it kicks in
Auto clean? I would not use it even if it did have that feature. The extreme temp cause the electronics to fail.
Apr 10, 2009 | Ovens
CANT FIND PART FOR COMMERCIAL PIZZA OVEN
Go here and find what you seek. Great Co.will help for free.BLODGETT
44 Lakeside Avenue, Burlington, VT USA 05401
Toll Free: (800) 331-5842 Phone: (802) 860-3700 Fax: (802) 864-0183
Jan 13, 2009 | Blodgett MT1828G Oven
Ovens Logo
20 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
