Question about Salter 2001 electronic kitchen scale
HOW DO i CHANGE THe Battery on A Salter Scale Model#2006
5 Suggested Answers
SOURCE: Can't open battery case
The middle part slides out. You'll need a small knife or a screwdriver to pry it out gently.
There are openings on two sides. One side has a larger opening than the other. Make sure you pry it out of the lager opening.
Once you gently slide it out, you'll see the two batteries. Make sure the positive side is facing up when you put them back in.
Hope that helps!
Posted on Aug 18, 2009
SOURCE: Kitchen scale, Salter, model 2006: change batteries
The 1 part just slides off.
Posted on Jun 28, 2010
SOURCE: setting the clock on salter scale model 5007
Hold down the g-oz key and the off key at the same time for about 5 sec's
The hour digit will flash
press the ml-floz key to move the hours.
then press the g-oz key again to move to the minutes.
press the ml-floz key again to set the minutes.
press the g-oz key and it moves to setting the cloak to 12h or 24h option.press the g-oz key to set the time.
And your done.
Posted on May 23, 2010
SOURCE: I changed the battery on bathroom scale Salter 987
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery untill you first complete the steps listed above.
Posted on Aug 29, 2010
Calibrate Salter model 9140 bathroom scales
Remove the battery and count to 10 and then replace it.
i found this
You do not reset the scale. It only saves the last recorded weight of the user. So, if you weighed yesterday, it will put your recorded weight in memory. The next time you select your user number and step on the scale, it will compute the difference from your previous record and save your current weight.
and also this
I had the same problem with my Salter 987 scale. Pull the battery out for about 10 seconds and put it back in. Then push the scale once so it turns on. After the blinking stops, push it once more. The scale will now zero itself. After the scale has zero'd itself it may turn off after a brief moment. It's now ready to use normally. If you're standing on the scale when it's trying to calibrate to zero, it will assume your weight is zero. Don't stand on the scale after replacing the battery until you first complete the steps listed above.
Not sure if this is the correct manual, but may be close. Page 3 and 4.
Salter Housewares Body Fat Computer Instruction Manual Page 3
Nov 27, 2017 | Salter Health & Beauty
How do i get battery compartment open on Salter kitchen scale model 2006
I went to the Salter website and I could not find that model number.
Salter Disc Electronic Digital Kitchen Scales White
However, looking at the other models they had there should be a door on the bottom of the scale. It looks like a release tab that you push in then lift up on. Give that a try.
Nov 22, 2017 | Salter Health & Beauty
Battery +- flashing on scale after battery change
The batteries may have been installed with the wrong polarity
Feb 12, 2014 | Salter 2001 electronic kitchen scale
Battery code for Salter kitchen scale Model 6055
i needs manuals of calibration of the scale salter model 6055
Aug 23, 2011 | Salter 2001 electronic kitchen scale
Jul 21, 2009 | Salter Stainless Steel Electronic Bathroom...
Salter 2001 electronic kitchen scale Logo
4,413 people viewed this question
Top Salter Health & Beauty Experts
vince
Marvin
Marvin
Andrew Taylor
Andrew Taylor
Are you a Salter Health and Beauty Expert? Answer questions, earn points and help others
