Question about GE Profile JTP18 Electric Single Oven
Thermador Oven-F31 Error Code
My Oven has a F31 Error Code and does not stop buzzing. we had to turn
the circuit breaker off to make it stop.
Any idea what is wrong with it?
  • Anonymous Apr 23, 2008
    Why is my thermador oven locked and making a clicking sound? HELP!
5 Suggested Answers
  • 1314 Answers
SOURCE: thermador oven secd272bs error code after install
check your owners manuel for code meaning and how to clear if its new call for service some can push stop reset or clear
Posted on Dec 31, 2007
textonor
  • 130 Answers
SOURCE: Thermador SC302T clicking noise, locked door after power outage
iodine, open the upper oven, look thru the grill below the control panel on the right side and there is your model number. The issue here is that when the power came back on the oven run thru a test and your lower lock motor has failed. It will need to be replaced. Yes the only way to stop this is to shut off the breaker.
Posted on Feb 03, 2008
blueextc3221
  • 15935 Answers
SOURCE: Keep getting F1 error code (constant beep) on my GE profile oven.
Here is some wisdom for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
%#$TEF
Posted on Oct 01, 2010
blueextc3221
  • 15935 Answers
&%YR
I replaced circuit board in whirlpool combo microwave / oven, shows fault code F2, error code E1.
Did you get the circuit board from a trustworthy place?
It is a circuit board error. Did you install it correctly - right wires to right connections?
Control displaying F2 E1:
There may be a problem with the User Interface (Touchpad), or the associated wire connectors.
Power unit down by turning off the circuit breaker(s) for one (1) minute.
Power unit up by turning on the circuit breaker(s).
Monitor the oven for one (1) minute to ensure the error code does not display again.
Verify oven operation
Have to go the long way to bring up the link by first:
e1 f2 whirlpool oven Google Search
and then click on https://www.google.com/url?sa=t&rct=j&q=&esrc=s&source=web&cd=1&cad=rja&uact=8&ved=0ahUKEwjprvf2_7nJAhXKVRoKHe7zAmMQFggdMAA&url=http%3A%2F%2Fwww.whirlpool.com%2Fproduct-help%2Ferror-code-oven-f2-error-code-f2-e1%2FPH7389%2F&usg=AFQjCNFoDK8E-zgNHF3Kp4EoihGu1tbyEw
Dec 01, 2015 | Whirlpool Ovens
Broil trips circuit breaker every time
I would start by replacing the breaker. They do become weak over time.
Dec 05, 2012 | GE JRP28 Electric Double Oven
Flashing PF 32 error code
Hello - This manufacturer does not show to have such an error code for a wall oven. However the error codes F30/F31 indicates that the unit either has an issue with the oven sensor, wiring with the EOC or the probe connections is open or shorted. Contact a professional to move forward accurately.
Nov 10, 2012 | Frigidaire 30 in. Electric Gallery Series...
We have a whirlpool double oven, model RBD245PDB12. Oven cooks well but, will not stay off, buzzes long and short intermittently throughout day and night flashing F2 code or E6.
Stove will not turn off CHECK
Temperature Control Thermostat
If the oven won't turn off the oven thermostat is often the cause of the problem. The electrical contacts inside the oven thermostat can weld themselves together and then the oven won't turn off. If this happens, turn off power to the entire appliance at the household circuit breaker or fuse. The oven thermostat usually cannot be tested and must be replaced if defective.
Oven Control Board
The oven control board has a set of relays that turn on and off power to the bake and broil circuits according to the customer settings and sensor input. If the oven won't turn off it could be that one of the relays on the oven control board is shorted closed, providing voltage to the heating circuit. It can be dangerous if the oven won't turn off. Don't leave the oven unattended without turning off power to the oven.
Relay board:
Some ovens are equipped with a relay board. This circuit board has several relays which control the switching of electrical current to the oven heat source. If the oven won't turn off it may be that one or more of the relays on the relay board have failed. If this happens replace the relay board. The relays on the board are not sold separately. ALSO CHECK THE BAKE AND BROIL ELEMENT.
: I offer free advice bcuz God is so good!
Feb 13, 2012 | Whirlpool Ovens
My oven displays error f31. It beeps and when I press clear the beeping stops. But if I try and set the temp it reverts back to f31
The F31 fault code indicates a problem with the oven temperature sensor probe. The temperature probe is secured in the top of the inside back wall of the oven. Unplug the range to disconnect electrical power. Open the oven door and remove the racks. Remove the screws that secure the oven temperature sensor probe in the back wall of the oven. Carefully pull the sensor into the oven until you get to the wire harness disconnect plug. Unplug the sensor probe. Do not let the wire harness **** back through the opening in the back of the oven. Check the resistance of the probe with a volt/ohm meter. At room temperature, you should measure about 1100 ohms of resistance. Since you are getting the F31 fault code, you will not likely measure this resistance. If the resistance is bad, replacing the oven temperature sensor probe .This should fix your problem. You can order this part from the www.appliancehelponline.com If the resistance of the temperature probe is normal (1100 ohms), then I recommend that you access the electronic oven control board in the console (with the range still unplugged ). Remove the upper back panel. Pull the P5 connector on the control board and measure the resistance through the purple wires (pins 12 and 13 as shown below) to check the resistance of the temperature probe through the circuit that connects to the board. If the resistance is drastically different than the 1100 ohms measured at the probe, then the wire harness is bad and will need to be replaced. If you measure the proper resistance through this wiring harness at the control board and the connections are good, then the electronic oven control board will need to be replaced.
Mar 23, 2010 | Ovens
When I try to set a temperature, F9 appears. I have tried to turn off power by flipping circuit breaker. The power was off and I set a temp, then turned it off and F9 appeared again with "lock." Any...
The most common cause of a F9 error code is a problem with the door latch circuit. There could be a pinched wire for the circuit causing a short or the door latch motor is defective. Sometimes a problem with the ERC can cause this error to appear. Possible problems can very slightly from manufacturer for this error code but almost all use the F9 error code for the oven door lock.
Jan 14, 2010 | Ovens
My thermador oven tells me error code 14
Sometimes you can unplug the unit for at least 30 minutes and reset the unit and it wont do it again.Try that first. An error code on a thermador of 14 means latch switch problems.
May 12, 2009 | Thermador SMW272 Electric Double Oven
F6E0
Last night I saw the lights in the house flicker momentarily... This morning, I turned the oven on, set it to Bake and within a few seconds, the control panel reported error code “F6 E0” then shut the oven off. The control panel also reported "Lost communication...". I read on another site that this code may require replacing the control panel itself. Apparently, the momentary power fluctuation wasn't large enough to damage the electronics (since the control panel still works), but was significant enough to confuse the electronics controlling the oven. To fix the oven, I simply turned the 30 AMP breaker for the oven off for about 5 minutes. When I turned it back on, the oven worked just fine. Solution #1 recommends taking off the control panel, which voids the warranty. It's more likely that it was fixed just by cycling power to the oven via the breaker.
Oct 27, 2008 | KitchenAid Architect Series KEBC107KSS...
F31 error
it is a shorted oven probe sensor
Apr 09, 2008 | Ovens
GE Profile JTP18 Electric Single Oven Logo
100 people viewed this question
Top GE Ovens Experts
William Miller
William Miller
Dan Webster
Dan Webster
Are you a GE Oven Expert? Answer questions, earn points and help others
