Question about HP LaserJet 2840 Printer
Getting error message that is page to complex
  • 223 Answers
If you are windows 7 and connected through usb its just a matter of changing a few settings.
under printing preferences change the raster compression to max and print data optimization to optomize for text and vector.
Also on the printer in the service menu make sure that the usb high speed is on.
If this does not fix the issue go to the hp website and download a universal post script print driver and change the settings under the advanced tab in the printing preferences menu.
Al
Eliteprintersolutions@gmail.com
Posted on Jul 14, 2010
Memory low message on hp laserjet pro 200
see HP LaserJet Pro Printers Memory is Low message displayed on the control...
HP LaserJet Pro Printers - 'Memory is Low' message displayed on the control panel HP LaserJet Pro - Troubleshoot 20.xx (memory failure) and 21.xx (print failure) error messages (ID: emr_na-c05049204)
HP Customer Support page and ensure the printer is running the latest available firmware. Print a Configuration Report from the control panel of the printer to check the installed firmware version.
  • If the printer supports expandable memory, you can install additional memory in the form of a DIMM. Check the printer's User Guide to see if it supports additional memory.
  • Break complex print jobs into smaller jobs that contain fewer pages.
  • If the printer is an MFP, delete stored faxes to increase available memory. Go to this document for instructions: HP LaserJet Pro MFP - Delete faxes from memory (ID: emr_na-c03264743)
  • Power cycle the printer to delete stored fonts or macros. It is possible to download fonts or macros in a way that power cycling the printer will not delete them; see Appendix A - Memory Allocation.
  • Changing some software and/or print driver settings might result in a less complex print job.
  • Use a different print driver. For example, a PostScript print driver will typically result in a more complex print file. If possible, try sending the file with a PCL6 or UPD printer driver.
  • Adobe PDF files can sometimes be very complex. Go to this document if printing PDF files is slow or resulting in memory out messages: HP LaserJet - Print job is slow or hangs in the print queue when printing Adobe PDF files (ID: emr_na-c04071740)
  • If the printer is connected via a network, try sending the file connected by USB cable only. This will eliminate possible network issues that are taking printer memory.
  • Appendix A
    Memory Allocation Utilities or jobs that you download to the product sometimes include resources (for example, fonts, macros, or patterns). Resources that are internally marked as permanent remain in the product memory until you turn the product off.
    Use the following guidelines if you use the page description language (PDL) ability to mark resources as permanent. For technical details, see an appropriate PDL reference for PCL or PS.
    • Mark resources as permanent only when it is absolutely necessary that they remain in memory while the product is turned on.
    • Send permanent resources to the product only at the beginning of a print job and not while the product is printing.
    NOTE: Overusing permanent resources or downloading them while the product is printing might affect product performance or the ability to print complex pages.
    Sep 08, 2016 | HP LaserJet Office Equipment & Supplies
    Pc x95
    If you are using windows, then go to the Printers dialogue and see if the x95 appears in there. If it does, uninstall it and the error messages will stop. If it doesn't (not very likely), the problem is more complex and further info would be required.
    Mar 20, 2014 | Xerox Office Equipment & Supplies
    Dell 2135 full memory error message cannot print PDF files.
    All three replies are incredibly stupid, but especially Frank's. The issue is simply that you're trying to print something that has too much complexity in it for the printer's pre-installed memory to store the final rendering of before printing. The way a laser printer works, unlike an ink jet, it has to take the entire page to be printed and render the final output in memory before the page can be fed through since it doesn't go line by line. If you're trying to print something that has a very complex page in it, such as a full 8x10 photo, the base amount of memory may not be enough. Dell sells a 256MB add-on memory chip you can put in the printer to get around this. Unfortunately the only other way around the issue would be to reduce the complexity of the page; perhaps try printing the PDF scaled down to 70% so the printed output is a lot smaller but also takes up less of the page, meaning the printer may be more likely to be able to fit the page into the existing memory.
    Nov 24, 2010 | Dell 2135cn All-In-One Laser Printer
    "Page Too Complex" message
    Press ENTER to clear the message.
    Allow the device to finish the job, or press CANCEL to cancel the job.
    Lower the USB speed on the product by turning off "High Speed USB". Following are instructions on how to do this from the Secondary Service Menu:
    To access the Secondary Service Menu press the Menu button.
    Now press the #2 button and use the < arrow to navigate to the High Speed USB selection.
    Press Enter and then use the arrow key to go to Off and press Enter again.
    Press the Cancel button twice to exit the Secondary Service Menu.
    Feb 15, 2010 | HP LaserJet 2840 All-In-One Printer
    I am getting message page to complex to print for jobs that were being printed previously
    In the task bar right click printer and kill any print jobs which are still active.
    Jan 30, 2010 | HP LaserJet 2840 Printer
    Keep getting 5100 error message--eratic
    PLUG IT OUT FOR ABOUT 3 DAYS.AFTER PLUG IT BACK IN AND IF YOU ARE STILL GETTING ERRO MESSAGES CALL 2489921 OR 2849921 AND I WILL GET YOU SOME ONE TO SOLVE YOUR PROBLEM.
    Dec 15, 2009 | Canon MP610 Photo All-In-One Printer
    My acer aspire 4710 is not getting started,and
    This laptop needs to be serviced if its showing a hardware error. You did not go into detail on the error message so its hard to tell what diagnoses to give. I would call Acer directly and have the laptop repaired if its still under warrenty,
    Any hardware error in a laptop can be complex so look into repair locally would be my best suggestion. Please do rate my solution as we strive for ratings- Thanks
    Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
    Aug 19, 2009 | Computers & Internet
    ''Page too complex'' message on HP color laserjet 2840 Multifunct.
    On the printer, hit the menu button
    Then navigate using your left arrow button until you see Main Menu - Service, then hit enter
    then use the right arrow to navigate to high speed usb and hit enter.
    it should now show on, use the right arrow once to change it to off and hit enter 2 times
    let the printer reboot and its should be fixed
    Nov 15, 2008 | Office Equipment & Supplies
    HP LaserJet 2840 Printer Logo
    95 people viewed this question
    mukhtar21 shaikh
    mukhtar21 shaikh
