Question about Dacor Kitchen Ranges
Looking to convert a Dacor SGM466 NG range to PROPANE
Looking to convert a Dacor NG range to liquid propane. Cannot find conversion kit. Is ther any way with typical parts available to acccomplish this?
  • 198 Answers
SOURCE: Natural Gas to Propane for Ge xl44 Gas range
The kit is located at the rear of the range right near the gas valve, there are probably 5 spuds and an extender for the large burner, directions are with the range. For the bake and broil you will need to tighten the brass orifice nuts down as tight as possible, also the brass nut on the gas valve needs to be reversed
your local LP dealer should be able to do this for you if you are uncomfortable doing it yourself.
Posted on Jan 27, 2009
SOURCE: Thermador PG484GGBS: How to convert from Natural Gas to LP?
I just did it with mine, I called thermador and they told me the number of the conversion kit to buy for my model.
I bought the kit from the retailer and did it myself, not very difficult.
no explosions yet :)
nic
Posted on Mar 26, 2009
  • 30 Answers
SOURCE: propane conversion
I used to order all my parts throgh a company called Arrow. It worked at a place of business that did LP & Propane conv. along with all installations so they may not sell to retail. You may also call Lowes, Home Depot or Sears and ask if they can get you the parts or know an installer who can sell them. Be careful.......they can be tricky and you could end up with a slight leak. They also take special tools. Incase you wern't sure or didn't know. Just be sure to test all installed new parts with the soap & water test!
Posted on Apr 26, 2009
SOURCE: how do I convert a dacor epicure range ERD48 from
Just change the orifices. Also adjust the pressure control regulator by reversing the built in plastic spacer, the regulator supplied is a dual fuel type. Any work should only be carried out by a person who is qualified to do so for safety reasons. Dacor are very unhelpful when I posed the same question directly to one of their technical advisors. The poor level of this persons 'technical' knowledge both surprised and concerned me.
Posted on Jan 30, 2010
  • 4 Answers
SOURCE: I want to convert to propane. Rinnai dont carry kkts for these anymore . . . . are there any way to convert these?
i want to convert one to natural gas from LPG would u like to swap the pilot assy and jets i cant find a conversian kit anywhere...
Posted on Aug 05, 2010
Converting a natural gas Webber genesis bbq to propane. Can you buy a kit to convert?
Hello, Kevin -
Do you mean a Weber (not Webber) Genisis grill? If so . . . see the information from the Weber grill company regarding the conversion of a natural gas grill to propane here:
https://consumer-care.weber.com/hc/en-us/articles/360001730474-How-can-I-convert-my-grill-from-liquid-propane-LP-to-natural-gas-NG-or-vice-versa-
Bottom line:
The Weber company does not recommend it and does not provide a conversion kit.
Best wishes.
Apr 30, 2018 | Grilling
Howcan i switch a dacor erd30 from natural gas to propane?
it requires different jets and the air mixer adjusted
it is a job for a gas fitter and not a DYI
Mar 31, 2015 | Dacor Kitchen Ranges
Where do i find propane to natural gas conversion kit for weber spirit e310 gril
Apparently, Weber does not make a conversion kit to convert the grill from propane or from natural gas to propane. According to the Owners Manual - "Liquid propane gas is not natural gas. The conversion or attempted use of natural gas in a liquid propane unit or liquid propane
gas in a natural gas unit is dangerous and will void your warranty." (From Page # 3 of the Owners Manual)
See below link.
http://www.weber.com/help/manuals/pdf_files/2008_updated/89525_030308_2008.pdf
Feb 23, 2011 | Weber Spirit? E-310 Propane Grill
I got a GE gas range (model JGBS22) from a co-worker. She had converted it from gas to propane. I just had a plumber hook it up to natural gas but, even with the conversion manual, he couldn't change the...
There should be a set of orifices for each burner as well as the oven and broiler. When the unit was converted to propane, these orifices should have been replaced and the ones for gas put in with the conversion kit installation information. The kit should have been reattached near the pressure regulator.
If the kit was missing the orifices, then, yes, you are missing pieces. Check with your coworker if the conversion kit was missing. If you have the kit, it can be easily done by any appliance installer (or repair person) licensed for handling NG. (At least on our range, the conversion kit installation was straight forward. Every orifice was clearly labeled with the labels different for each burner and for the gas/LP kits (ABCD (NG) vs MNOP (LP)) .) The regulator is the only part that switched for LP or NG without the kit.
As I recall, the only tools we needed for the top burners were a small wrench (10 mm) and a small flat blade screwdriver. Remove one orifice and put in the appropriate replacement. Then adjust the burners so that they didn't blow out when the oven was opened or quickly turned from high to low (for the simmer burner). The oven and broiler took a bit longer. Several screws had to be removed to get at the orifices. Then the air flow had to be adjusted for the incoming gas.
I hope this helps.
(the conversion installation manual was on the counter during installation; I read it while it was open.)
Jan 14, 2011 | GE JGBS22 Gas Kitchen Range
New BBQ chaged from propane to NG
Hello. The conversion of any gas appliance usually requires changing orifices, regulator and burner. Then once those changes are made you can adjust the gas flow. The difference in the orifices is this.
Natural gas orifices are larger than liquid propane orifices simply because the gas pressure for the natural gas is lower.
I would double check to be sure that you have installed the correct orifice. Also, you can adjust the amount of gas by turning the orifice in or out, using that socket.
Please call the uniflame technician directly if you still have a problem 800-762-1142 Joe
Mar 11, 2010 | Uniflame Corporation LP Gas Outdoor...
Hi I am trying to convert my Dacor stove/oven from NG to Propane. We can't find the conversion kit anywhere. Any ideas?
Hi, to convert from NG to LP is easier in some ways but harder in others. The pressure part is easy because LP runs at the same pressure that comes into the house so the regulator is normally locked wide open to allow a direct by-pass. You could just as easily remove the regulator and plumb straight in from the houseline. You don't say what model but usually the sealed cooktop burners will need smaller orifices and the oven and broiler orifices are adjustable. If that is the case, the oven and broiler orifices can be tightened until they bottom out which be the correct output for LP. You would need to remove the cooktop orifices and find replacements which are correct for LP, these are non-brand specific. Honestly, if you go to repairclinic.com and enter the brand and model number, I'd be surprised if you couldn't find the conversion kit. Even the Dacor site should be helpful. I found many different kits available at the repairclinic.com site even without a model number. Best of luck.
Jan 29, 2010 | Dacor Preference SGM365SS Gas Cooktop
Can a dacor range be converted from natural gas to LP liquid propane ??
I will trade you parts. I have the NG version and need to switch to LP.
Email me at adjuster@me.com.
Thanks
Jul 10, 2009 | Dacor Preference SGM365SS Gas Cooktop
Propane conversion
Apr 26, 2009 | Dacor Epicure ERD30 Dual Fuel (Electric...
JDS8130 Cooktop Conversion Kit : Propane to Natural Gas Conversio
here is a site that has gas conversion kits
http://en.allexperts.com/q/Major-Appliances-3603/Jenn-Air-gas-range.htm
Jan 31, 2009 | Jenn-Air 30 in.JGD8430ADS Gas Cooktop
nic
Dec 25, 2007 | Thermador PG484GGEBS Stainless Steel...
Kitchen Ranges Logo
119 people viewed this question
Top Dacor Kitchen Ranges Experts
Oloyede Monsuru
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Dacor Kitchen Range Expert? Answer questions, earn points and help others
