Question about Linksys Wireless-G Broadband Router
Wireless connection keeps dropping I changed the channel to make sure I wasn't on the same one as my neighbor. The name of the connection is OK (it's not 'linksys'). It's a WRT54G. I just upgraded the firmware for the very first time. Do you think that will stop the disconnects?
  • 550 Answers
It is recommended that after upgrading the firmware of the router, you should reset the router and reconfigure the router.
But once u reset the router, it will come back to the factory default settings and u will need to reconfigure the router.
Click Here for step by step by instructions
Posted on Jul 14, 2010
Dropping wireless connection
first you much make sure that the signals are not interfering with each other. log in to your routers and make sure that one of you is on the first channel and another is on the 3rd 6th 9th and 11th. wifi or wireless signal has bleed into adjacent channels.
this link will explain
2 4GHz Wi Fi interference between devices in close proximity even though...
Sep 03, 2017 | NetGear (WPN824) Wireless Router...
Router keeps dropping connection
Solution for wireless dropping issue or connectivity issues
*Change channels on the router from1,6,11 or 9(rarely works) *Change Channel width 20 or 20/40 MHz *Keep other radio signal emitting or wireless devices away as possible *Change security types *Change Antennas position *Upgrade the firmware
May 15, 2010 | Linksys Wireless-N WRT150N Router
Is there anything in a PC that can cause interference with a wireless network? Because firefox ate my earlier question, I'll keep this short: PC used to keep laptop from connecting to internet when it was...
there is nothing inside a PC that will keep it or anything else from connecting to a wireless network. You have to lookout for things that use the same frequency such as cordless phones and believe it or not microwave ovens. both broadcast at 2.4Ghz which is the same frequency wireless routers and access points use. Your problem may also be a neighbor with a wireless router or access point using the same channel. Wireless routers and access points have 11 different channels that they can broadcast on and if you and your neighbor are using the same channel there will be interference. try changing the channel on your wireless router or access point.
Apr 14, 2010 | D-Link WDA-2320 (ASKU54036) Wireless...
My laptop keeps dropping the wireless and I am having a hard time resetting - i can't understand why
There could be dozens of reasons for this. One of the most common is interference on a certain channel, often caused by neighbors's routers operating on the same channel. Change the channel on your router and see if things improve. Other sources of interference are 2.4MHz wireless telephones (even when on-hook), microwave ovens, and locating the router too close to a water heater or aquarium. The bad news is that reoccurring drops in wireless signal is also a common symptom of a failing router; you can sometimes diagnose this by unplugging and replugging the router's power cord the next time you experience a drop and see if the connection comes back without doing anything to the laptop.
Apr 02, 2010 | D-Link DIR-615 Wireless Router
There is another wireless router closebye, and it seems to make my connection unstable. Can there be some kinda interference? Keep loosing connection, or loosing connection speed.
Hi
check for the following
When you use your laptop you should be able to check for properties on the other connections, make a note on what channel they are on.
go to your wireless router and change the channel that it is broadcasting on to something different. ( ie 6 ) also check that your router is not close to dect phones as they can ruin your signal as well
Jan 08, 2010 | SMC Barricade g SMCWBR14T-G Wireless...
Hello! My laptop is not able to connect to my Linksys router.
Make sure that your wireless is not secure or you are entering the right password. Also check to see what channel that your wireless is set on and compare that to your neighbors around you. If you and your neighbor have the same channel number set that is your problem. Your neighbor is over powering your own router.
Dec 16, 2009 | Linksys Wireless-G WAP54G 802.11g/b...
How can i find my wep key,the system was set up by someone else who never left this info( Netgear rangemax wpn 824)
Open a web browser like internet explorer or Netscape. Enter the ip address of your router in the address bar of your browser. In the picture above the address bar has http://www.google.com in it. Just replace all of that with the ip address of your router. By default the ip address should be set to 192.168.1.1.
You should see a box prompting you for your username and password. Enter your username and password now. By default both the username and password are admin. Click the Ok button to log in to your router.
Click the Wireless Settings link near the left side of the page.
In the box called SSID put a name that you make up. You will need to remember this name because it will be used to connect to your wireless network. Do not make it obvious to guess, the network name should be difficult for your neighbors to guess. If you can not think of anything, simply use your first name.
