Question about Electronics - Others
Require wiring diagram for hyundai trajet towbar fitting to connect to back lights
SOURCE: vauxhall zafira towbar wiring diagram.
what make of towbar wiring kit was fitted ? You can get a Whitter grey (S) fitting kit but this connects to their own black (N) wiring kit I would think any supplier of the N wiring should be able to supply a S kit.
JB
Posted on Mar 13, 2009
  • 33 Answers
SOURCE: tow bar electics
Hi, I don't know whether you have sorted this or not but you MUST NOT connect directly to the cars lighting system, it will assume that there is an overload and switch the circuits off. You must use a bypass relay system of some sort, or preferably a vehicle specific wiring kit which will either plug directly into the REC (fuse box) in the left rear cubby hole in the boot or if you don't have the REC then a different wiring kit plugs into the lamps and has a towing interface with it. If you are not sure what you are doing then best contact your local towbar specialist.
Posted on Jul 21, 2009
  • 33 Answers
SOURCE: wiring diagram for 2055 towbar for honda crv
The best place to connect the wiring is behind the left trim in the boot, there is a grey socket which has all that you need except the fog which can be located in the wiring loom to the left light unit.
  • 582 Answers
SOURCE: ford focus c max towbar electrics
ARE YOU READY
L.H. STOP AND TURN ( YELLOW )
R.H. STOP AND TURN ( GREEN )
TAIL, LICENSE, SIDE MARKERS ( BROWN )
GROUND ( WHITE )
NOW THE COLORS ON THE VEHICAL ARE GOING TO BE DIFFERENT AND YOU WILL NEED A 12 VOLT TEST LIGHT FOR MAKEING SURE YOU HAVE THE WRITE WIRES FROM THE CAR TO THE TOE BAR, DON'T NEED BACK UP TIGHTS FOR THIS
Posted on Aug 25, 2009
  • 33 Answers
SOURCE: Towbar Wiring Instructions Ford Focus
On the left inside the boot behind the carpet is a blue connector, this has all of the wires for the rear lights. if you use a test lamp you can identify which wires do what and connect as you go. Use a self tapping screw for earth.
Posted on Sep 14, 2009
Is there a wiring diagram to fit a towbar wiring / trailer lights to my 2013 Hyundai ix35
if you have the proper kit , the it is a simple matter of pulling the harness connector from a tail light assemble and inserting the harness on to the assembly the fitting the harness back on to it
the wires are color coded and all new trailer plug connections have the pin numbers for the color wire to get the correct lights working at the back
if you are not power or circuit savvy then get the towbar shop to wire it up or get an auto electrician to do the job
Jun 28, 2016 | Hyundai Cars & Trucks
I have a 2012 Hyundai ix35& have fitted a towbar wiring loom.
take it to an accredited auto electrician to have the reverse sensor disconnected when the trailer is connected as the sensors are seeing the trailer when reversing and that is why they are beeping
Feb 17, 2016 | Hyundai Cars & Trucks
How do i fit a towbar to a 1995 hyundai excel
if you get a hyundai bar the instructions will be with it as will most other makes , if you go non hyundai make sure it is the exact bar for your vehicle , a workshop manual will give you the wiring connection required for the brake lights etc keep me posted if you wish
Jul 15, 2014 | 1994 Hyundai Excel
Hyundai trajet reverse light switch
on the gearbox will have a connector with 2 wire coming from it and the end of switch will have a nut shape so can be undone
Apr 28, 2014 | 2001 Hyundai Trajet
Mazda 5 sport with light sencors towbar wiring diagram
We have no wiring diagrams here at fixya due to copyrighted material from Mazda.
Jul 19, 2012 | Cars & Trucks
Wiring Diagram Needed for a MK2 Ford Galaxy
use a test meter to locate the cars wiring thats the easy part and make sure the ground or earth connection has more than one connection ,use the towbat bolt fittings and the back light cluster earth ,Also make sure that the laws in your country allow you to fit it yourself as all europeon states now require this work to be carried out only by a certified garage with the vehicle presented to a inspection station with the certificate of conformity and homoglonation for the hitch and the certificate of fiting signed and stamped by a auto electrician and the garage that fitted it ,as you are not allowed to fit this sort of thing yourself then it has to be added to the vehicles paperwork at the inspection station where the vehicle has to have another yearly inspection as to weither the old one has expired or not .-you have been warned 2_29_2012_10_06_02_pm.jpg
Feb 29, 2012 | Cars & Trucks
I need wiring diagram for 1995 ford ranger XLT i need to hook up trailer lights
Unfortunately this model has separate filaments for the stop and turn signals. You will need to use an adapter relay to hookup a standard trailer plug or you will need a trailer that also uses this wiring setup. The first diagram below indicates there my be a trailer adapter for the turn signals at the base of the steering column. The wire colors at the bulbs are as follows:
tail/running lights: brown
stop: light green
left turn: light green/white stripe
right turn: white/light blue stripe
back up: black/pink stripe
ground: black
Please let me know if you have questions.
Oct 07, 2011 | 1995 Ford Ranger Supercab
I have all relevant diagrams and wires for my tow bar but dont know where to connect wires or what wires too connect my towbar wires too, can any1 help me. its an almera
Hi There it may be easier to trace the required wire from each light cluster and splice in the towbar electrics rather than follow a hand book wiring diagram ie; pin 1 Yellow L/H direction indicator. go to left hand cluster and locate left hand indicator wire, stip back the tape binding enough so that you have enough to play with and then splice in the Yellow towbar wire and continue onto the next wire on the list. Good luck
Apr 29, 2011 | Nissan Altima Cars & Trucks
Tow bar trailer socket wiring connection point to car wiring?
The connectors for towing wire harnesses on foresters are generally on the passenger side, below the rear taillight inside the cargo space. some require pulling up the foam block that is between the spare tire compartment and the taillight. Check where you replace the tailights from inside the car, if there isn't a matching connector hanging out there, check around the spare tire compartment, see if you can remove the carpeted foam block next to the compartment and find the plug under there.
Jun 03, 2009 | 2006 Subaru Forester
Vauxhall zafira towbar wiring diagram.
JB
Nov 07, 2008 | Car Audio & Video
Electronics - Others Logo
148 people viewed this question
Top Electronics - Others Experts
Are you an Electronics - Other Expert? Answer questions, earn points and help others
