Question about Brother MFC-7220 All-In-One Laser Printer
The printer says back door open when its not - Brother MFC-7220 All-In-One Laser Printer
    President:
  • 405 Answers
Open the front cover and remove the drum and toner(cartridge) There should be a paperjam in the machine. It reads back cover open because the piece of paper is covering the sensor for the back cover.
Posted on Jul 15, 2010
My laserjet pro 400 color mpf m475dn printer is indicating " paper jam...open back door to clear jam," please describe how i will go about this process.
There is an access door in the back of the printer. Open the door and you should see jammed paper. If not then you have a faulty sensor or switch.
Mar 20, 2014 | HP LASERJET PRO 400 COLOR MFP M475DN
Hp cp2025 error reads "front door open" when front door is closed
pront door liver switch open not work it ,or it displace.you should check it or service need
Sep 12, 2012 | HP Laserjet Cp2025n Printer
Brother all-in-one printer not working; error 'back door open'
Open the front cover and remove the drum and toner.
Jun 02, 2010 | Brother MFC-7220 All-In-One Laser Printer
Blinking orange light on hp 932c
Solution
  1. Check to ensure that the top access door is firmly closed.
  2. If the light continues to blink, open the top access door. When the top access door is opened, the print cradle moves so the yellow arrow on top of the cradle points to a drawing of a cartridge. Each drawing describes a symptom.
Solution two:
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
Solution three:
The print cartridge carriage is stuck.
Solution
1. Open the top access door on the printer.
2. Remove the ink cartridges.
3. Turn the printer off, then on again.
4. Replace the ink cartridges.
5. Close the top access door.
Solution Four:
Issue
The 2-Sided Printing Module is installed incorrectly, not at all, or the back access door is unlocked or open.
Solution
1. Turn the knob on the rear access door of the printer counter-clockwise, and remove the door.
2. Insert the module into the back of the printer.
3. If the lights remain on, remove the 2-Sided Printing Module by pressing in the buttons on the ends of the unit.
4. Re-install the 2-Sided Printing Module by pushing the unit back into the printer without pressing the buttons, until it snaps firmly into place.
Jun 17, 2009 | HP DeskJet 932c InkJet Printer
Dell Laser MFP 1815 won't print. Message keeps coming up Jam 2 open rear and front door. Have opened and shut doors repeatedly, restarted printer, tried copying over message but it keeps being displayed....
I had same problem. If you go to rear of printer and open the back door you'll see it is attached to a blue connector. Unattached it so that the door opens fully and then unflap the inside roller assembly. Next open the fuser door and you'll notice a little spring loaded assembly on the inside of the opened fuser door. This is where my problem was. Make sure that the assembly springs back when pushed because part communicates with a sensor on the motherboard. If it doesn't spring back then the printer thinks there is a jam. Mine was stuck but after pushing it a few times it started to work freely again. This was a frustrating problem but that fixed my issue and hopefully it will fix yours.
Jun 04, 2009 | Dell 1815dn All-In-One Laser Printer
Can't get the back door open to remove jammed paper. How do the levers work?
I downloaded the user guide and saw a picture illustration that showed how to open the back door of the printer.  I was then able to follow the visual directions on the printer LED to remedy the paper jam.
May 28, 2009 | HP PSC 2355 All-In-One InkJet Printer
Back door cutoff switch broken
ok make sure the back door is fully shut.by opening it again and closing it firmly. If that doesnt fix the problem then unplug the printer and let it sit unplugged for 3 minutes. That will reset it.
please mark this answer as a fixya!
Mar 13, 2009 | HP DesignJet 750c plus InkJet Printer
Toner lite will not go out or print
A couple of suggestions
1) Open door and remove drum and toner. Hold Go button down until all lights are on. Put drum and toner back in and shut door.
Another is.
1. Switch off printer
2. Switch on printer
3. Open front door
4. Remove toner/drum unit
5. With the door still open hold down the go button for 1 second
6. Put the toner/drum unit back in
7. With the door still open hold down the go button for 1 second
8. Close the door and press go to test
Apr 25, 2008 | Brother HL-5240 Laser Printer
HP6310
Something is holding the top cover on the printer open enough so it is not pressing the switch to tell it it is closed, OR there may be a back door on the printer that is not fully closed. Many printers have an access door in the back for clearing paper jams. If the back door is not fully seated and latched it will cause an error.
Mar 18, 2008 | HP Officejet 6310 All-In-One InkJet...
Back door closed
I did not get any error message but the 6940 printer would not print. Instead "Ready" the printer said "door open". When I deleted printer and plugged the usb cable back in the XP machine found the new hardware, said "Ready" and could print.
Dec 22, 2007 | HP Deskjet 6940 InkJet Printer
Brother MFC-7220 All-In-One Laser Printer Logo
301 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
