Question about Microsoft Xbox 360 Console
X box 360
I get nothing to the console. the power cord has an orange light ive un plugged it and plugged it back in it still stays orange
    Problem Solver:
  • 9 Answers
Orange means = stand by
Green= its ON
Red= theres a problem (usually power supply overheating)
There could be many reasons as to why your console wont switch on such as broken power switch, faulty / damaged power cord / supply unit, or over heating has damaged the console.
If possible try using teh power cord in another xbox 360 console to eliminate the cable being the problem.
If the problem still exsists all that you can really do from there is send it to the xbox repair center.
You should be able to get it fixed free of charge.
if you have a game or dvd in there you cant get out unplug teh console and remove the face plate. depending on the dvd drive manufacture in your xbox you may / maynot be able to see some small black cogs at teh front of the dvd drive inside the actuall dvd drive unit. spin these with a small techinical screwdriver and the the tray will start to slide out with each spin.
Not very technical or approved but does the job.
hope this helps
Anthony Kinson
Posted on Apr 22, 2008
When i turn on my xbox i'm getting 3 flashing red lights what does this mean
it means your xbox is overheating, you can send it back as they extended the warranty on it for this common fault unless you have modified it, in which case look up ring of death on youtube.
Jun 13, 2011 | Microsoft Xbox 360 Elite Console - Black
Power box light is blinking orange and sometime a steady red and console want come on.
Green Indicator Light:
The default indicator light is green. When the Xbox 360 power supply light is green it means that there are no problems with your power supply. However, if you are having problems and the power supply light is green, this means that the console is faulty and you need to contact Xbox 360 support.
Orange or Yellow Indicator Light
When the Xbox 360 power supply light is orange or yellow this means there is no problem with your console but the power supply can't supply it with power.
To remedy this problem, first try unplugging the Xbox 360 power supply from the console and unplug the power cord from the wall outlet. You'll also want to uplug the Xbox 360 power supply from the power cord.
Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If you are still getting an orange or yellow indicator light, then something is at fault with the Xbox 360 power supply. If this is the case, contact the Xbox 360 customer support to get a new one.
Red Indicator Light:
If the xbox 360 power supply light is red, then there is something wrong with the power supply connection. If this is the case, try the same solution as listed above of unplugging the power supply from the console, unplugging the power cord from the wall outlet and unplugging the power supply from the power cord. Wait for about five minutes and then reconnect everything. You might also want to try plugging it into another wall outlet without an extension cord.
If the indicator lights are still red, then there is a fault with the power supply. If this is the case, contact customer support about getting a new one.
No Indicator Light:
If the XBox 360 power supply light is not illuminating at all, this usually means that the Xbox power supply is not connected to the wall outlet correctly. On the other hand, it might also be a fault with the power supply or the power cord.
Either way, try the same solution as listed above for the red indicator lights. If you still don't see any lights illuminated after unplugging and then reconnecting everything, you'll need to contact customer support about getting a new power supply.
Green and Orange Indicator Light:
If the indicator light is flashing green and orange, this may mean that the console does not detect the AV Pack.
Disconnect and then reconnect the Xbox AV Pack. Make sure the connections are firmly connected. Turn your Xbox back on.
If the indicator light is still flashing green and orange, try another AV pack if one is available.
If the indicator light is still flashing green and orange, you'll need to contact Miscrosoft Customer support.
Flashing Orange Indicator Light:
If your Xbox console's indicator light flashes orange, this means the internal components have overheated and the Xbox has automatically shut down to prevent damage.
Turn off the console and let it cool for at least 10 minutes.
To prevent the Xbox from overheating in the future, make sure that it's not placed in a closed cabinet or on carpet. It's best to get the Xbox elevated off the ground where the PSU can have maximum heat release.
You'll also want to make sure the Xbox is not located near a heat source like the back side of a television, computer, monitor, or other electrical device.
Aug 26, 2010 | Microsoft Xbox 360 Elite Console
My 360 does not have power to console. the light
Have you tried removing all extra accessories?
Xbox.com states:
Mar 01, 2010 | Microsoft Xbox 360 Console
Red light on power box for 360
i have to personally dissagree with 'wildbear' :-)
well not actually dissagree but i think the problem will be at lot less technical than all the writing he has done.
a simpler check.......does the 360 'switch on' ??
i assume with a red light on the power brick it dosnt ??
the problem is more likely a faulty pin (terminal) inside one of the USB slots you have been using for either a controller charger or wired controller (or a usb memory stick to play music thru ur xbox??)......plugging chargers/wired controllers in & out of either the 2 front slots (behind the flap) or the 1 at the back can sumtimes bend one of the terminals causing it to touch the outer casing of the usb slot ?? if it does this it shorts the board of the 360 which in turn stops u powering up the 360 all together :-(
one of the signs of this is a 'RED' light on the power brick & the 360 not powering up at all !! but sumtimes the power brick light will stay orange or even green.....even with this fault ! it dosnt always turn red !
