Question about Dell Inspiron 1525 Laptop
My wireless switch is turn off, how do I turn it back on?
    Master:
  • 497 Answers
Take this link to your models Updates/Downloads Site. I recommend that you do Any/All Current Updates for your system. That should take care of your issue.
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=19&l=en&s=dhs&os=WLH&osl=en&SystemID=INS_PNT_PM_1525&catid=-1&impid=-1
Posted on Jul 14, 2010
  • 734 Answers
Step 1
Check the front and sides of your laptop. Their may be a switch that you slide to turn your wireless capabilities on or off. If there is a switch, slide it to "on." Your internet should be working.
If there is no switch, move on to step 2.
Step 2
Look up at the top of your keyboard. If there was no switch on the front or sides, there will be a key (in the Function keys, F1, F2, etc) which has a picture of an antenna on it. Push that button.
Your internet should be working. If not, go to step 3.
Step 3
If you found the key with the picture of the antenna/tower on it and pushing it didn't work, sometimes you have to hold down the "Fn" (Function) key while pressing the antenna/tower key.
Your internet should be working!
I have a toshiba satellite p 775D pc. it says the hardware radio switch is off. how do i turn it back on and where is it?
Look on both sides of the computer and in front of the computer for a switch that controls the wireless.
Once you turn it on your wireless should come back. Also once you have the switch turned on there is another way to toggle the wireless on and off by hitting a set of keystrokes. If you Press and Hold the FN function key at the lower left part of the keyboard, then hit the key that controls the wireless (F1 thru F12) you can toggle the wireless off and on. The correct F1 thru F12 key will have the wireless icon )))) signal on it or it might have a tower with a the wireless icon )))) signal. Once you Press and Hold the FN key, then hit the correct F1 thru F12 key to toggle the wireless a message will probably appear on your screen that says Wireless On or Wireless Off.
Apr 21, 2012 | Toshiba Computers & Internet
Wireless switch is broken cannot turn on wireless adapter
Dear Friend,
If the wireless switch broke, you might need a flash light and something very thin and long to turn it back on. Now, if the switch attached to the motherboard broke as well you need to think about getting another motherboard.
You might want to consider and external USB or PCDM wireless card if you cannot turn it on.
Good Luck!
Jan 02, 2012 | Acer Extensa 5620 Notebook PC
Wireless communication switch is disabled. I am not able turn on wireless communication switch. I was wondering if Toshiba a135-s4527 has a built wireless hardware????Vista SP2
When you say oyu cant turn on the wireless switch does that mean after flicking the switch usually located on the front or side of the laptop it sitll doesnt work. or have you tried holding the function key (fn) and hit the wireless symbol key on your keyboard it looks like the letter i with circles around itusually on the f8 key. by holding fn then f8 key it should turn it back on
May 07, 2011 | Toshiba Satellite A135-S4527 Notebook
I am having trouble connecting to the internet because my WLAN has been turned off, how do I turn my wireless back on?
From the HP website:
The power to the wireless network and bluetooth devices is controlled by a switch or button on most computers. It is possible to accidentally bump the button and turn off the wireless service. c02230159.jpg On most computers, there is an LED light that glows blue when the wireless device is turned on and enabled, and glows orange when off or disabled. Some newer models use different a different color scheme. To turn on and enable the wireless device, do the following:
  1. To turn on the wireless device, simply move the switch to the on position. On some computers, the switch is actually a touch point on the panel above the keyboard.
  2. To enable the wireless device, right-click the HP Wireless Assistant (disabled) icon c02228164.gif and select Open Wireless Assistant . Click Turn On . The HP Wireless Assistant (enabled) icon c02228163.gif will display.
Apr 18, 2011 | HP Pavilion dv4000 Notebook
Cannot the wireless internet setup
Hi kschmerer,
I understand that you are not able to setup the Wireless Network Connection in your Computer.
To fix this issue, please make sure that the Physical Wireless Switch on the Computer is turned ON and then try connecting the Computer to the Wirelss Network.
You can locate the Physical Wireless Switch on the front side of the Computer. Please move the switch toward right side to turn it ON.
Once the Physical Wireless Switch is turned ON, please try setting up the Wireless Network Connection.
If you are not able to to connect to Wireless Network Connection after switching on the Physical Wireless LAN Switch, try using the Wireless Switch Setting Utility.
To enable the Wireless Network Connection using the Wireless Device Switch Utility, please double-click the Wireless Device Switch icon on the right corner of the Taskbar. Then in the open Wireless Device Switch window, please click to check the box next to Enable 2.4Ghz Wireless LAN.
This should fix the issue.
Please post back if you have any questions or require further assistance.
Thanks for using FixYa.
Dec 07, 2010 | Sony VAIO VGN-AR150G Notebook
Wireless on my Dell Latitude E6400 switched off and I can not turn it back on. Any idea?
Press on F2 when turning back the laptop by going to the BIOS setup screen and from there have to enable your WIRELESS CONNECTION. And then have to manually TURN ON your WIRELESS device by enabling or turning ON the Wireless button of the laptop. Thank you.
Apr 11, 2010 | Dell Latitude E6400 Laptop
Turn on wireless switch and laptop turns off and back on, internet working fine with the cable from hub but cannot turn on wireless switch, blue screen with alot of txt flashes and laptop restarts
1. It's a bad memory problem! (Blue Screen)
2. Try to close unneccessary processes / software using Task Manager before switching ON wireless!
3. Now, switch ON wireless.
4. If it don't work, reinstall the wireless driver!
5. Restart ur system.
tell me if it helps...tc! :)
Nov 25, 2009 | Toshiba Tecra A1 Notebook
The wireless network won't connect
Yes, the switch is at the back.
The LifeBook S is equipped with a Wi-Fi (802.11b) receiver; the antennas are inside a long, black plastic panel that runs along the top edge of the lid. The wireless receiver's on/off switch is on the back of the notebook, where the power switch was located in earlier models. Meanwhile, the power switch has moved to a more convenient location on the side of the unit, next to the FireWire port.
Wireless LAN/ Bluetooth ON/OFF Switch
The switch allows you to turn on and off the Wireless LAN/ Bluetooth communications. Slide the switch to the right to turn it on, or slide the switch to the left to turn it off.
Nov 26, 2008 | Intel S6240 Notebook
Gateway 7324 laptop wireless switch
I just spent ages looking on the net for the solution on how to able and disable the wireless on my Gateway NV54 series. I finally gave up only to accidentally touch the wireless light only to find that was the switch. Its a touch switch along with the volume controls and volume mute.
Dec 27, 2007 | Computers & Internet
Wireless radio switch
Page 13 will show you the radio switch. It is the 4th button.
Wireless switch Turns the wireless feature on or off, but
does not create a wireless connection.
✎ A wireless network must be set up in
order to establish a wireless
connection.
http://h10032.www1.hp.com/ctg/Manual/c01035586.pdf
Dec 25, 2007 | HP Pavilion dv9000z Notebook
Dell Inspiron 1525 Laptop Logo
153 people viewed this question
Alun Cox
