Have to click on items several times to get it to work then it gets stuck on
  • 1,511 Answers
Hello and Welcome to FixYa!
It seems that you need to re-install/run recovery on your system. Your system is overloaded with softwares and applications or the operating system files are getting corrupt due to virus/threats infections.... Restore your system or run the recovery to get rid of the trouble...you are facing....
Best of Luck,
Please do RATE the solution, if found Helpful,
Concerned.
Posted on Jul 14, 2010
Locked the keys inside.
Slim jim works all the time. This may sound nuts, but I proved it to work. If someone has a second key fob and a cell phone, have them click the unlock button several times really close to the phone. You get real close to the antenna and watch the doors unlock. This , of course works when you're stuck in a parking lot and the other key fob is miles away.
Aug 30, 2016 | GMC 2002 Yukon SLE
How do I delete items on favorites bar that are showing up several times
right click your mouse on the item and then delete that will get rid of the extra you will need to do this to all the ones you want to get rid of
Oct 17, 2013 | GPS
Polycom 501 phone keeps trying to reboot itself. We rebooted manually a few times and get the same error message: 'Could not find boot server current configuation" Any ideas?
try to turn off the Polycom device. When you turn it back on, press Setup. from the options, select server then click edit. Then select the item Trivial FTP (that setup depends on your ISP), and type the IP address assigned to your network (example 192.168.90.90) then hit OK. click exit several times then press Save & reboot. If it did not work, let us know...
Jun 19, 2010 | Polycom SoundPoint IP 320 SIP IP Phone
Document stuck in que, can't delete, can't print i can delete the other ones after the first one, but the first one is stuck. tried to delete several times, won't allow it. tried to unplug printer, shut...
I'm not an expert, but this usually fixes my printer when this happens. Go to Start, Control Panel, Administrative Tools, and then Services. You will see a long list of items. Scroll down to Print Spooler. On the left hand side you will see buttons to Stop and Restart Services. Click on Stop and wait until it stops. Then click on Restart. Try to delete the item from the printer que again. If it doesn't work, do the same steps as above, but between the Stop & the Restart, try to delete it then. This works for me. Good luck!
Mar 04, 2010 | Dell A940 All-In-One InkJet Printer
Help
The problem could be due to keyboard key stucking or malfunction.
For example,if Ctrl key is stuck whenever you clikc anything with your mouse pad it will automatically select those items. Similar case with Shift key too.
Blow your keypad with an Air-blower and if you can take out every key,it will be more fine.
your problem will be solve. if you have never laid any hand on computer hardware, get someone who can do it for you.
Jan 11, 2010 | Acer Aspire One PC Notebook
Delco tape deck in 1992 buick regal: when instert tape clicking several times and ejects the tape
its time for a replacement unit. these radios now days only last so long. there are several cleaning items that you can use however dont expect any miracles or any longevity.
Nov 09, 2009 | 1992 Buick Regal
Ipod Click wheel 20g is stuck plug into outlet mode after restore
I purchases the premiun service, but was not able to get the problem solved. The expert had me do the items in the manual, which I had already done. Any more suggestions?
Apr 21, 2008 | Macally iPocket MAIPOCKET
Copying
Please explain if you are in netwrok.... also try this step.
Click on start button and select run if youhave Win XP.
Tye msconfig in the run window and click on ok.
Click on the startup tab and then disable all startup items.
Click on services tab and select hide all microsoft services.
Click on disable all. (Hide all microsoft services is imp - do not miss that)
Click on apply and reboot.
Now try working on your system and check if this issue resolves by itself.
If the issue gets resolved we need to check your services tab and start up items which must be causing thisissue.
also reply if you have norton installed...
Please explain in detail any error messages while you try to copy
Also explain if you have windows live care installed in your computer
Nov 17, 2007 | HP PSC 950 All-In-One InkJet Printer
Computers & Internet Logo
David Payne
David Payne