One way to rectify it is (un-plug the powere brick from the mains first) & unplug ALL USB CONNECTIONS TO THE 360 !! (controller chargers ect) & try powering up the 360 !! (after plugging it back in)
if this fails ur gonna need a torch & a little screw driver (or tweezers) un-plug everything from the 360 & look inside ALL usb slots you have used ! check to see if any of the prongs have bent accidently whilst plugging in & out chargers ect ..... if they have straighten them so they are not touching any of the sides of the usb slot....
after doing this ...plug back in and 'hopefully' Whoooop Whooooop :-)
hope this helps ??
failing this it maybe as wildbear suggests & its a problem with the power brick altho i very much doubt it ?? they normally way out live an xbox !
remember thumbs up if this helps :-)
Jan 01, 2010 | Microsoft Xbox 360 Console
My 360 won't work. It will turn on but thescreen stays black and the controllers wont connect. It isn't making the noise when it turns on either. I un-plugged and plugged back in the Video and Audio...
If your Xbox 360 does not have display you need to stop the heat getting to the chips. You can actually do this yourself as many have in this forum using the recommended Xbox 360 Repair guide.
Basically the guide will show you how to stop the heat build up with videos and household items, of course if you are in doubt send it in.
It has a preview video on the website.
Or of course you can send it in to have it fixed.
Dec 29, 2009 | Microsoft Xbox 360 Console
Power brick colour
Alright, lets fix this!
 Xbox 360 power supply light is orange or yellow.
Usually when the Xbox 360 power supply light is orange it's on standby so there is no problem with your Xbox 360 console but the power supply can't supply it with power !
First you have to try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for a minute then reconnect it all back , also try it on another wall outlet without any extension cords at all.
If it's still doing the same it will be definitely a fault with the Xbox 360 power supply.
So, in this case please contact Xbox 360 customer support to fulfill the Xbox 360 power supply.
Xbox 360 power supply light is red.
There is something wrong with the Xbox 360 power supply connection so try unplugging the Xbox 360 power supply from the console & unplugging the power cord from the wall outlet also unplug the Xbox 360 power supply from the power cord, wait for minute then reconnect it all back , also try it on another wall outlet without any extension cord at all.
If it's still red that would be for sure a fault with the Xbox 360 power supply .
So, then contact Xbox 360 customer support to fulfill your Xbox 360 power supply .
You can also find replacement power cords many places online. See if you can get your hands on another cord and try that to see if its the current power cord.
Hope this helps you out! Please don't forget to rate :)
Apr 10, 2009 | Microsoft Xbox 360 Console
Xbox360
Sep 06, 2008 | Microsoft Xbox 360 Console
My xbox 360 won't turn on!!!
yo i tried everything and it turned out to be what one dude on her said about the usb ....if u look close in the usb port ...ther is 4 things sticking out ..in one port they were all straight ...in the other port they were crushed up against the wall so i took a knife and smashed them back down away from the wall make sure they are pointed down AWAY from the walll i cant plug a controller in that port but i can the other port.....soooooooooooooooooo it dont matter and bammmmmmmmmmmmm it came on i started **** in front of everyone
May 10, 2008 | Microsoft Xbox 360 Console
My xbox 360 power cord box messed up....
check your Audio/Video cable connection, sometimes those lights means that the plug isn't in the xbox/tv all the way
Jan 06, 2008 | Microsoft Xbox 360 Console
360 No Longer Turns On
By cord, do you mean the entire AC convertor box? Does the orange light on the convertor box light up? If you used your friends whole ac wire/convertor box (w/ the plug that goes into the xbox itself) and THAT didn't work, then your motherboard took a surge. It is probably trashed as they are VERRRRRRRY sensitive and prone to failure. Time for a new one (or a warranty "repair").
Sep 12, 2007 | Microsoft Xbox 360 Console
Microsoft Xbox 360 Console Logo
Top Microsoft Video Game Consoles & Games Experts
Troy Gorman
Troy Gorman
Pablo Gonzalez
Mike Neath
Mike Neath
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
