Question about Technics SL-1200MK5 Turntable
Turntable stopped working with Torq DJ Software
I have been using Torq software with technics 1200 mk5 turntables for three years now and one of my turntables just stopped working with the software. the turntable works fine just plugged into the mixer and even works if i use the knob on my torq interface to switch to input instead of usb. I have a lot of work coming up and i need this problem fixed asap but torq tech support is never open and they cost too much to get help.
  • 677 Answers
It could be either or none of them! It could be the fuse, but if there's any power present you could eliminate power switch, fuse, transformer or power supply. If no indication all of them are suspects.
More than likely the RCA cables need to be replaced. Torque, Serato, and all digital dj programs require a clear signal path coming from the source (turntable, cdj, etc). If it does not have a clear signal, or 1 side is louder than the other, it will not work.
You have to remember, these are analog turntables connecting to a digital system. The signal quality is different, and your RCA cables have to be prestine.
The following cables work very well for this type of configuration:
MOGAMI RCA CABLES
- OPTiC
The ORIGINAL 1200 TECHNICIAN.
Technics DJ Repair Videos
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Audio Video Accessories
Posted on Jul 14, 2010
  • dustin4rm Jul 14, 2010
    Thats what i thought the problem was but i wasnt sure if it was the rca or tone arm wires. i really appreciate the help and ill try out your suggestion.
  • ikechukwu joshua
    ikechukwu joshua Jul 14, 2010
    Hi,please don't forget to rate me.
    Take care.
I just purchases a Technics 1200 turntable for $70.00. I have found a problem, at the end of the album, the arm does not auto return, but just stays on the album. Could this be a simple problem,...
First off, Congratulations on such a excellent deal! That's a $500.00 turntable. I know I own a pair and I've been a DJ for 18 years.
Second, the Technics 1200 does not have an auto return. You have to pick up the needle and bring it back manually.
Feb 03, 2011 | Technics SL-1200 Turntable
I have a technics 1200 mk5 and when i put a record on the volume is low no matter how high i pt it up in the mixer. When i use it with serato it works fine. What can be the problem?
Years ago, Radio Shack sold a turntable with the same problem. The fix was to purchase a pre-amp to go between the turntable and the tuner/amp. I think this had something to do with a magnetic vs. ceramic cartridge?
Dec 14, 2010 | Technics SL-1200 Turntable
EVERYTIME I PLAY A RECORD IT DRAGS TO PICK UP SPEED
Are you sure you have a Technics SL1200MK2 Direct Drive Turntable? If so, then there is a major problem with the drive system. This can only be diagnosed and repaired by a qualified technician.
If your turntable is not the Techics SL1200MK2, and you have no idea what turntable you have, look at the model's label, if it says BELT DRIVE - this is the reason why it drags to pick up speed. If it says DIRECT DRIVE, then take it to a service center for repair.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Apr 02, 2009 | Technics SL-1200MK2 Turntable
Pitch problems
You would need to calibrate them to each other. Not very difficult, but not that easy either.
I would suggest taking it to a service center, and ask them to calibrate the turntables to each other. It's a matter of adjusting VR302, which is located underneath the turntable platter. You'll also need a frequency counter or similar - which aren't cheap.
- OPTiC
Technics Repair Videos
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Mar 15, 2009 | Technics SL-1210M5G Turntable
Technics SL 1600Mk2 turntable works, but turns off seconds later
The SL1600MK2 is a direct drive turntable. Meaning that there are multiple electronic components which make it turn. With that said, the only place you can start is the main circuit board. Unfortunately, this will not be an easy diagnosis without the proper testing tools - multimeter, and a scope to get you started.
Otherwise, you'll have to take it to a service technican for repair.
Unfortunately, all parts for this model are discontinued, so if it's something that is specific to this unit, it will be very hard to source parts.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 28, 2009 | Technics SL-1200MK2 Turntable
Computer not playing my technics table
MOGAMI RCA CABLES
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 18, 2009 | Technics SL-1200MK5 Turntable
Needle for Technics mk5
Ok, the needle is just a small portion of everything required to get up and running. Here is a diagram of what your going to need:
The stylus, also known as the Needle, is what you are asking for. As you can see it's only 1 of 3 items you need:
1) Headshell
2) Cartridge
3) Stylus / Needle
If you already have 1 and 2, and you need to replace #3, then we would need to know what model #2 is?
You'll need what's called a STANDARD Mount cartridge, (aka Half-inch). In addition, that cartridge will need to be mounted to a Standard Mount Headshell.
Here is a collection of Standard Mount Cartridges that will fit this model.
Try to stay away from those all-in-one configurations that look like the Concorde airplane. Over time they will damage your tonearm due to a poor design flaw. Stick with a set up similar to the image posted. You can't go wrong, and you'll have more options.
- OPTiC
Technics DJ Repair
Technics DJ Parts
DJ Parts
DJ Equipment Sales
Feb 15, 2009 | Technics SL-1210MK5 Turntable
One cdj and one turntable
This is possible, by connecting your turntable to the Line Input on the serato box. Then just connect both to your LINE INPUT on your mixer, and set the controls on your Serato Software to LINE INPUT - NOT Phono.
- OPTiC
Technics DJ Repair
Technics Parts
DJ Parts
DJ Equipment Sales
Jan 18, 2009 | Technics SL-1210 Turntable
Technics multiple play spindle wearing out it seems.
Need the model number. Technics released over 100 turntables between 1970-1990 - so a model number would help us in determining what you need.
- OPTiC
Repair Videos
Turntable Repair
DJ Equipment Sales
Technics Parts
Jan 03, 2009 | Technics SL-1200 Turntable
Technics SL-1200MK5 Turntable Logo
51 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
Ben Armstrong
Morne Olivier
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