In the box called Channel, pick a random channel number. Channels make it so that you and your neighbors can use your own wireless networks without interfering with each other. By picking a random channel you reduce the chance of your neighbor using the same channel as you.
Choosing your network security type can be challenging. Use the table below to help you decide which encryption type is best for you.
Put a dot into the WEP radio button.
Select Open System from the Authentication Type drop down box.
Select 128bit from the Encryption Strength drop down box.
Put a dot into the Key 1 radio button.
If you are using WEP Now you need to make up your network key.
It doesn't matter what this key is, as long as it is random. A network key is a password that is 26 characters long, and made up of only the letters A,B,C,D,E,F and the numbers 0,1,2,3,4,5,6,7,8,9. If you are using 128 bit WEP, then your key must be exactly 26 characters long, and the more random it is, the better it is. Here is an example of a random 128 bit network key:
7F5B3FD23A8EC290AC682DF8FA
Onnce you have made up your key, write it down somewhere. You will need it at each computer that you are going to connect to your network.
Now put the key you made up in the box called Key 1.
When you're finished, click Apply near the bottom of the screen to save your changes.
And that's it! You're done!
Nov 19, 2009 | Computers & Internet
My wireless has been connecting to a neighbors!!! Help!!
First you'll need to change channel on your wireless router so you can boost more signal (use 1,9, or 11 on channel). Then on your Mac make sure you only have the name of your wireless network set there. Contact your router manufacturer to assist you on how to do that or Mac.
Sep 08, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Keep losing the signal. appears that the power
Intermittent Connectivity:
NOTE: Before following the steps in this article, check if your wireless computers have stable connection when connected to other wireless networks (hotspots).
This article assumes that all wireless computers are experiencing intermittent wireless connection with the Linksys router.
Frequent wireless disconnection can be caused by different factors such as:
  1. Wireless interference within the network.
  2. Wireless settings of the Linksys router are still set to default.
  3. Firmware is corrupted.
Reducing Wireless Interference
If you are experiencing frequent disconnection from the wireless network, it helps if you check the following factors, all of which can greatly affect your wireless signals:
your cordless telephone system (or even your neighbors’), or other nearby equipment. Try to change your router’s channel to 1 or 11 (the default channel is 6) and restart the wireless computers.
Physical obstructions: Your router or wireless computers may be losing connectivity because of physical obstacles such as walls and floors. Try to move the equipment to different locations to find a better link.
  • Placement of the router: Linksys suggests that you place your router as high off the ground as possible. When placing the router in a high location, leave a distance of two feet between the router antenna tips, ceiling, and wall. If your signal passes through multiple floors, place the router on the upper-most floor, and high up in the room.
  • Surroundings: Keep the router away from large metal objects, bodies of water (fish tanks, bathrooms), and any electrical equipment including television sets, microwaves, radios, etc.
Customizing Wireless Settings of the Router
Having default wireless settings on the Linksys router may cause conflict with other Linksys routers within your network range. Linksys suggests changing the SSID (network name) and the Wireless Channel of your router. Also, if it is possible, enable the Wireless Security of your router.
To change the router’s SSID or the wireless network’s name, click here.
To change the router’s channel, click here.
To enable the wireless security on the router, click here.
NOTE: If the wireless connection remains unstable after performing the steps above, upgrade the router’s firmware. For instructions, click here
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Jun 25, 2009 | Linksys WRT54GX2 Wireless-G Broadband...
WIRELESS NETWORKING
There are several problems reported that may cause disconnection. First is the hiding of the SSID (wireless network name) and enabling WEP or WPA encryption. The recommended solution for that is to unhide the SSID in the router configuration.
Second is that there are more and more wireless devices and occasionally interference occurs on a single channel (even from non computer devices like wireless phones. As routers are often set to channel 6 you may be competing for radio communications with your neighbors. The recommendation is to switch the router to either channel 1 or 11. If your first choice does not work try the other.
Dec 24, 2007 | D-Link AirPlus DWL-G630 802.11g/b Wireless...
Linksys Wireless-G Broadband Router Logo
70 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
