Question about Crystal Decisions NISSAN SKYLINE GTR R32
Loss of compression for my car - Crystal Decisions NISSAN SKYLINE GTR R32
  • 48 Answers
Most likely to be blown head gasket but could also be a hole in the piston or piston rings if the car is blowing blue smoke
Posted on Mar 04, 2011
What is a misfire in cylinder #1
Loss of compression means either piston or valve issues. You wouldn't know without a compression test with a gauge.
Misfire could be spark plug, coil or electrical issues.
Jul 24, 2017 | Kia Cars & Trucks
Can loss of engine compression be fixed?
loss of compression can be fixed
broken timing belt /chain or skipped a tooth
engine work required
leaky valves seats in the heads
or piston rings worn
Nov 26, 2016 | Buick Cars & Trucks
2002 3.7 litre jeep. How can I ck to see if a valve is fully closing? There is no lash adj. Springs look o.K. no compression #2 cyl. All others o.K.
You put compressed air into the cylinder an listen for the air escaping , if coming out of the throttle plate ,burnt intake valve . If you hear air coming out of exhaust pipe , burnt exhaust valve . If you hear air coming out dip stick tube bad rings or piston damage. How To Perform Leak Down Test EricTheCarGuy
Mar 02, 2016 | Cars & Trucks
I have a major loss of compression. could it be the catalytic converter or sensor. Need help please
No, the catalytic converter is the first part of the exhaust system and burns hydrocarbons to improve emissions. It has nothing to do with engine compression.
Loss of compression is inside the engine cylinders and can be caused by loose spark plugs, worn piston rings, pistons with holes in them, or incorrectly adjusted, worn or burnt valves or valve stems.
Oct 28, 2015 | 2007 Infiniti QX56 2WD
Running well but loss of compression after starting sometimes then last week driving along fine lost all compression have pulled fuel tank out checked fuel pump and it runs fine from a battery
Loss of compression is something else. What you are describing is a fuel pump issue and it sounds like a relay. Since you did not post what the year make and model is, we have no way of knowing UNLESS it is a jeep.
Aug 25, 2015 | Cars & Trucks
Vios 2004 1.3e manula something happen to the engine i'm not sure is it the igniton coil or the gasoline filter (loss compression) 65000km.....
IF there is a compression loss then have a compression test done to determine if so and which piston . If it is just a miss then isolate each coil until you find the faulty one . If you feel that it is fuel have a fuel pressure test done to determine where the fault is.
Jul 28, 2013 | Cars & Trucks
Overheated and loss compression.
The most common cause is a blown head gasket and sometimes a warped head. Someone would need to remove the cylinder head and have it checked for damage, then replace the head gasket.
Jul 15, 2013 | 2001 Mazda 626
I mark engine compression loss
i had the same problem with mine and it ended up being a burnt valve
Apr 27, 2013 | 1986 Isuzu I-Mark
Loss of compression why
Hi and welcome to FixYa!
A worn out piston ring is a general cause of loss compression. Have it replaced and you'll be good.
Hope this helps and thank you for using FixYa! Have a good one!
Dec 29, 2010 | 1995 Nissan Pickup
02 bmw 3 series. One in ten times when you try to start car thier is no compression
hav u used a compression tester on the vehicle-must read values to confirm--it may be other things that appear to be the problem-if there is a low reading then rings/valves/oilpress or heads are of concern
Sep 08, 2009 | BMW 318 Cars & Trucks
Crystal Decisions NISSAN SKYLINE GTR R32 Logo
79 people viewed this question
Top Crystal Decisions Toys Experts
Andrew Taylor
Andrew Taylor
ray gallant
Are you a Crystal Decisions Toy Expert? Answer questions, earn points and help others
