Question about Toro LX466 22HP Lawn Tractor 13RT61RH244
Need toro lx460 dirve belt schematic - Toro LX466 22HP Lawn Tractor 13RT61RH244
    Champion:
  • 225 Answers
Transmission drive or cutter deck drive?
Posted on Mar 08, 2015
2 Suggested Answers
vrb2
SOURCE: how to tighten belt on aToro LX460 V twin
it may have stretched and needs a new belt there is a spring tensioner that can only go so far
Posted on Aug 07, 2012
What is the size of drive belt for toro riding mover lx460
Refer your inquiry directly to Toro or a local Toro dealer.
Jul 27, 2014 | Toro Garden
How to change the belts on toro timemaster
Type toro.com and the model of your mower they have schematics that will help you.
Jun 17, 2014 | Toro TimeMaster 30" Self-Propelled Lawn...
Jerky movement
there are 2 drive belts that control the transmission. 1 is a variable speed drivebelt going from the engine back to the trans. it is the long one. the shorter belt drives the trans. off of the other variable speed belt. both belts are located under the mower and are not fun to get to. I would bet that one of these belts are slipping and grabbing, giving you the jerky ride. visually inspect for cracks or peeling, then check tensioning system for the belt to make sure they have the correct tension. less likely would be in the geardriven trans. it might act that way if some teeth of the gears inside are worn or broke. one other thing to check if all else looks good.... the variable belt drive pulley expands and contracts to change speed of the transmission input. I have seen these pulleys fail to operate correctly and this could also cause the ride to ****. hope some suggestions here help. R
Aug 23, 2012 | Toro Power Lawn Mower
How to tighten belt on aToro LX460 V twin
Apr 20, 2012 | Toro LX466 22HP Lawn Tractor 13RT61RH244
I need to replace the belt for the mower deck of riding mower. Need schematics. Model #78260 serial #4900572
Jump onto www.toro.com and download the free service manual for your machine. Note down all the details on the ID plate on the mower, you will need it to find the correct manual.
Aug 27, 2011 | Toro Garden
How do you hold the blades on a toro LX460 while breaking the nut loose to change them
Use a piece of 2x4 and a clamp. Clamp the wood to the inside of the deck using the clamp. When the blade comes around and bumps against the wood it should act as a stop. Or you could rig something with a Vise-Grip plier. Lock onto the blade with the Vise-Grip, run a piece of rope from the pliers to a point on the mower where it will stop the blade from turning.
May 23, 2010 | Toro Lawn Mower With Toro Power Tools
Toro Lawn Tractor won't start, engine turns
best guess , blocked main jet or water in the carby
an overhaul would be in order
Oct 24, 2017 | Toro Lawn Mower With Toro Power Tools
Mower will not start,changed plug,new gas,has fire to the plug still will not start,backfires once in a while checked the fues it is ok,it is a lx460 mod# 13AX60RH744, cleaned the points etc,
Replace the air filter. Remove the plug and try to start it. If you don’t smell the gas your problem is fuel. Most have a primer button that needs to be pressed 3 times. Remove the air filter and press the primer button to see if you squirt fuel. If it has no or little smell, continue priming and starting until you have fresh fuel. Replace the filter and plug. Disengage the pto ect ( saftys)before starting. Here is the manual Don’t forget to follow the safty startup list.
http://www.dixiesales.com/ipl/339/13ax60rg744_operators_manual_02_22_06.pdf
Aug 17, 2009 | Toro Lawn Mower With Toro Power Tools
What length is a deck belt on a toro lx460
1/2" x 90" ; Toro P/N 112-5834
Try:
http://www.tractorsupply.com/outdoor-power-equipment/mowers-attachments-accessories-parts/mower-parts/mower-belts/huskee-v-belt-1-2-x-90-in-4461290
for $19.49 if you have a Tractor Supply Company nearby.
Or:
http://www.texasmowerparts.com/catalog/products.asp?ds=DETAILED&category_id=47&group_id=184&section_id=585
# Replaces Toro 112-5834 # 1/2" X 90"
for $14.17 + $5.95 shipping
Danotex
Jul 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro LX466 22HP Lawn Tractor 13RT61RH244 Logo
719 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
