Question about Cameras
Will a sdhc card work in my vivitar dvr 410 - Cameras
  • 571 Answers
Your camera does not support SDHC cards. Only SD- or miniSD can be used.
Posted on Jul 14, 2010
I want to upload a video to my macbook pro for an iMovie, but it says I need a Fire Wire...Is it possible to connect my Vivitar DVR 410 to a FireWire cable?
As a tech, I found FireWire cables to be vastly unreliable, but if you just have to have one, do NOT scrimp. Get one that is heavy duty. The thicker the cable, the better. Avoid flexing the cable near the connectors if at all possible.
Jul 31, 2013 | Vivitar NP60ACcharger) for Vivitar...
Vivitar 508nhd wont work when SD card put in
Are you sure you have an SD card (2GB or smaller)? The 508 won't work with higher-capacity SDHC cards.
Jan 28, 2013 | Vivitar DVR 508HD Digital Video Recorder
Vivitar camera isnt reading sd card
What type and size memory card? Is it formatted?
Dec 22, 2012 | Vivitar Dvr-410 - Camcorder - 1.3 Mpix -...
I'm trying to install my vivitar dvr 410 cd in the computer,and it aint working
I'm panasonic matshita uj 810sperm ejeculation kind of was tightly bound and ..... celebrity *** tapes computer to install the card within the PC while the other mode, ...... Oh my of vivitar dvr 550 review satellite fairs including the NADA fair, ..... operating system you use on your desktop has twin cheerleaders .
Sep 17, 2011 | Computers & Internet
How do i get an 8gb sd card to work in my vivitar dvr-530 cam corcoder?
The DVR-530 works with SD cards, which max out at 2GB. Your 8GB card is actually an SDHC, not an SD card. While SDHC cards fits into the slot, they are electronically incompatible and will not work in this camcorder. You need to use SD cards, 2GB and smaller.
Sorry if that wasn't the answer you wanted to see, but that's the way this camera works.
Sep 11, 2011 | Vivitar dvr-530 Digital Camera
The only sd card i can find locally is an 8gb marked PNY SD HC it says on the packaging that this is new technology and only compatible with SD HC host devices. Is this card suitable for the Vivitar...
To be correct, the 8GB card is not an SD card but an SDHC card.
The 925DVR can use both SD and SDHC cards, up to 32GB in size. There should be no problems with the PNY card.
May 08, 2011 | Vivitar Cameras
Do i need a sd card to operate my vivitar 410
Yes you do. The Vivitar DVR 410 requires a standard SD memory card (up to 16GB) to record images or video. The 410 is NOT designed to accept SDHC memory cards so make sure you purchase the proper type.
Jan 05, 2011 | Vivitar DVR410BLACK Pocket Video Camcorder
My vivitar 410 is saying the memory is full but it has a brand new sd card???
Hi
There are two Vivitar DVR-410 models. A model released in the early 2000's and a newer version released in 2010.
If you have the the earlier DVR-410 model then it will probably only use low capacity SD cards - e.g. 512Mb or lower. if you are trying to use a higher capacity card on this model it may well show that it is full.
If you have the modern 2010 version of the DVR-410 then it can uses SD cards upto 2Gb and SDHC cards upto 16Gb
You should also check the card you are trying to use is formatted, and the lock switch is not set.
Hope this helps
David
Dec 29, 2010 | Vivitar Cameras
DVR 518 question regarding sd card compatibility;- will the product accept a SDHC card to 8gb I have difficulty in getting a standard SD card
The manual is not very precise but you cannot get normal SD cards that go to up 8gb, the highest is 2gb.
When they say 8gb they must mean SDHC.
Hope this helps.
Mar 19, 2010 | Vivitar DVR518 Camcorder
Is the vivitar dvr 530 compatible with sdhc cards
Plug the SD card with contact terminals facing away from battery. It most likely is using internal memory which is much smaller. All cards under 4gb are normal SD. The camera should be able to format the card, or use an adapter and windows will format (default settings).
Jan 03, 2009 | Vivitar DVR 530 Flash Media Camcorder
Cameras Logo
441 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
