How to conect my laptop to my lcd tv using hdmi cable
  • 206 Answers
Take one end of the hdmi cable into the port on your laptop, and put the other into the port into the TV they are probably going to be around the same port
Hope this Helps!
Posted on Jul 14, 2010
How to fix issues whith component outputs on haier hlh26atbb 26 in. lcd ?
When you make the connection with HDMI are you changing the source or input key on the television to activate HDMI port? If you don't activate the corresponding source you connect to and leave the TV in the TV mode, you won't actually see the device you are connecting. It's possible the TV does not support the 1080P from your PS3.
Apr 17, 2015 | Haier HLH26ATBB 26 in. LCD Television
Conecting to tv
For sure there must be some tv output on your computer..... for example hdmi out..... then you need to use hdmi cable and on tv switch to correct AV input.....
another way is to connect via monitor output, but works only with LCD TVs with monitor input.....
if you would tell me what model of computer you have, than you can get better answer
Mar 24, 2014 | Packard Bell Computers & Internet
Conect pc to tv
check HDMI port in ur laptop .if it is there then u can connect your laptop to tv by using HDMA cable.
Nov 19, 2012 | Samsung R530 (NPR530JA02US) PC Notebook
Hi, I have bought LG LCD ld310 . Can I connect my computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable Thanks Jatinder Kumar
Hi Jatinder Kumar ,
Yes you can connect your computer output to lcd tv through dvi-hdmi cable or vga-hdmi cable.
1. Connect to HDMI (DVI) : just plug in HDMI (DVI) out of PC or laptop to HDMI or DVI TV. Than select source from HDMI.
2. Connect to PC : Plug D sub to TV, select PC in.
I hope that will help you.
thanks.
Mar 21, 2011 | LG Televison & Video
I conect my lenovo laptop Y 410 with Panasonic THP42C10 D for Vidio There are no sound in TV
Hi dr_piyushpat,
I see that you conencted your Lenovo Y410 to a Panasonic THP42c10 LCD TV, see details below.
*The Audio will dpened on what cable connection you have from the Laptop to the LCD TV,
*You have Y410 I do not think that HDMI will be an option.
*I believe that you are using the VGA port on the Machine for an extended Video.
*The Audio will really not be coming out of the Panasonic TV if you are using a VGA cable since that is only for Video you will need an audio cable Jack that will relay audio from the Laptops Audio Jack to the Audio Jack of your Panasonic TV thsi is the only way you can get audio out from the Laptop since you are conencted using a VGA cable.
* do not think that HDMI is present on your Lenovo Y410, but if ever you may have that connection/port the way to get Audio from an HDMI conenction is to change the audio PLayback properties and selct HDMI as the default device for the Audio to work using HDMI.
I hope that this helps.
have a nice day,
mvincentc
Feb 13, 2011 | Lenovo 3000 Y410 Laptop
How to connect/configure my acer aspire 4736Z to my LCD TV using the HDMI port/cable of my laptop? i tried to connect the HDMI cable but my laptop hangs...please help
for HDMI, I guess you just connect it with HDMI cable to your LCD TV, and use the FN+F5 or F6 to switch display from laptop's LCD to external. I think it should be the same way as using projector.
Sep 30, 2010 | Acer Computers & Internet
How to conect my laptop to LCD
It depends on the laptop connections. First make sure that your computer is sending data to the port (particularly VGA); you may have to access the BIOS to change the setting (often F1 or F2 on restart). If you have a VGA port on the laptop, get a video cable (VGA-VGA) and connect the two together (this is usually a blue port and you need M/M ends). Then enable in the graphics properties (right click on the display where there are no icons or running program). You want the section that lets you choose sending to the external monitor, the laptop monitor or showing the same contents on both. The version of your OS may alter which command you need (you can also access this in the Control Panel (Display). You may need to restart the computer with the TV on to get the computer to recognize the TV. Set the TV to have the source the PC input. Also connect the speaker cable from the laptop to the TV if you want to use the TV's speakers (there is an audio port next to the VGA port that I believe is a 3.5 mm jack (would need a stereo 3.5 mm m/m cable between the two). Make sure you select the optimum resolution of 1360 x 768.
If you have an HDMI port on the laptop (newer laptops), get an HDMI cable (m/m) and connect the two. Set the TV to DVI or HDMI source (depending on if you need the audio cables separate) and reboot the computer. Then enable the display, as above. I believe you still need the audio cable as well (should use a 3.5 mm stereo to RCA R/L (red/white) cable) look for the DVI audio next to the HDMI/DVI port.
I hope this helps.
(my understanding is that computer HDMI ports do not send the audio but you should check your laptop manual.)
Jun 09, 2010 | Samsung LE32R71B 32 in. HD-Ready LCD...
I have a Samsung Series 6-650 LCD TV (Model # LN46A650A1F). I am trying to connect my Laptop to use the TV as a monitor and have done everything to make it work, using a VGA/HDMI cable, but the TV refuses...
Why do you use VGA-HDMI cable? This TV works fine with VGA cable - it has VGA plug.
Or if your notebook has DVI output, then you can use DVI/HDMI cable and connect it to the TV to plug named DVI/HDMI (only one HDMI input is marked as DVI on TV).
I suppose that over HDMI the TV supports only some standard resolutions, but over VGA it supports almost every resolution laptops use. You can find supported resolutions for each input in the TV manual. Try setting the same resolution on the laptop.
Feb 28, 2010 | Samsung LN46A650 46 in. LCD HDTV
HDMI conection
Hi.
Connect the Home cinema and the TV with the HDMI cable. When you turn it on, first turn on the TV and then the home cinema. I hope this works.
Oct 07, 2007 | Samsung HT-HDP40 - 800 Watts 5 Disc HDMI...
Computers & Internet Logo
121 people viewed this question
Alun Cox
David Payne
David Payne
