Question about Xerox WorkCentre M20i All-In-One Laser Printer
Need to replace the fuser unit kit in a xerox m20 copy machine
Can someone tell me how to change out a fuser unit kit in a xerox M20 copy machine?
  • 239 Answers
First unplug the machine.
Open the right side door. there are four screws to remove. Unplug the two plugs to it.
Pull out the fuser modual.
Insert the new fuser modual, and release or flip the green jam tabs.
When put on the four screews make sure not to over tighten, just a gentle snug is needed.
Close the door, pug machine, and turn it on.
If the fuser fan is not working, this can cause the fuser to over heat again. Make sure the fan is truning by viewing it from the back.
Good luck.
Posted on Aug 23, 2010
  • CCRusty
    CCRusty Nov 15, 2013
    you just screw it in and it works? i keep getting paper jams in the new one and paper gets stuck (accordion)
I have Xerox M 20i .When ever I feed papers from ADf. Print is not coming normal.Some time it shrink the text,I checked the roller are fine.
The Xerox is a business machine and has a setting to reduce the size of scans by percentage.
Read the instruction manual to turn it off or play with the buttons.
WorkCentre M20/M20i Documentation - Xerox Support and Drivers
www.support.xerox.com/support/workcentre-m20-m20i/documentation/enus.html
  1. Cached
  2. Similar
Product documentation for WorkCentre M20/M20i. ... WorkCentre M20/M20i Firmware Installation Instructions. Setup and Installation Guides. Description.
[PDF]WorkCentre M20i System Administration Guide - Xerox Support and ...
www.support.xerox.com/support/workcentre-m20i/file-redirect/enus.html?...en... Xerox WorkCentre M20i System Administration Guide. Page i. Table of Contents. 1 Welcome ................................................................................. 1-1. Introduction .
Xerox 20i Google Search
Nov 19, 2016 | Xerox Office Equipment & Supplies
I changed the drum and now copies are too light.
I'll share a secret with you: Here's what i do when i buy something and it doesn't work properly. I take it the hell back!
But you probably saved a few bucks buying an aftermarket unit, and can`t do that. Right?
Isn`t saving money great?!
Jan 07, 2013 | Xerox WorkCentre M20 Black and White...
I HAVE A M20 XEROX PRINTER AND I AM GETTING A MESSAGE THAT SAYS OPEN HEATER ERROR WHAT DOES THIS MEAN
The heater rod (quartz lamp) inside the fuser roll is cut/ burned. Unfortunately Xerox will not support it as spare. You should buy a new
fuser.
Replacing it is easy. Just a few screws to take off on the right side plus two electrical plugs.
Oct 03, 2010 | Xerox WorkCentre M20 Black and White...
XEROX M20I OPEN HEATER CODE DOES IT NEED FUSER KIT
On an M20 there is a 99.99999 percent chance the heating element in the heat roll has gone bad. You will have to replace the Fuser. Very easy to do.
First off, Google a business called The Parts Drop, call and order a fuser from them. Honest straight forward business. I do not work there, But I do business with them and they are the best.
To replace the fuser. You open the right side door, as if you were removing a jam. You will see the fuser on toward the top. it has a yellow label on it with a heat warning. On each side there are 2 silver phillips screws, a total of 4, You need to remove them. The one on the lower right holds a small black plastic cover on. Take those 4 screws out, unplug the one connector on the right. Insert the new fuser, plug the connector in and replace the screws and plastic cover. There is no reset required, it will warm up and run .
Feb 09, 2010 | Xerox WorkCentre M20i All-In-One Laser...
When printing text on every tenth or so Thank You Card, a card gets jammed and I can't seem to release the printer's grip on it. Is there a release other than the green lever above the rollers on the left...
It really sounds like the teflon coating on the heat roller is worn and contaminated. On an M20 you will have to replace the fuser itself. Google a business called " the parts drop" Give Britt a call and he should have what you need. The M20 uses a unique hearing element. So the fuser itself will have to be replaced. The pages you are printing are tacking to the surface of the heat roller. Not uncommon .
Jun 08, 2009 | Xerox WorkCentre M20i All-In-One Laser...
Paper size mismatch
If the paper supply trays have movable edge guides, make sure the guides are against the paper, also insure the paper is oriented the same a s the print job or copy require.
Hope this is of some help.
Ed
May 06, 2009 | Xerox WorkCentre M20 Black and White...
XEROX WORKCENTRE M20 WHEN POWERING UP MACHINE IT WILL NOT COME OUT OF WARM UP MODE. FUSER IS HOT. MACHINE DISPLAY WILL SAY WARMING UP, MACHINE WILL CYCLE, SCANNER WILL MOVE , PRINTING WILL APPEAR ON...
what you want to do is this, turn the machine off. Remove the back cover. Then on the main board you should see a memory stick or 2 depending on the model.
Remove the memory sticks, then power up the machine with them out. Let it come to ready, then re install the memory sticks and power the machine back up to remove any software corruption.
Apr 08, 2009 | Xerox WorkCentre M20 All-In-One Laser...
XEROX workcenter M20i prints codes at bottom of page
someone has gone into diagnostics and enabled Status Print Engine
Fix
1. press menu/exit key
2. enter # 1931 in that order
3. engine test(diagnostic) should be displayed
4. use arrow keys to scroll to, then select engine test(status print)
5. press enter
6. press the "2" key on numeric keypad to disable (status print)
7. machine will revert to Ready to Copy
8. power off and then back on the M20
9. Your done.
May 02, 2008 | Xerox WorkCentre M20i All-In-One Laser...
Xerox WorkCentre M20i All-In-One Laser Printer Logo
815 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
