Question about 2wire (1000-000057-000) Modem
My modem loses connection constantly... It will be green then flash red and kick me off the Internet... Then it will turn green and repeat
  • 206 Answers
Make sure all of the Network cables a re connected
Hope That This Helps!
Posted on Jul 14, 2010
When i connect the dsl cable to it the dsl light starts flashing green then red
Put tinfoil over your splice connectors and filters as they leak signals that totally confuse your modem. Never leave any bare wires, I tinfoil the entire modem to prevent the neighbors from hacking me. I don't use wireless, only CAT5 ethernet cable.
Jan 02, 2013 | Gateway 2wire 2701hg Wireless Dsl Modem
Tip
Troubleshooting DSL Modems
Ever look at your DSL Modem and wonder what all those lights mean? Why do some flash, while others remain solid? What if your lights are different colors? How do you tell if your DSL Modem is working correctly?<br /> <br /> Each light on your DSL Modem represents a function. The light is an indication of whether that function is working properly. Sometimes the placement and title of each function can vary by modem manufacturer, but they are pretty standard in interpetation. If you look closely your modem, you might find that each function is labeled in small print to help identify them.<br /> <br /> A standard DSL Modem has a light for power, internet, ethernet, link and wireless connection. A healthy DSL Modem will have a steady green light that does not blink or flutter for all features other than internet, ethernet and wireless. A flashing or fluttering light indicates movement and useage. When you are connected to your DSL Modem wireless, the light for this feature will blink indicating a connection and/or active useage. If the internet connection is working properly the color of the light will be green. If the connection is working but experincing a problem the light can turn to yellow or orange. If the connection fails, the light on the DSL Modem can be red or absent depending on the problem causing the trouble. If your service is turned off by the provider, more than likely the light will be "off".<br /> <br /> If your lights turn a different color, are absent or your internet connection fails try power cycling your modem before reporting the trouble to your provider. Power cycling helps the DSL Modem to reset its connection and repair your internet services.<br /> <br /> If you are using a DSL Modem alone to connect to the internet (no additional router) you can power cycle it by first turning off your computer and then unplug the modem itself from the power source at the wall. Wait for 1 to 2 minutes and then plug it back into the power source and wait for the warm up to finish before rebooting the pc.<br /> <br /> The DSL Modem should go through the normal warm up procedures of blinking lights, making them all stable and solid green ect. You will know when its finished warming up when the features are set at solid green (other than eithernet, internet and wireless connection as explained above). When the modem finished the warm up, reboot your computer and check your internet connection.<br /> <br /> Power cycling your DSL Modem can help keep your connection healthy and running at optimal speeds.<br />
on Mar 30, 2011 | Computers & Internet
Unable to connect to the internet
possible reasons why you can't connect to the internet
1. Ethernet cable is not plug in tight from the modem to your laptop. 2. DSL light on your modem is RED/flashing green/ OFF 3. if you have router try to unplug both modem and router for 20 seconds then turn your modem on first and wait for the DSL light on the modem become solid green before powering the router ON 4. check the LACAL AREA CONNECTION. it might be disabled. to check click satart menu then go to control panel then look for network ana internet then click network and sharing center. From the left had side of the page look for manage network connection and click it then check if the LAN is disabled. if its disabled right click the LAN and select enable. 5. check internet connection again if it works
Sep 10, 2011 | Computers & Internet
UNABLE TO CONNECT WITH MY LAP TOP ON INTERNET HAVE FOUR LIGHTS ON AND FIFTH ONE FLASHING JUST STARTED YESTERDAY.
So that means its working well and connected to the ISP' server. What is your connection? Is it ADSL?
First make sure that all light have the color of green. If they are Flashing with color RED that means the property associated with the light is having a failure.
Here are the description of Colors and Lights.
Modem Light state: Unlit Flashing Red Flashing Green Steady Green
Cases:::
Power Light
Modem is not getting power - no light Modem has failed POST - Red Power is on - Steady Green
Ethernet (2nd Light)
No Ethernet link detected - No light Problem with ethernet port or cable - Flashing Green Modem has detected a successful link to a PC or router - Steady Green
DSL (3rd light)
ADSL sync signal is not detected - Red Modem is trying to synchronize. - Flashing Green Modem has ADSL sync and is ready for PPPoE session traffic - Steady Green.
Internet (4th light)
Modem has given up or isn't configured to initiate the PPPoE session - No Light PPPoE initiation has failed or PPPoE has been terminated. - Red Initiating a PPPoE session to Internet - Flashing Green. Modem is ready for Internet traffic - Steady Green.
Note: This light sometimes not working even if the connection initiated.
Activity
Normal DSL traffic flow - Flashing Green. Steady traffic flow - Steady Green.
Solving problems.
Case1: You have to connect your machine to the Modem Via the Network cable. Plug the other side of the cable to your Machine. (Not the modem port. Network card port.). Case2: You have to make sure that you have installed the Network Card drives. To check that you have to use Device Manager. Follow these steps. Hit Windows key with R In the "Run" box type devmgmt.msc In the right hand side check whether the network card is installed. If it has a yellow exclamation mark or a mark with red that means you haven't either installed or its having a device/driver problem.
Case3: If its fine then what you have to do is to check your network settings. Heres how: Since you haven't specified the Operating System I m including the Windows XP method here. Not much difference in other Operating Systems as well.
  • Get the Control Panel.
  • Go to Network and Internet Connections.
