Question about Toshiba SD-R6572 DVD RW Dual Layer Burner
I am unable to boot from the Samsung SD-R6572 optical drive installed in my Toshiba P25 laptop running XP. BIOS is set for the CD to boot first, and CD is selected when boot selection window appears (after F12 key), and it still wont boot from the XP install disc, or Toshiba recovery disc. Is this a problem with this particular drive?
    President:
  • 4,070 Answers
Hi! I believe that the problem will be on the optical drive. The lens maybe dirty and not able to read the cd causing it to skip the boot sequence. Try running a cd lens cleaner on the optical drive to clean the lens and tell me how it goes. Hope this helps and have a good one!
Posted on Jul 14, 2010
  • 4 more comments
  • loumudd Jul 14, 2010
    Thanks, cleaning was the only thing I hadn't tried yet. I'll clean both the drive and the disc-s and let you know how it goes.
    Lou
  • dj_relly999
    dj_relly999 Jul 14, 2010
    Sure thing. Good luck!
    I was hopeful, but cleaning did not solve my issue.
    Could it be a corrupted BIOS and is there a way to reset the mother board? I would update my BIOS, but I think I must start from a CD, unless there is a way to do it from a PCMCIA Flash Card.
    Thanks.
  • dj_relly999
    dj_relly999 Jul 15, 2010
    Alright, If no luck on that, I suggest that you remove the battery of the motherboard and let it sit for atleast 3hours. Insert the battery again and reboot the pc then tell me how it goes.
  • loumudd Jul 17, 2010
    Sorry, I've been busy with other projects.
    I don't know if the laptop motherboard has a battery, or a reset switch. I've downloades a service manual so I can find out. If I remove the laptop battery with power disconnected would that do the same thing, or do you think I have to find a mobo battery?
    If this doesn't work, I'm guessing that my optical drive is on the first legs of its demise.
    Thanks.
  • dj_relly999
    dj_relly999 Jul 18, 2010
    Well the truth is, even if you disconnect the mainboard battery it will still fail for the optical drive is the one failing.
Toshiba P25 cannot read cd
Make sure it has power (ejects). Check Device Manager in Safe Mode by pressing F8 during boot. Right click My Computer > Manage. Select Device Manager > View > Show Hidden Devices. Now delete all DVD/CD-ROMs and reboot. Windows will say "New Hardware Found" and install. Check BIOS by pressing F key (correct F key is noted during boot) and make sure BIOS see's the Optical Drive.
Nov 28, 2012 | Toshiba Satellite P25-S5093 Notebook
How do i replace harddisk in my toshiba p25 s487
Ensure you have your backups up to date and either OS disc or rescue discs to place a new system on your new hard drive.
Remove the larger cover from the underside of the laptop, slide out the hard drive. Remove the old drive from the cradle and fit the new drive to the cradle. Slide it in.
Power the laptop up open the DVD drive and place your restore/PS disc in it and on the bios menu select F12. Set the boot device to DVD/CD.
Boot from the DVD/CD drive and follow the prompts.
When finished, download updated drivers from www.toshiba.co. and restore your backups and programmes.
Hope that helps.
Feb 17, 2011 | Toshiba Satellite P25-S487 Notebook
Hi, I've got a Toshiba Portege M205-S810 without CD-ROM drive. Only slots fro USB and SD Card. 1. How to boot up this tablet from SD card? SD card is empty. 2. How to make an image of my CD with Win XP...
http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/bulletin.jsp?ct=SB&soid=886254&ref=EV
If you want to use an external cd drive these are the ones that will work and only these..
The procedure is getting into BIOS settings (press F2 on start ) and on boot sector select the external drive as boot device )
If you want to boot from a SD card or USB memory stick ..than you have to make a boot-able one ..and from what I tried is kinda tricky to make a XP one..so you might consider to install windows 7 if the Ram memory is at least 1 G
But if you want to try ..here are some resources about how to make such a boot-able flash ..
here is for vista and 7 if you do nto have the cd drive ..use a virtual one like iso hunt
http://www.intowindows.com/bootable-usb/
Here is an xp ..and the tools for making a boot-able stick ..read carefully the instructions ..
it was made to install a asus eee which is also a non cd drive net-book
http://wiki.eeeuser.com/windowsxpusb
They recommend to select teh boot device on each restart ..I say to check the bios and see if the boot from usb is available and select it first boot device throughout the installation ..
Jan 27, 2011 | Computers & Internet
I have Toshiba Satellite P25-S509 I lost the cd and I need to reformat it how can I reformat it.
hi
u can formate with any XP CD or Vista just put disk in to optical drive and restart your laptop it will boot from the disk after that just folow the instrction
Jul 07, 2010 | Computers & Internet
Toshiba Tecra A3X Not Booting from USB CD ROM
Your laptop is apparently unable to boot up off an external usb source. Only newer equipment has this provision in the bios. Since you cannot boot up from usb the only way you can recover your unit or do a clean reinstall or repair of xp is to replace the internal drive that is allegedly defective.
Replacing the optical drive is fairly easy and does not involve massive disassembly of your laptop. And any cheap drive will work provided it has the same physical configuration as the old one.
Jul 03, 2009 | Toshiba Tecra A3 Notebook
USB devices not detected
go to the bios and check the boot device order, if the option for usb boot is there makes it first, ortherwise make cd/dvd as your first boot device, ........... enable all the usb options available on your bios
Oct 10, 2008 | Toshiba P25-S526 Notebook
I need xp drivers for my toshiba satellite A135-S2276
you should have windows xp cd put it in your optical drive
you have to go to the bios select first booting device cd/dvd rom then save and exit,
when the laptop starts it ask press any key to boot from cd, you should press any key on your keyboard, then follows the step that it will show, you can get drivers from toshiba site itself
Oct 03, 2008 | Toshiba Satellite A135-S2276 Notebook
Unable to install Win XP on Toshiba portege R500
make the SATA disk mode from ACHI to Compatibility in the BIOS. once its done without any problem you can make partitions, installa Windows XP. hope this helped you. thanks.
Ammar.
Oct 02, 2007 | Toshiba Portege S100-S1133 Notebook
Toshiba SD-R6572 DVD RW Dual Layer Burner Logo
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
