Question about HP LaserJet 2840 Printer
When initializing or beginning a print job we hear a grinding noise like gears slipping. Any suggestions?
    An expert whose answer gotĀ voted for 100 times.
    Novelist:
  • 123 Answers
Hello Joan !
You need to be a little bit more specific next time, where does the noise is comming from ?
I would try turning the printer off, taking all supplies out ( cartridges and imaging drum)
Turn the printer back on and check if you still have the noise
Most of the times this kind of noises are related to a defective Toner cartridge, so if you dont hear the noises anymore after powercycling you can tell that the problem is one of those cartridges
Then you can install one by one to see which one is the one giving problems
Now, If you determine that the problem is not on one of the cartridges, then the problem may be related to a defective roller inside of the unit.
If the printer its still under warranty you can call hp tech support (1 800 334 51 44) or take the printer to a Local Hp Repair Center
This link can help you find one near you :
http://h20465.www2.hp.com/GPL/search.aspx?language_code=en&country_code=us&SearchType=SSP
You can contact me directly on : eliteprintersolutions@hp.com
Posted on Jul 14, 2010
Testimonial: "Excellent advice on trouble shooting a printer problem. We identified the problem within 5 minutes and arranged for a replacement part! Thank you!"
Service manual
Any time I hear that complaint I cringe. Not because of the noise but what it might be telling me. I usually hear that noise as the hot roller bushings &/or the main gear that drives the fuser is cracking or already cracked and is ready to fail. This causes the roller to bind up hence, the grinding noise. Sometimes a drum can seize and that will also make that sound but if you're able to print OK that is probably not the issue.
Oct 24, 2013 | Epson ACULASER CX11NF All-In-One Printer
Tip
Noise while printing - Diagnosis Pt 1
<p>Unexpected noise (such as clicking, thumping, or grinding) from an branded device are heard during printer operation.<br /> <br /> <span><b>NOTE: </b></span><br /> Noises can be caused by a number of things, some of which may not be addressed in this document. This document deals strictly with the isolation and potential resolution of known noises through troubleshooting.<br /> <p>The following table describes some of the noises to be expected in a printer functioning normally:<br /> <span>Noise occurs:</span> <br /> <span>Additional information:</span> <br /> During power-up<br /> When the printer periodically makes humming and buzzing sounds as the carriage assembly moves around on the right/left side of the printer, the printer is actually cleaning the ink cartridges. This is a normal operation for the printer. This sequence may happen in the following conditions:<br /><br /><br /> <ul> <li> <p>Before and/or after printing<br /> <li> <p>During power on <br /> <li> <p>After the printer has been on standby/idle for some time<br /> <li> <p>After replacing a cartridge<br /> <li> <p>In the middle of a long print job (such as printing many photos)<br /></li></ul> During printing*<br /> <ul> <li> <p>Paper pickup: There will be some noise during paper pickup due to the movement of rollers and gears.<br /> <li> <p>While printing: The unit has printed a few lines or the paper has been fed into the printing area. There will be some noise during printing due to the movement of rollers, gears, carriage and paper (paper feed and ejection).<br /></li></ul> During paper ejection*<br /> At the end of the print job, there is a louder clicking noise as the paper is being "pushed off" to the output tray.<br /> During copying/scanning<br /> The scanner may make pulsing and dragging noises as it scans portions of the document or it may make a long rolling sound if it is doing a continuous scan. After scanning, it will make a long dragging noise as the scanner is brought back to the home position (could be on the left or right side).<br /> Post-printing with no additional jobs in the queue<br /> Post-completion of a print job and without another job in queue: At the end of a print job, there will be a noise on the left/right side of the printer as the pens are being capped. The printer may try to do this a couple of times, which is normal.<br /> Between print jobs<br /> The printer may make humming and buzzing sounds as the carriage assembly moves around on the right/ left side of the printer during the cleaning of the ink cartridges.<br /> In the accessories<br /> There may be some noise associated with accessories (ADF, duplexer, etc.) during the initial positioning and during normal operation.<br />
on Mar 10, 2011 | Office Equipment & Supplies
WHen under load the motor revs up and it seems that the Clutch is slipping, it has 100000miles and I suspecting the clutch or the high / low range might be messed up, its a 4 plus 3 manuel transmission.
If it feels like the clutch is slipping, chances are it is. If there was a problem in any component that has internal gears, you would have grinding noises. Gears cannot slip. As the clutch wears more you may hear grinding when you try to change gears but that is because the clutch won't fully disengage so the gears are spinning too fast to shift properly. Before that happens, have the clutch replaced.
Aug 02, 2011 | Chevrolet Corvette Cars & Trucks
Canon MX7600 error 5100, 5C20
Yes, 5100 means the carriage is not moving back and forth properly or there is grease on the encoder strip behind the carriage assembly. Grease spots make it lose count and slam into the side and grind gears. You need to clean the strip with a Q-tip moist with alcohol, but very carefully, not too much pressure on the strip.
Dec 13, 2009 | Canon MX7600 Office All-In-One Printer
Our whirlpool 5232d top loader is making grinding noises at the beginning of the wash cycle and the agitator seems to be slipping on its spindle though a little further on into the wash cycle the grinding...
Sounds like a bad transmisson or you room temp is below 30 making the oil in transmisson like tar. Or its just the dogs or top gears in the adj.
Nov 11, 2009 | Refrigerators
When i print, the printer makes a grinding noise the paper gets jamed also.
Remove the fuser unit and check if there is a residue on the side of the gears. If so, you 'll have to replace the swing gear assy. Partnumber 5851-2766. It is not an easy job!!!
Gerrit Jan
Oct 28, 2009 | HP 4250 Monochrome LaserJet Printer
Grinding noise only when printing a large print job
It is passable the grinding noise is coming from one of the toner cartridges in the printer.
Check for any toner cartridges which are stiff or difficult to turn by hand
Replace and refilled toners or compatible toners with original manufactures toners.
If you have alternative toners available replace each toner in turn to see if the cause can be identified to a particular toner.
Mar 26, 2009 | TallyGenicom 8008 Laser Printer
4250 grinds
It needs to be looked at by a technician to see it there are any broken gears in it.
Jun 13, 2008 | HP LaserJet 4250n Printer
HP LaserJet 2840 Printer Logo
191 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