  • Go to Network Connections.
  • Check the Local Area Connection.
  • Right Click and check "Status".
  • If it says connected
  • Check the Duration and Speed(100 or 1000Mbps).
  • If the settings are fine go to "Support" Tab.
  • Check whether the Machine has received an IP Address. Which is often in the range of 192.168.254.xxx for Siemens Modems/Routers.
  • If you see an IP Address which starts from 169.xxx.xxx.xxx your network card was unable to pick an IP Address from the DHCP router which runs in the modem. (If you run a DHCP in the machine you have to configure to stop leasing IP Addresses to your machine from the Router/Modem. You can try the "Repair" button below and it will try to Release and Renew your IP. If it fail either you have a problem with your network card or Modem/Router (Could be the cable also).
  • If you still see the IP Address which starts with 192.168 the connection with your Modem is fine.
  • Next: Right Click on the Local Area Connection again.
  • Go to "Properties".
  • Double Click on "Internet Protocol (TCP/IP).
  • Check the settings.
  • The settings should be "Obtain IP Addresses Automatically" and "Obtain DNS Server Address Automatically". (But if you know the router's/Modem's IP Address you can configure it and you can give a "Static IP" to your PC as well. It must not be the Router's / Modem's IP and must be in th SAME SUBNET. If router uses 192.168.254.xxx you can assign it as 192.168.254.2)
  • Then Apply the Settings and go to the "Status" again and then click on "Details".
  • Except Wins Server all others must be populated with values in 192.168 range. Check the "Default Gateway" Setting. Its very important that you have pointed the machines Default Gateway to the Router/Modem.
  • Final Check:
  • Go to the "Internet Protocol (TCP/IP) again and click on "Advanced".
  • Check IP Settings (first tab) too make sure DHCP is enabled on you machine.
  • Go to "Options" tab and Check TCP/IP Filtering. Click on properties and make sure that the Filtering is not enabled. If it enabled make sure your network adapter Permits all routers traffic in to the machine.
By following these options will let you surf the internet.
Check for the behaviors of indicators as well.
Case 3 :Browser settings
In the Internet Explorer go to: Tools -> Internet Options ->Connections -> LAN Settings -> Its fine if any box is not checked. Or you can check the "Automatic Detection".
Last thing is If you have a Firewall or Antivirus Suite Please make sure that you are not blocking adapters and traffic/application. You can try to disable Windows Firewall and check whether it works as well.
Hope this will solve your issue. Please be kind enough to rate the answer with a comment (testimonial) if this helps you to overcome the issue. Feel free to contact us further. Thanks for contacting Fixya
Jun 05, 2010 | Siemens SpeedStream Modem (4100) (SS4100)
Airport extreme that is constantly flashing green
yes if only one location has this problem, the airport has now top security level because of latest theaths. it's normal.
Dec 29, 2009 | Apple AirPort Extreme Router
Dsl light flashes red constantly
Whenever your dsl light on the 2wire modem turns red,it only means that there is a problem with the dsl connection to the modem. Here are some ways on how you can isolate the problem
1. check if your modem is properly connected to the phone jack by unplugging and replugging you phone cable
2. try to reboot the modem
3. if still getting the same lights, contact your ISP
Nov 13, 2008 | 2wire HomePortal 1000HW DSL Modem and...
4100 Light flash no connection
*if the DSL light on your modem is blinking..
TRY: using different filters// check physical connection
IF: not resolved call ISP for a trouble ticket for their line department
*if all the lights constantly blinks
DO: purchase new modem, maybe deffective already or check if modem still under warranty so provider can replace it
NOTE: plug 4100 modem directly to the back of the computer tower without the linksys router and check if light status still the same...
HOW: cable connected from back of modem shud be plug in directly to port at the back of PC tower.. completly remove linksys and turn linksys off..
Jul 16, 2008 | Siemens SpeedStream Modem (4100) (SS4100)
Zoom X6 internet light constantly red
the internet light, is usually a blinking green, showing that it's seeing the internet signal. The only reason it's red, is cause there's no net signal..double check the phone line going into the back of your router, and change it if you need to.
check your computers warranty here 4 FREE
Mar 16, 2008 | Zoom X6 (5590) DSL Modem (55900003)
2701HG-B
Hi. I will not repeat the check the phone line and resetting comments as it's now redundant.
I always have a spare modem as a line tester.
I've seen several 2700HG-B 2wire modem/routers burn out and every single time it's the DSL signal or modem portion that is burnt out. Even if you have two or three phone line surge protectors these 2700s are prone to shorting out unless you have a direct signal splitter DSL setup.
Here are a few things you can try to confirm if the 2700 is no longer functional on the DSL signal light problem.
#1: Turn on (plug in) your 2700 without the phone line plugged in and wait. If the DSL starts flashing red then there is a hardware problem in the modem/router.
#2: Plug the phone line into the 2700 while the dsl light is flashing red. It might take about 3 seconds however it should start to flash green and let it flash for about (usually) three minutes. If it turns red then the 2700 is indeed damaged.
#3: If you can enter into your modem using the http://2wire... and check the connection status. The first two status lines should read attempting to connect and no connection.
Nov 01, 2007 | 2wire 2700HG-B Router (2700HGB)
2wire (1000-000057-000) Modem Logo
267 people viewed this question
Top 2wire Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a 2wire Computer and Internet Expert? Answer questions, earn points and help others
