Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
F1 error on top and bottom. Power won't shut off until unplugged.
  • Fisher and P... Master
  • 3,247 Answers
Generally it means the flood switch under the drawer (inside the housing is activated). This means water is leaking from somewhere - foam in detergent, cracked or crinked hoses, door seal leak etc.
To fix, take the drawers out from housing and dry the flood switch located in the centre of the housing base. Need towels and hair dryer.
Make sure the power is turned off.
Posted on Jul 30, 2010
How do I stop the F1 error even after assessing there is no water in the bottom tray and dried it with hair dryer just in case
There should be F1 on both displays. "If power fails to the bottom tub it will cause the top tub to go F1. Test heater plate." (from the service manual).
If there is F1 on both displays it could be a faulty flood switch or PCB.
Jan 30, 2015 | Fisher and Paykel Dishwashers
Flood switch 920 model
Not sure what the actual model number is but usually the F1 error with Fisher and Paykel dishwasher means water has entered the flood switch located at the base. This could be due to leaky hoses or water leaking through the door or lid seal. Wait for a day or two until the water evaporates and try again. Otherwise you will have to dry out the flood switch and then try again. Location of flood switch will depend on your model. For double drawer dishwasher you will have to take the bottom drawer out from the housing and the switch is on the floor of housing. But make sure you take the mains power chord out before touching the insides of dishwasher. Will also need to find the cause of the leak. Other reason for F1 could be loss of power to top dishdrawer if you have double drawer. But in that case the top drawer will have no lights on. The power board is located on the base of housing under bottom drawer. Once again do not touch inside of dishwasher without shutting off mains power.
Jan 27, 2014 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Our fisher and paykel dishdrawer won't wash. It comes up with F1 and flashing light on control panel.
the dynamo dishwashing stuff has caused foaming which reached the base of the dishdrawer unit causing the flood switch to trip. This gives F1 error.
Not sure how much foaming has occured.
Best to turn off power and take power cable out from socket. then empty the drawer using towels. pull out the bottom drawer and wait a day or so to let the foam disappear from the bottom of dishwasher (under the bottom drawer). Connect the power and see if F1 had gone. If not, you need more work. Post a comment based on the above suggestion and I will guide you further if required. Always use Finish dishwasher power only (recommended quantity) as the drawers are small and don't need much detergent.
Dec 27, 2012 | Fisher Paykel Dishwashers
Mer6772bas ovens won't work, bottom oven won't open
F1-4 is a lower oven runaway clean error F9-3 is a lower oven door latch failure. Must be a bad door latch causing the errors.
GEMINI FAULT CODES
Aug 30, 2012 | Maytag MER6772BAS Gemini Electric Kitchen...
We have a 23" Fisher&Paykel dishwasher and got
The F1 error coming on top drawer when operating bottom drawer is due to the thermal fuse blowing up on the bottom drawer and shutting controller power.
The thermal fuse could have blown either as a normal component failure or heater over heated due to thermostat failure. In any case this can be repaired by replacing the whole heater assembly as all the parts are integrated.
This is at the underside of the drawer and will need a technician to replace unless you are very familiar with repairing electronic dishwashers. The part look like this.
The way you have described the onset of the F1 error is not due to flood switch. You can confirm that the lights on the bottom drawer are out even though the top drawer is showing F1 and beeping.
If problem was flood switch then both drawers would show F1.
Nov 25, 2010 | Fisher and Paykel 23 in. DD-603 Built-in...
F1 is coming up on the top and bottom drawers of the dishwasher.
Hi
Thanks for using FixYa.
F1 error means that the flood switch has been activated. You'll need to reset it by powering off the breaker or by unplugging the unit from the power socket and mains for more than five minutes. Please check that there is no blockage in the drain hose and it is not raised higher otherwise the water will run back to the dishwasher. Also perform the following procedure---
    • Unplug power and remove bottom dish drawer
    • Use a Sponge and dry all the excess water underneath
    • Remove circuit board cover
    • Dry all around and underneath as much as possible
    • Apply hairdryer for 10-15min
Please rate the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Oct 07, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
F1 error
The heater unit in the bottom drawer is blown. This causes power to shut off to the controller. The effect of this is the F1 error on the top drawer.
If you get the heater on bottom drawer fixed, that should take care of the F1 error in the top drawer.
Jul 11, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
181 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
